Papers for Drymounting
2012-11-17 by robertades
Which inkjet papers work best for drymounting prints? I have an Epson R3000 and I plan to use a commercial framer. One paper I'm interested in is Ilford Gold Fibre Silk. Thank you, Robert Ades
2012-11-17 by Paul Roark
I have not had any problems with any of the glossy papers and dry mounting. I just keep the temperature low -- 180 f. Paul www.PaulRoark.com On Sat, Nov 17, 2012 at 10:00 AM, robertades <robertadescpa@...>wrote: > ** > > > Which inkjet papers work best for drymounting prints? I have an Epson > R3000 and I plan to use a commercial framer. One paper I'm interested in is > Ilford Gold Fibre Silk. > > Thank you, > Robert Ades > > > [Non-text portions of this message have been removed]
2012-11-17 by David Kachel
Short answer: if your goal is "art", dry mounting is absolutely out of the question, without exception. If your goal is commercial, dry mounting, glue, staples, chewing gum, anything that works, they are all in the same "quality" class. You can dry mount just about any paper, but the type of dry mount tissue, and the temperature, vary according to paper type. Some image surfaces may be adversely affected by the heat. David Kachel ___________________ Artist-Photographer Fine B&W Photographs www.davidkachel.com david@... Gallery: www.reddoorfinephotographs.com director@... PO Box 1893 Alpine, TX 79831 (432) 386-5787 [Non-text portions of this message have been removed]
2012-11-17 by Seth Rossman
Since you didn't say which type of dry mounting, I'll go ahead and give my thoughts on both. If you're talking about adhesive (transfer or pre-stuck) the 3M is generally preferred. BUT, any "pre-applied" adhesive is deadly. I worked for a major historical society in the past and have dealt with photo conservators. "Acid-free" is not the only issue. From a heat mount standpoint I'd ask what their mounting temperature is. Keep in mind that inkjet papers should never be sent through a laser printer because the coating could melt; likewise some pigments. Lasers (generally) run at 400-deg F; some dry mount presses get close to that. Considering that paper only passes through the fuser at about .10 of a second, leaving a print in a hot press for significantly longer could be as bad. Hinging is the accepted way to mount art. Anything from linen tape to mulberry paper/rice paste. A lot of places (Michael's, Hobby Lobby, etc.) now use what they call photo mounting tape which is a white masking tape. They just tape the art to the mat. Actually, hinging will keep the art flat since it can move with changing temperatures and environmentals. Of course, you didn't use the terms archival or longevity, so I may have gone overboard. Seth -- If I agreed with you both both of us would be wrong.
2012-11-18 by robertades
Okay, I realize I didn't say a whole lot in my OP. It's for hanging pictures around the house -- kids, family, etc. Longevity and archival issues are not a concern. As long as it looks relatively new and fresh for 3 to 5 years, I'm fine. Basically, this is two-pronged question: 1) From an aesthetic standpoint, which types of paper finishes look good? I see matte papers being used a lot, but in most cases those were used in commercial installations where resistance to fingerprints was essential. 2) What are the basics about the dry mount process? I hear lots about cold vs. hot. I want the print to look good, but if the print is destroyed/damaged in the process, it's no loss -- I can make another. Thank you again, Robert --- In DigitalBlackandWhiteThePrint@yahoogroups.com, David Kachel <david@...> wrote:
> > Short answer: if your goal is "art", dry mounting is absolutely out of the > question, without exception. > > If your goal is commercial, dry mounting, glue, staples, chewing gum, > anything that works, they are all in the same "quality" class. > > You can dry mount just about any paper, but the type of dry mount tissue, > and the temperature, vary according to paper type. > > Some image surfaces may be adversely affected by the heat. > > > > David Kachel > > ___________________ > > Artist-Photographer > Fine B&W Photographs > > www.davidkachel.com > david@... > > Gallery: > www.reddoorfinephotographs.com > director@... > > PO Box 1893 > Alpine, TX 79831 > (432) 386-5787 > > > > > [Non-text portions of this message have been removed] >
2012-11-18 by pdesmidt tds.net
You can use dry mount adhesive that mounts at around 170F, and there's no reason to go over 200F, let alone near 400F. I recently went to a show of all Ansel Adams prints. They were all dry-mounted, of course. This issue, whether to dry mount or not, has been gone through for quite awhile. Even the conservators at the Smithsonian say that dry mounting, if done properly, is a perfectly acceptable way to mount art. It's the best way to keep a print flat. On Sat, Nov 17, 2012 at 7:40 PM, robertades <robertadescpa@gmail.com> wrote: > ** > > > Okay, I realize I didn't say a whole lot in my OP. It's for hanging > pictures around the house -- kids, family, etc. > > Longevity and archival issues are not a concern. As long as it looks > relatively new and fresh for 3 to 5 years, I'm fine. > > Basically, this is two-pronged question: > > 1) From an aesthetic standpoint, which types of paper finishes look good? > I see matte papers being used a lot, but in most cases those were used in > commercial installations where resistance to fingerprints was essential. > > 2) What are the basics about the dry mount process? I hear lots about cold > vs. hot. I want the print to look good, but if the print is > destroyed/damaged in the process, it's no loss -- I can make another. > > Thank you again, > Robert > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, David Kachel <david@...> > wrote: > > > > Short answer: if your goal is "art", dry mounting is absolutely out of > the > > question, without exception. > > > > If your goal is commercial, dry mounting, glue, staples, chewing gum, > > anything that works, they are all in the same "quality" class. > > > > You can dry mount just about any paper, but the type of dry mount tissue, > > and the temperature, vary according to paper type. > > > > Some image surfaces may be adversely affected by the heat. > > > > > > > > David Kachel > > > > ___________________ > > > > Artist-Photographer > > Fine B&W Photographs > > > > www.davidkachel.com > > david@... > > > > Gallery: > > www.reddoorfinephotographs.com > > director@... > > > > > PO Box 1893 > > Alpine, TX 79831 > > (432) 386-5787 > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > [Non-text portions of this message have been removed]
2012-11-18 by jimbo
Robert with your display requirements you can pretty much go anyway you want to go.. including simple photomount spray adhesive all the way to a heated platten vacuum rig or laminating your choice.. Dry mounting is quite convenient..I would suggest if you aquire a dry mount press with heat.. that way if you want to fool with different materials you can.. Would I dry mount an original ..nope.. but prints sure.. We have a seal 4468 vac seal rig and a seal 44 inch hot/cold laminator.. As far as what paper surfaces look good well that's going to be your call as it's personal choice Personally I'm not into a gloss finish but much enjoy teh fine art paper looks along with the lower luster photo type materials.. jimbo
Sent: Saturday, November 17, 2012 6:40 PM
Subject: Re: [Digital BW] Papers for Drymounting
Thank you again,
Robert
> David Kachel
> ___________________
> Artist-Photographer
> www.davidkachel.com
> david@...
> Gallery:
> director@...
> PO Box 1893
> Alpine, TX 79831
> (432) 386-5787
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2013.0.2793 / Virus Database: 2624/5885 - Release Date: 11/09/12
Internal Virus Database is out of date.
[Non-text portions of this message have been removed]2012-11-18 by Seth Rossman
Okay, for "hanging around the house" and your worry about fingerprints gives me the mental picture of mounted prints just hanging on the mat board. No frames, glass/acrylic, front mat, etc. The times we did do this was for "exhibits" that moved around. Not that I didn't have to replace a few during the life of an exhibit. You can probably expect a two to three year life if no direct sunlight burns on them during the day. Fingerprints?? Why are folks touching them? If that is an issue, something as simple as a clear fixative spray would let you clean them with a barely damp soft cloth. Fingerprints on the mat would need a either a gray or flexible art eraser. However, those were the silver days and E paper surface. All prints were toned in some manner to stabilize the silver. Your question about type: I would ask your framer what they use. Make a small test and ask him to mount it on something. (Make two and compare when you get one back!) If it is adhesive, 3M makes a roll that requires a special silicone covered press that does a nice job. Some ooze needs to be cleaned off, but they should do that. As Paul said, heat shouldn't burn the coating or pigment at 180 and below. Trust me. I was with a Xerox service guy when he had to replace a fuser in a multi-thousand $$$ Docucolor that had inkjet paper run through. The user had seen me using King James Cast Coat (not an inkjet paper) in a demo machine. He was warned the next fuser was on him!! The point is that ~400-deg F will melt the surface. OT- This is why I stay away from paper for my color laser marked "inkjet and laser compatible." They are neither IMO. Seth
2012-11-18 by Kelly Healy
Cresent Perfect Mount from Dick Blik is a acid free ph neutral (So they say) pre adhesive board. Very easy to use and very rugged. ti comes in all sorts of sizes and !/4 and !/8 thicknes ,also foam core. I use it for making puzzles and toys for my granddaughter, Hever had it buckle or discolor after 2 years. Kelly
2012-11-18 by E.Neilsen
Robert, there are special adhesives made for use with inkjet materials. Is this going to be a in house project or are you taking it some place? Eric Neilsen Eric Neilsen Photography 4101 Commerce Street, Suite 9 Dallas, TX 75226 www.ericneilsenphotography.com skype me with ejprinter Let's Talk Photography _____
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of robertades Sent: Saturday, November 17, 2012 12:00 PM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] Papers for Drymounting Which inkjet papers work best for drymounting prints? I have an Epson R3000 and I plan to use a commercial framer. One paper I'm interested in is Ilford Gold Fibre Silk. Thank you, Robert Ades [Non-text portions of this message have been removed]
2012-11-19 by David
Robert,
You might look at this 3M product for mounting:
http://www.dickblick.com/products/3m-scotch-positionable-mounting-adhesive/#description
I used to use it for making posters, before posters could be printed all one sheet. There is a reference to an applicator in the description, but the adhesive comes with a little plastic device, shown in the picture, that does the trick.
David
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "robertades" <robertadescpa@...> wrote:> > Which inkjet papers work best for drymounting prints? I have an Epson R3000 and I plan to use a commercial framer. One paper I'm interested in is Ilford Gold Fibre Silk. > > Thank you, > Robert Ades >
2012-11-19 by robertades
It's for use in the home and possibly my office. --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "E.Neilsen" <e.neilsen2@...> wrote:
> > Robert, there are special adhesives made for use with inkjet materials. Is > this going to be a in house project or are you taking it some place? > > Eric Neilsen > Eric Neilsen Photography > 4101 Commerce Street, Suite 9 > Dallas, TX 75226 > > www.ericneilsenphotography.com > skype me with ejprinter > Let's Talk Photography > > _____ > > From: DigitalBlackandWhiteThePrint@yahoogroups.com > [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of > robertades > Sent: Saturday, November 17, 2012 12:00 PM > To: DigitalBlackandWhiteThePrint@yahoogroups.com > Subject: [Digital BW] Papers for Drymounting > > > Which inkjet papers work best for drymounting prints? I have an Epson R3000 > and I plan to use a commercial framer. One paper I'm interested in is Ilford > Gold Fibre Silk. > > Thank you, > Robert Ades > > > > [Non-text portions of this message have been removed] >
2012-11-19 by EJ Neilsen
I mean are you going to do the mounting or have it done somewhere else. Eric Neilsen 4101 Commerce Street, Suite 9 Dallas, TX 75226 214-827-8301 www.ericneilsenphotography.com SKYPE ejprinter
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of robertades Sent: Sunday, November 18, 2012 10:14 PM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: Re: [Digital BW] Papers for Drymounting It's for use in the home and possibly my office. --- In DigitalBlackandWhiteThePrint@yahoogroups.com <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> , "E.Neilsen" <e.neilsen2@...> wrote: > > Robert, there are special adhesives made for use with inkjet materials. Is > this going to be a in house project or are you taking it some place? > > Eric Neilsen > Eric Neilsen Photography > 4101 Commerce Street, Suite 9 > Dallas, TX 75226 > > www.ericneilsenphotography.com > skype me with ejprinter > Let's Talk Photography > > _____ > > From: DigitalBlackandWhiteThePrint@yahoogroups.com <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> > [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> ] On Behalf Of > robertades > Sent: Saturday, November 17, 2012 12:00 PM > To: DigitalBlackandWhiteThePrint@yahoogroups.com <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> > Subject: [Digital BW] Papers for Drymounting > > > Which inkjet papers work best for drymounting prints? I have an Epson R3000 > and I plan to use a commercial framer. One paper I'm interested in is Ilford > Gold Fibre Silk. > > Thank you, > Robert Ades > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed]
somewhere else. --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "EJ Neilsen" <e.neilsen2@...> wrote:
> > I mean are you going to do the mounting or have it done somewhere else. > > > > Eric Neilsen > > 4101 Commerce Street, Suite 9 > > Dallas, TX 75226 > > 214-827-8301 > > > > www.ericneilsenphotography.com > > SKYPE ejprinter > > > > From: DigitalBlackandWhiteThePrint@yahoogroups.com > [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of > robertades > Sent: Sunday, November 18, 2012 10:14 PM > To: DigitalBlackandWhiteThePrint@yahoogroups.com > Subject: Re: [Digital BW] Papers for Drymounting > > > > > > It's for use in the home and possibly my office. > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com > <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> , "E.Neilsen" > <e.neilsen2@> wrote: > > > > Robert, there are special adhesives made for use with inkjet materials. Is > > this going to be a in house project or are you taking it some place? > > > > Eric Neilsen > > Eric Neilsen Photography > > 4101 Commerce Street, Suite 9 > > Dallas, TX 75226 > > > > www.ericneilsenphotography.com > > skype me with ejprinter > > Let's Talk Photography > > > > _____ > > > > From: DigitalBlackandWhiteThePrint@yahoogroups.com > <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> > > [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com > <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> ] On Behalf Of > > robertades > > Sent: Saturday, November 17, 2012 12:00 PM > > To: DigitalBlackandWhiteThePrint@yahoogroups.com > <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> > > Subject: [Digital BW] Papers for Drymounting > > > > > > Which inkjet papers work best for drymounting prints? I have an Epson > R3000 > > and I plan to use a commercial framer. One paper I'm interested in is > Ilford > > Gold Fibre Silk. > > > > Thank you, > > Robert Ades > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > [Non-text portions of this message have been removed] >
Then I'd just make sure that they know about and use an appropriate adhesive. It has been long enough now that most places that do mounting should know better, but there are specific adhesives made for inkjet prints. Appropriate being one that doesn't cause yellowing of eth paper and image because of pH issues. Eric Neilsen 4101 Commerce Street, Suite 9 Dallas, TX 75226 214-827-8301 www.ericneilsenphotography.com SKYPE ejprinter
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of robertades Sent: Monday, November 19, 2012 2:18 PM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: Re: [Digital BW] Papers for Drymounting somewhere else. --- In DigitalBlackandWhiteThePrint@yahoogroups.com <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> , "EJ Neilsen" <e.neilsen2@...> wrote: > > I mean are you going to do the mounting or have it done somewhere else. > > > > Eric Neilsen > > 4101 Commerce Street, Suite 9 > > Dallas, TX 75226 > > 214-827-8301 > > > > www.ericneilsenphotography.com > > SKYPE ejprinter > > > > From: DigitalBlackandWhiteThePrint@yahoogroups.com <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> > [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> ] On Behalf Of > robertades > Sent: Sunday, November 18, 2012 10:14 PM > To: DigitalBlackandWhiteThePrint@yahoogroups.com <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> > Subject: Re: [Digital BW] Papers for Drymounting > > > > > > It's for use in the home and possibly my office. > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> > <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> , "E.Neilsen" > <e.neilsen2@> wrote: > > > > Robert, there are special adhesives made for use with inkjet materials. Is > > this going to be a in house project or are you taking it some place? > > > > Eric Neilsen > > Eric Neilsen Photography > > 4101 Commerce Street, Suite 9 > > Dallas, TX 75226 > > > > www.ericneilsenphotography.com > > skype me with ejprinter > > Let's Talk Photography > > > > _____ > > > > From: DigitalBlackandWhiteThePrint@yahoogroups.com <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> > <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> > > [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> > <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> ] On Behalf Of > > robertades > > Sent: Saturday, November 17, 2012 12:00 PM > > To: DigitalBlackandWhiteThePrint@yahoogroups.com <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> > <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> > > Subject: [Digital BW] Papers for Drymounting > > > > > > Which inkjet papers work best for drymounting prints? I have an Epson > R3000 > > and I plan to use a commercial framer. One paper I'm interested in is > Ilford > > Gold Fibre Silk. > > > > Thank you, > > Robert Ades > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed]
2012-11-20 by Steve Gibson
Micheal's has some Elmer's Foam Board that is repositionable Self-Adhesive. I've used it for just some around the house stuff. http://www.elmers.com/product/detail/950049?filterPath=self-adhesive%2f Steve
-----Original Message----- From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of EJ Neilsen Sent: Monday, November 19, 2012 6:07 PM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: RE: [Digital BW] Papers for Drymounting Then I'd just make sure that they know about and use an appropriate adhesive. It has been long enough now that most places that do mounting should know better, but there are specific adhesives made for inkjet prints. Appropriate being one that doesn't cause yellowing of eth paper and image because of pH issues. Eric Neilsen 4101 Commerce Street, Suite 9 Dallas, TX 75226 214-827-8301 www.ericneilsenphotography.com SKYPE ejprinter From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of robertades Sent: Monday, November 19, 2012 2:18 PM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: Re: [Digital BW] Papers for Drymounting somewhere else. --- In DigitalBlackandWhiteThePrint@yahoogroups.com <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> , "EJ Neilsen" <e.neilsen2@...> wrote: > > I mean are you going to do the mounting or have it done somewhere else. > > > > Eric Neilsen > > 4101 Commerce Street, Suite 9 > > Dallas, TX 75226 > > 214-827-8301 > > > > www.ericneilsenphotography.com > > SKYPE ejprinter > > > > From: DigitalBlackandWhiteThePrint@yahoogroups.com <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> > [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> ] On Behalf Of > robertades > Sent: Sunday, November 18, 2012 10:14 PM > To: DigitalBlackandWhiteThePrint@yahoogroups.com <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> > Subject: Re: [Digital BW] Papers for Drymounting > > > > > > It's for use in the home and possibly my office. > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> > <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> , "E.Neilsen" > <e.neilsen2@> wrote: > > > > Robert, there are special adhesives made for use with inkjet materials. Is > > this going to be a in house project or are you taking it some place? > > > > Eric Neilsen > > Eric Neilsen Photography > > 4101 Commerce Street, Suite 9 > > Dallas, TX 75226 > > > > www.ericneilsenphotography.com > > skype me with ejprinter > > Let's Talk Photography > > > > _____ > > > > From: DigitalBlackandWhiteThePrint@yahoogroups.com <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> > <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> > > [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> > <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> ] On Behalf Of > > robertades > > Sent: Saturday, November 17, 2012 12:00 PM > > To: DigitalBlackandWhiteThePrint@yahoogroups.com <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> > <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> > > Subject: [Digital BW] Papers for Drymounting > > > > > > Which inkjet papers work best for drymounting prints? I have an > > Epson > R3000 > > and I plan to use a commercial framer. One paper I'm interested in > > is > Ilford > > Gold Fibre Silk. > > > > Thank you, > > Robert Ades > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] ------------------------------------ Please visit the Group Homepage to check the Files, and other resources as they are often being updated. http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. Please follow these basic guidelines: - As threads develop, trim off excess portions of earlier messages to keep them short. - Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice. - Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership. - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See Group Topic, Rules and Guidelines in the Files section: http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP. Yahoo! Groups Links
