Digital BW, The Print
Cartridge shaking
Cartridge shaking
2010-05-05 by John Beeching
Dear All,
I have recently replaced my Epson 2100 with a 3880 and am greatly enjoying
its possibilities and its more economical cartridges.  Whilst one shakes
them in installation I would imagine that the pigment may settle with time
in the cartridges, which could cause altered tones on the prints.  Should I
remove them periodically to give them another shake and, if so, should this
be every week, month or whenever?
Yours,
John
John Beeching
http://johnbeeching.com/
Re: [Digital BW] Cartridge shaking
2010-05-05 by Mark Savoia
Yes, shake (roll hand over hand) very gently and preferably not
immediately before making a print, let the bubbles settle. How often,
depends on how often you make a print, if you print everyday they get
shaken a bit during printing.
Mark
http://www.stillrivereditions.com
On May 5, 2010, at 3:50 PM, John Beeching wrote:
> Dear All,
> enjoying
> shakes
> with time
> Should I
> should this
> Yours,
> John
> John Beeching
2010-05-06 by -= Chris =-
Have YOU actually done this?  Does it not introduce a bubble into the line?
I do understand what you mean, not shake, but gently rock, like in the old days with chemistry in the developing tray <g>.
2010-05-06 by Mark Savoia
Yes, I have been doing it for years. Yes, like agitation of a dev
tank, you do not need to do it much. Epson's claim is that if you
print everyday -all day, you would never need to do this because the
shake of the printer and using up the ink that fast would not give it
enough time to settle.
Mark
> the line?
Mark, THANK YOU!
We'll try that and see if it helps.
I've been very lucky, and have not had any clogs.  But I've been away for 5 weeks, and I need to fire up the printer.
I'll give that a whirl.  After all, my fear could have occurred when I change the cartridge, so doing 'Le Shake' is in order.
-= CB =-
> Yes, I have been doing it for years.<snip> Epson's claim is that if you
Re: Cartridge shaking
2010-05-06 by mojojones2001
Not sure if this applies to your particular cartridges but Inkjetmall has a video that shows how to use the 220ml refillable carts.  Towards the end they demonstrate several methods of shaking the cartridges.  My favorite is "agitate the printer". ;-)
video here: http://www.youtube.com/watch?v=hyjI4tIGQ4Y
J.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, John Beeching <johnbeeching@...> wrote:
> Dear All,
> Yours,
> John
> John Beeching
2010-05-06 by pr_roark
> Yes, I have been doing it for years... like agitation of a dev
> tank ...
I also routinely agitate my 7800 MIS carts before turning the printer on if it has sat for any significant length of time.  I've been pleasantly surprised that there has been no evidence of air getting into the lines.  It's made the relatively fast-settling dilute Eboni approach very easy and consistent.
Paul
www.PaulRoark.com
>... My favorite is "agitate the printer". ;-)
I tried that with my old 7500 and it was not very effective for me.  It's great exercise, however.
Paul
www.PaulRoark.com
2010-05-06 by John Beeching
Dear All,
Thanks for all the advice.  I will now gently shake and imagine that I am
back in the darkroom!
Yours,
John
> > tank ...
> consistent.
> Paul
> www.PaulRoark.com
John Beeching
Re: [Digital BW] Re: Cartridge shaking
2010-05-07 by Andrew Sharpe
All this shaking has me wondering. To get at the cartridges in my 1400,
I have to use the change ink button. And of course, putting the
cartridges back (after filling or agitating) causes a "new ink" cycle to
occur in the printer, wasting my time, and, presumably, my ink. Even
checking to see if the ink needs to be refilled causes it to waste more
ink. Is there a better way? Push the ink button and pull the plug? Does
everyone else suffer through these interminable cleaning cycles every
time they want to examine the cartridges?
Andrew
> <http://www.youtube.com/watch?v=hyjI4tIGQ4Y>
> J.
> <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com>, John Beeching
>  > Dear All,
> enjoying
> time
> Should I
> should this
>  > Yours,
>  > John
>  > John Beeching
>  > http://johnbeeching.com/ <http://johnbeeching.com/>
http://andrewsharpe.com
2010-05-07 by Bob Frost
Does
How else is the printer going to get rid of the air that you let into the
printhead/cartridge system when you disconnected the cartridge?
bob Frost
2010-05-07 by piezobw
Shaking is usually done to re-suspend pigment. The carts we sell for large format hold about 350ml of ink. Epson recommends discarding a 220ml cart that has not been used up in less than six months. So pigment settling is an issue with pigment printers. Intermittent shaking therefore is a preventative to settling. Rather than wait six months to try and breath some more life into the ink, the idea is to not allow the pigment to settle at all.
For desktop carts, the biggest problem often is that an air pocket forms at the port. OR in initial filling that is not done with the vacuum method, it is possible that the air in the port does not get displaced by ink. Even vacuum filling often will not displace this air lock.
The port get's pierced by the ink stem of the printer head carriage and the tiny holes in the stem sometimes encounter the air. The piezo crystal acts like a little tiny pump in the print head and its not strong enough to counter the air pocket and get ink. Likewise the capping station which is a very strong pump sometimes can't either...
Shaking gently can work, but often does not dislodge air pockets. It's best for resuspending pigments. I believe Epson instructs the customer to gently shake the desktop cart before installing. They arguably have the best filling procedure in the industry. So if they have the occasional air pocket - one can imagine that the third-party carts will have more occasion to have air pockets.
For a cart with a nuisance air pocket, I usually put some folded paper toweling on a table, and then sharply rap the cart port side down directly onto the table. The paper towel will absorb any ink that might otherwise mark the table and provides some cushioning to the cart. The rapping seems to force the ink contents to replace the air pocket through the magic of gravity!  Imagine being on an elevator when the cable snaps....  That is what rapping the cart is trying to do...  not a pleasant thought, but trying to illustrate what gravity is trying to do... making the ink above the air pocket suddenly hit the bottom of the port...the air bubble is forced out and rises quickly to the top of the ink cart.
Give it a go...
Jon Cone
Piezography
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "mojojones2001" <mojojones@...> wrote:
> J.
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, John Beeching <johnbeeching@> wrote:
> > Dear All,
> > Yours,
> > John
> > John Beeching
2010-05-07 by Michael King
Jon,
" I believe Epson instructs the customer to gently shake the desktop cart
before installing. "
Yes and at least the Epson R1900 carts, actually have a loose ball bearing
inside them to aid agitation when shaking. You can hear it rattling about.
Not that I actually use Epson carts of course :) But I shake the inks from
new printers, before I sell them off on ebay. With set of new carts fetching
about $90 it sure helps to reduce the cost of printer acquisition.
Mike
> all.
> air pockets.
> Give it a go...
> Jon Cone
> Piezography
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com<DigitalBlackandWhiteThePrint%40yahoogroups.com>,
> > J.
> > > Dear All,
> enjoying
> time
> Should I
> this
> > > Yours,
> > > John
> > > John Beeching
2010-05-07 by Walker Blackwell
In the past what I have done to get rid of annoying air pockets in the port is grab the little cotten-filled plug used to plug the air intake (when transporting the cart). I then take the cart out and tip it slightly so the port-end is down. I simply nudge the plug into the cart port and any excess ink that shoots out gets sopped up by the plug's cotton. This gets rid of air-bubbles nicely.  Gravity feed.
Walker
> Give it a go...
> Jon Cone
> Piezography
> > J.
> > > Dear All,
> > > Yours,
> > > John
> > > John Beeching
Walker Blackwell
802.821.4451
www.walkerblackwell.com
aim: greendirtblues
wblackwell@...
I don't think you need to shake carts in a small Epson - the constant
whizzing backwards and forwards while printing does it for you, and the
ballbearing is there to improve this even more.
bob F.
2010-05-10 by James Parker
Does that mean that those old unopened 4800/7800 PK carts that I've
not used since I bought the printers four years ago are toast? I
bought them thinking I'd print glossy, but never did the switch. I do
shake them and rotate them lovingly every few months.
Jim Parker
parkerparker :: design | photography
http://www.parkerparker.info
@dakkid / twitter
2010-05-10 by Michael King
That's 6 months after opening - yours are unopened. They also have an expiry
date printed on them... not sure why - I think to avoid people keeping
asking how long to do they last.
In practice unopened and gently shaken regularily (say every couple months)
they should last a long time. How long - who knows what will go first. The
rubber seal on the cartridge mount ? The internal bag welding ?  Slow
evaporation through the bag ? Though the internal bags tend to be a foil
material rather than plastic. Presumably because plastic bags /films are
actually porous.
Let us know when you eventually use them ...
Mike
> Jim Parker
> @dakkid / twitter
2010-05-11 by Iric Siegert
I seem to remember some concern several years ago, when people discovered that their expired cartridges would not work in their printers.  The contact chips' logic kept them from printing.  I cannot remember the brand or the resolution.  I vaguely remember something about the manufacturer fixing that.  People did pay for the cartridges after all.  Does anyone remember the details?
