Upgrading DTXpress with AX-14S and CK-V
2003-11-03 by jeffrey_chiu18
Hello,
Today, I have chat with Ed from Drumbalaya.  And I have decided to
order the Pintach AX-14S and CK-V thru him.  However, I have some
thoughts on the setting, (suggestions are welcomed)
Option #A
1) Replacing the Yamaha KP60 with CK-V.
2) Connecting the AX-14S : 1st end to #9, 2nd end to #10 of module.
3) Putting the original TP80S to the HiHat for 2-zone sounds
4) Putting the TP60 from HiHat to #2 (snare) for another Tom/Snare
sound.
Option #B
2) Connecting the AX-14S: 1st end to #2, 2nd end to #9 of module.
3) Replacing  the TP60 from HiHat with the TP80S to get 2-zone HiHat
sounds
4) Connecting the TP60 to #10 of module for another Snare/Tom Sound,
instead of buying a DB12.
Jeffrey
Re: Upgrading DTXpress with AX-14S and CK-V
2003-11-03 by moosetication
--- jeffrey_chiu18 wrote:
> Option #B
> #9 of module.
> get 2-zone HiHat sounds
> Snare/Tom Sound, instead of buying a DB12.
This is the one I would go for. Your AX14S main sound would work
immediately with the preset kits, as they expect the snare on #2.
Stewart
2003-11-03 by liberatusvirus
--- In DTXpress@yahoogroups.com, "jeffrey_chiu18"
<jeffreychiu18@s...> wrote:
> Hello,
Jeffrey,
Just a reminder: Ed knows that you have a Yamaha module and is
including the polarity adaptor for the CK-V, right?
Ed
Re: [DTXpress] Re: Upgrading DTXpress with AX-14S and CK-V
2003-11-03 by Darren Lo
I'm lost -- polarity adaptor for the CK-V? I believed, perhaps
erroneously, that polarity was mainly an issue with high-hat controllers.
My CK-V seems to function fine on the DTXPress 1 without an adaptor
(although it runs very "hot" as mentioned previously).
Darren Lo
lo@...
Darren,
My mistake. I was thinking hi hat. Oops.
Ed
--- In DTXpress@yahoogroups.com, "liberatusvirus"
Jeffrey,
Forget my message about the adaptor. For some reason, I had hi hats
on the brain; you don't need an adaptor for the kick. Darren,
thankfully, caught my error.
Ed
Hello Darren,
Thanks for correcting Ed.  So in your opinion, which of the setting
would u use?  Sugguestion is welcomed.
Jeffrey
controllers.
adaptor
> Darren Lo
> lo@m...
2003-11-03 by docdrum_s
Jeffrey,
As a recent personal convert to edrumming, I'd definitely recommend
you go with option #B otherwise you will constantly have to "revoice"
both the head and the rim when you switch drum kits on the module.
By spliting between #2 (head) and #9(rim) you only have to revoice
the rim when you switch..... and in a pinch you can either avoid rim
shots or pull out the #9 cable if you don't have time to reset fully
during a performance. The other option of course is to set up a few
user drum kits with all the proper settings and wail away.
I have both the AX-14S and CK-V on my DTXP2 and they work beautifully
with some patient tweaking. I have a PCY10 running into #10 because
bell sounds are an important part of my drumming.
I've also discovered that the AX-14S doesn't run as hot in the center
as the CC120 which is an added blessing. You will find, though, that
with these 2 zone Pintechs (others anyone?) and the DTXP2 you'll have
to work hard at setting the rim/head rejection and crosstalk
parameters for the snare. I've got mine pretty well separated and if
you have trouble let me know and I'll send you off my settings to see
if they work for you.
Good luck,
Rich
--- In DTXpress@yahoogroups.com, "moosetication" <moosetication@y...>
> > Option #B
> > #9 of module.
> Stewart
RE: [DTXpress] Re: Upgrading DTXpress with AX-14S and CK-V
2003-11-04 by Jeffrey Chiu
Hello Rich,
Do you use a "Y" cable to connect the AX-14S or use the supplied cable?
Besides I do not know what kind of cables come with the snare.  Any
idea?
I will have the AX-14S on a stand, separating from the rest of the set
to eliminate the crosstalk and rejection issues from other pads.  I
think I need to set parameters on the snare alone.
Jeffrey
Sent: November 3, 2003 12:30 PM
To: dtxpress@yahoogroups.com
Subject: [DTXpress] Re: Upgrading DTXpress with AX-14S and CK-V
Jeffrey,
Good luck,
Rich
> > Option #B
> > #9 of module.
> Stewart
Community email addresses:
  Post message: DTXpress@yahoogroups.com
  Subscribe:    DTXpress-subscribe@yahoogroups.com
  Unsubscribe:  DTXpress-unsubscribe@yahoogroups.com
  List owner:   DTXpress-owner@yahoogroups.com
Shortcut URL to this page:
  http://groups.yahoo.com/group/DTXpress
Alternate DTXpress site:
  http://www.dtxpressions.com
Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/>  Terms of Service.
Hello,
Ed from Drumbalaya said that AX-14S comes with a stereo cable, which I
can plug it into #9/#10.
Why can't I plug it into #2?  Probably due to the switch issue, right??
How do you connect the AX-14S to #2 and #9?  I guess you need two
different "Y" adaptor.
Detailed explanation would be nice.
Jeffrey
Jeffrey,
Good luck,
Rich
> > Option #B
> > #9 of module.
> Stewart
2003-11-04 by moosetication
> stereo cable, which I can plug it into #9/#10.
A stereo or "TRS" (Tip, Ring, Screen) cable can be used either for
stereo (piezo and switch) or dual-zone (two piezo) triggers. The
AX14S is a dual-zone snare. Input #2 is a stereo input. If you plug
the AX14S into #2, you won't get the rim sound as it's expecting a
switch not a piezo. Input #9/10 is a dual zone (or dual mono) input
and so naturally suited to the output of the AX14S without using
splitters.
Unfortunately, the downside to using it the way that has been
recommended here is that you'll need not one but two insert cables
(splitters). You will need to split the tip and ring from the AX14S,
send the tip to #2 and the ring to another splitter on #9/10.
Stewart
2003-11-05 by docdrum_s
Hi Jeffrey,
I don't remember what cable came with the AX14S but I bet it was a
stereo cable which will only "work" in 9/10 to get you both zones.
What you need is two separate cables to set yourself up:
1. You need a HOSA YPP-117 to split 9/10 into two 1/4" mono females
which you can see here
http://www.directproaudio.com/product.cfm?directid=34032
and
2. 1/4" insert cable (such as HOSA STP 202) to split the AX14S into
two mono males which you can see here
http://www.directproaudio.com/product.cfm?directid=24977
You should ask Ed at Drumbalaya to sell these to you (although I only
saw the YPP 117 on the site) or you can get them from directproaudio
or anywhere else you can find them.
Also, mounting on a stand is the way to go and I was really
specifically talking about the settings for the snare head/rim that
will require some "extra" tweaks..
Hope this helps....
Rich
--- In DTXpress@yahoogroups.com, Jeffrey Chiu <jeffreychiu18@s...>
wrote:
> Hello Rich,
cable?
> idea?
set
> Jeffrey
> -----Original Message-----
> From: docdrum_s [mailto:docdrum_s@y...]
> Jeffrey,
to "revoice"
rim
fully
beautifully
center
that
have
if
see
> Good luck,
> Rich
> > > Option #B
> > > #9 of module.
> > Stewart
