Digital BW, The Print
Changing Ink Type
Changing Ink Type
2013-01-04 by Keith
Hi all,
I am about to change an Epson 1400 from a black and white pigment to black and white dye ink. I have my reasons.
My feeling is to fill a set of carts with base solution, do a couple of head cleans over a few days and then print several sheets of paper with a purge pattern. Will this be enough to rid the parking pads of any pigment residue?.
Any thought from the groupd would be most appreciated.
Keith Dugdale.
Re: [Digital BW] Changing Ink Type
2013-01-05 by Paul Roark
Keith <keithdale@...> wrote:
> Hi all,
> and white dye ink. ...
If the dyes are old style (not Epson Claria/Noritsu) I'd be sure to flush
everything very well and clean off the parking pad.  We had lots of trouble
converting old 1280s to pigments due to incompatibilities.  I nearly killed
one of my 1400s when HP dyes hit pigments.
On the other hand, the Claria/Noritsu and MIS pigs are compatible.  It
takes 2 cleaning cycles to clear the machine.  I just switched a 4000 from
MIS pigs to Noritsu dyes with no flushing and 2 power cleans.  Works great.
Paul
www.PaulRoark.com
