switching to accoustic
2003-09-05 by carlos
hello everybody , is it hard to switch to accoustic drums once you
get used to playing on e-drums?
thanks,
carlos
Re: [DTXpress] switching to accoustic
2003-09-06 by Stephanie Ellison
It could be, if you haven't drummed on an acoustic before and the drum set is
tuned low.  You don't have that rebound from a rubber pads.  You either have
to pull it out or tune the heads tighter, I think.
Stephanie
Re: switching to accoustic
2003-09-06 by carlos
--- In DTXpress@yahoogroups.com, Stephanie Ellison <deafdrummer@a...>
you
drum set is
either have
> Stephanie
thanks a lot Stephanie
2003-09-07 by brown8700
Carlos:
I play both electric and acoustic drums. I find the major difference
being, as Stephanie mentioned, the stick response to the heads.
You'll also find that it takes a wider range of motion to play an
acoustic set because they take up so much more real estate.
Dynamic, too, can be quite different between the two.
One more thing: Cymbal strikes are quite different, in feeling and
response.
If you plan to switch to acoustics, you  may want to also play with
your hihat on a level plane rather than a severe tilt.
Stephen
