On May 7, 2010, at 1:32 PM, Paul Grant wrote:
> Really depends on how much you are doing in the way of
> adjustments. Try it both ways and look at the difference in the
> histograms for both. You will find you have a lot more margin with
> the 16bit. However all that being said if your not doing much in
> the way of adjustments not sure you will see much.
> Paul
> On May 7, 2010, at 9:20 AM, Sylvain wrote:
>> Hi all,
>> As a Gimp user, I'm just wondering whether the 16bits (not
>> available on Gimp but only on PS) is really an advantage for B&W
>> pictures. Did any one make a comparison between 8 and 16bits
>> processing, in the case of a standard image retouching? Is there
>> really a difference on the final print?
That reply really addresses 16 bit image editing, not 16 bit printing.
I have tested a number of 16 bit export modules over the years, and
not seen any visible improvements from the 16 bit mode; but then, most
did not allow B&W anyways, and color hides the detail quite
effectively. Now that I have direct 16 bit printing capability from
Photoshop CS5, I'll probably test some more, but I suspect that
glossy media would be the only place this might show, and I'm not
really a glossy media fan, so its not high on my list...
C. David Tobie
Global Product Technology Manager
Digital Imaging & Home Theater
CDTobie@...
Datacolor
www.datacolor.com/Spyder3
