hahnemuhle matt fibre 200
2013-03-26 by benoit.lantoine
Hello has someone tryed this new entry level paper from hahnemuhle? it could be a good way to make archival proof prints a a lower cost than hpr 188. reading the specs, this is not cotton but the paper is warm and contains very few Oba. thanks
2013-03-26 by Ernst Dinkla
On 03/26/2013 08:30 AM, benoit.lantoine wrote: > Hello > > has someone tryed this new entry level paper from hahnemuhle? > > it could be a good way to make archival proof prints a a lower cost than > hpr 188. > > reading the specs, this is not cotton but the paper is warm and contains > very few Oba. > > thanks The sample I have of the Harman by Hahnem\ufffdhle Matt Fibre Duo 210 grams is identical to the Innova Decor Art IFA25 220 grams. I guess this HM one at 200 grams will be identical to the Innova Decor Art IFA24 210 grams. No sample of that one here. The 5 -10 grams difference usually is a marketing trick and not the actually weight difference I use the IFA24 often when customers can not afford more expensive cotton papers etc. A friend uses the IFA25 too. Prints well with the latest HP, Canon and Epson pigment inks. Not smooth but a very light texture that is an advantage in my opinion, my customers like it. High white reflectance without OBA according my spectral measurements. The high reflectance depends a lot on the bleached ECF paper base which can not be considered a paper base that will last in time. But testing could prove otherwise. http://www.northlight-images.co.uk/reviews/paper/innova_ifa25.html -- Met vriendelijke groet, Ernst Dinkla http://www.pigment-print.com/spectralplots/spectrumviz_1.htm December 2012: 500+ inkjet media paper white spectral plots.
2013-04-05 by mig2012photo
It would be very handy to have a comparison list of what paper's are exactly the same. Just like Ernst suggested HPN = Papergraphics smooth art fine etc... Met vriendelijke groet Michiel Megens --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla <e.dinkla@...> wrote:
> > On 03/26/2013 08:30 AM, benoit.lantoine wrote: > > Hello > > > > has someone tryed this new entry level paper from hahnemuhle? > > > > it could be a good way to make archival proof prints a a lower cost than > > hpr 188. > > > > reading the specs, this is not cotton but the paper is warm and contains > > very few Oba. > > > > thanks > > The sample I have of the Harman by Hahnem�hle Matt Fibre Duo 210 grams > is identical to the Innova Decor Art IFA25 220 grams. I guess this HM > one at 200 grams will be identical to the Innova Decor Art IFA24 210 > grams. No sample of that one here. The 5 -10 grams difference usually is > a marketing trick and not the actually weight difference > > I use the IFA24 often when customers can not afford more expensive > cotton papers etc. A friend uses the IFA25 too. Prints well with the > latest HP, Canon and Epson pigment inks. Not smooth but a very light > texture that is an advantage in my opinion, my customers like it. High > white reflectance without OBA according my spectral measurements. The > high reflectance depends a lot on the bleached ECF paper base which can > not be considered a paper base that will last in time. But testing could > prove otherwise. > > http://www.northlight-images.co.uk/reviews/paper/innova_ifa25.html > > > -- > Met vriendelijke groet, Ernst Dinkla > > http://www.pigment-print.com/spectralplots/spectrumviz_1.htm > December 2012: 500+ inkjet media paper white spectral plots. >
