? for the group/recording software?
2004-02-23 by gatormikeb
Ok, I have a ?, what are some of the software packages that I can
use on my pc to plug in my DTXPRESS III and record, not just sounds,
but that will help with righting the sheet music?
Mike
Re: ? for the group/recording software?
2004-02-23 by emf
sounds,
Mike,
I think that Sonar and Cubasis allow you to print out variations
kinds of notation. I don't know whether less expensive sequencers
will.
Ed
2004-02-23 by moosetication
> will.
If you can save from your sequencer as MIDI, then a number of score-
printing packages are available that will import MIDI and produce
scores -- at all prices from low to stratospheric. We use Noteworthy
Composer (or did, until the kids got a "loan" copy of Sibelius for
their school music work). It's about $40. Finale Notepad is free but
unable to import MIDI. At the top end, you have the full-blown
Finale package and Sibelius.
The problem I have found with notation packages is that few of them
are good at drum set notation. You can't do it at all in Noteworthy
as it has no concept of drum set as a staff type or instrument and
no way to change note heads and stems. It's perfectly fine for tuned
instruments. Despite the fact that Sibelius understands the concept
of a drum set staff, the only way to do get the notation right is to
individually change every note head and stem direction (if needed).
For any voice other than snare and toms that gets real dull real
quick. At least, that's the only way I've found to do it. It's such
a horrific user interface that an easier option could be buried out
of sight somewhere.
Stewart
