Digital BW, The Print
Epaon 1400 vs. 1430 Cartridges
2013-01-19 by remononaz1
I just purchased and installed a new 1430 to go with my 1400 so that I can now print black and white and color without changing carts. After getting the 1430 up an running I loaded it with my MIS color carts. It does not recognize them at all - say the printer is out of ink and won't print. I loaded the Epson carts just to prove the machine is OK and they work fine.
I have submitted a question about this to MIS, but while I'm waiting to hear for them, does anyone know if there is something different about the 1430 and its carts that would cause this? Is there a setting in machine setup that I am unaware of?
Re: [Digital BW] Epaon 1400 vs. 1430 Cartridges
2013-01-19 by William Harvey
I had a similar issue. I tried to use some 3rd party refillable carts
that had worked fine with my 1400 in a new 1430, they did not work like
yours. I had a set of "new" refillable carts from Inkjetmall.com (Jon
Cone) , I tried these in the 1430 and they work just fine. Perhaps some
programming is missing in the older carts that the 1430 expects and when
not detected the printer refuses to use.
Hope this helps
Cheers
> and they work fine.
Default-WH
William Harvey
From the Beautiful Napa Valley, U.S.A
And
Mas de Cazes
Parisot 82160
France
Lat. = 44 degrees, 15.1 minutes North
Long. = 1 degrees, 50.6 minutes East
Re: Epaon 1400 vs. 1430 Cartridges
2013-01-19 by bakerstrten1
The MIS cartridges didnt work in my 1430 either.  I bought 3rd party refillable cartridges from ebay (Hong Kong).  I have read a suggestion that there are different cartridges required depending on where in the world you got your printer but I dont know if it is true.
I think (but as I am not at home, I cant check) that 1430 cartridges can be labled 79 or 81 and the MIS ones are 79's.  My printer worked with the 81 series cartridges
Cheers
Michael
2013-01-19 by Paul Roark
Check the Epson site to see if the 1400 and 1430 use the same cart #s.  I
think they do.  I believe I've seen comments on this forum and from MIS
that the 1430 runs the same carts.
One thing I'd like to know also, however, is whether the 1430 will accept a
mix of Epson and MIS carts.  My 1400s do, which is rather handy for me.
 That is something I expect Epson could stop with software and get away
with.
Be sure what you are seeing is not just a warning that you're running third
party carts.  I do think Epson software detects non-Epson carts and
sometimes flashes a warning.
Paul
www.PaulRoark.com
2013-01-21 by remononaz1
No word back from MIS yet. Perhaps they have MLK day off. I've looked at a number of web posts indicating that something is up with the 1430 and the cartridge chip. I hadn't anticipated this. I have five set of the MIS cartridges, so replacing them all would cost as much as the printer.
Keeping the printer for Epson-only ink has some value, but with its wireless feature, this will be the 'public' printer in my house. I'd much rather use my dedicated printer for Epson inks and let the others here print with MIS inks.
I haven't opened the new Epson cartridges yet; perhaps I'll send the thing back.
Re: [Digital BW] Re: Epaon 1400 vs. 1430 Cartridges
2013-01-21 by Paul Roark
At http://www.inksupply.com/product-details.cfm?pn=ARC-T079-SET
Re. the Epson Artisan 1430 and Epson Stylus Photo 1400,
MIS has a set of empty carts.
MIS states, "Note: We Do Not Support Mixing OEM, Remanufactured, Empty, Or
Compatible Cartridges, As Chip Issues May Result From Not Matching Sets.
For This Reason We Only Offer These Empty Cartridges As A Complete Set."
I find that I can mix the MIS carts I have with OEM Claria carts in my
1400s, but I have never tested a 1430.  The disclaimer by MIS suggests a
mixed set may be a problem, or at the very minimum, you're on your own if
you do this.
Paul
www.PaulRoark.com
> back.
2013-01-22 by bengui
> you do this.
> Paul
> www.PaulRoark.com
> On Mon, Jan 21, 2013 at 12:53 PM, remononaz1 homershannon@...
> looked at a
> and the
> much
> thing
> > back.
Hi Paul,
As soon as a new bottle of Edwal arrives, I will be mixing and setting
up Noritsu 2K2LK for my new 1430. I plan on initially trying a mix of
Noritsu in MIS cartridges for the first four positions and Epson Claria
cartridges in the yellow and light magenta positions. I'll see if the
mixed cartridges work in the 1430. It would surely be convenient if this
mix works. If it doesn't, do you have any suggestions for good bulk
yellow and light magenta to use in MIS cartridges? I don't plan on
buying any Noritsu except for the K that I have now and I hesitate using
MIS dye for this ink set.
Tom Hefter
2013-01-22 by Paul Roark
Yes, please let us know.  This is what I had in mind with that setup.  It
works great in the 1400.
You might want to just pull the colors out of the 1430 Claria carts and put
it in the MIS carts.  If you buy the Claria M (no LM), after you dilute it
with the generic base (30% Claria M to 70% base), the cost of the LM
becomes quite reasonable.
I don't know much about the MIS dyes.  I assume they would not be as
lightfast.
Paul
www.PaulRoark.com
2013-01-22 by Rafe Cross
Can you not take the chips from the epson cartridges and swap them onto the
ones from MIS? Ive done that with other printers and it works no problems.
I havent seen a 1400 or 1430 though so have no idea what the cartridges
look like.
> lightfast.
> Paul
> www.PaulRoark.com
> ones from MIS?
I don't think that works with the 1400/1430, but I have not tried it.
The MIS chips are on platforms that slide out so that they can be
easily swapped within the MIS 1400/30 cart set, but the Epson chips
are not on a similar platform.
Paul
www.PaulRoark.com
> and put
> lightfast.
> Paul
> www.PaulRoark.com
Paul,
This sounds like a good idea and a solution if the mixed cartridge
approach doesn't work in the 1430. I should know within a week and will
post it.
Tom Hefter
> look like.
>> lightfast.
>> Paul
>> www.PaulRoark.com
> Please visit the Group Homepage to check the Files, and other resources as they are often being updated.
> http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
> If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page.
> Please follow these basic guidelines:
> - As threads develop, trim off excess portions of earlier messages to keep them short.
> - Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice.
> - Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership.
> - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See \ufffdGroup Topic, Rules and Guidelines\ufffd in the Files section:
> http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
Thanks. However, if the mixed cartridges don't work in the 1430, I'll
try Paul's suggestion on transferring Claria ink to MIS cartridges. The
idea of swapping chips never appealed to my semi disabled hands.
Tom
