Polyphony?
2003-09-05 by Paul Bentley
How important is polyphony with regard to a brain, as there's a big difference between the budget brains; the Alesis DM5 is 16 voice, the DTXpress 32 voice, and the Roland TD-6 64voice? pb
2003-09-05 by moosetication
--- Paul Bentley wrote: > How important is polyphony with regard to a brain... Depends. If you were to layer every voice on every pad, you end up using a lot of voices. For example, I have three stereo cymbals, so each pad has two voices - six overall. But each of those voices has two layers, so I'm actually using twelve "polyphony" voices on those cymbals alone - and because of sustain, they could well be sounding simultaneously. Now look at all the pads... three "triple zone", five stereo, and two mono. That makes a grand total of 42 "polyphony" voices. You'd have to move faster than me to get them all to sound simultaneously, mind. You can hear the effect of this if you play along with any of the built-in songs (sad, but I do from time to time), because they all use voices too. When doing so, cymbal, crashes often choke early because the brain has run out of voices. I can't imagine managing on 16... Stewart
Really Inspector, do you seriously expect me to believe that on 5/9/03 12:20 pm, "moosetication" <moosetication@...> said: > --- Paul Bentley wrote: >> How important is polyphony with regard to a brain... > > Depends. If you were to layer every voice on every pad, you end up > using a lot of voices. For example, I have three stereo cymbals, so > each pad has two voices - six overall. But each of those voices has > two layers, so I'm actually using twelve "polyphony" voices on those > cymbals alone - and because of sustain, they could well be sounding > simultaneously. Now look at all the pads... three "triple zone", five > stereo, and two mono. That makes a grand total of 42 "polyphony" > voices. You'd have to move faster than me to get them all to sound > simultaneously, mind. > > You can hear the effect of this if you play along with any of the > built-in songs (sad, but I do from time to time), because they all > use voices too. When doing so, cymbal, crashes often choke early > because the brain has run out of voices. > > I can't imagine managing on 16... Ah......yes of course, thanks Stewart. Just like computers, more is better! (It was only when I was trying to compare brains that I noticed the flagship Roland TD-10 actually has fewer voices (56) than the lowly TD-6 (64)!)
2003-09-05 by liberatusvirus
--- In DTXpress@yahoogroups.com, Paul Bentley <pb@w...> wrote: > Really Inspector, do you seriously expect me to believe that on 5/9/03 12:20 > pm, "moosetication" <moosetication@y...> said: > > > --- Paul Bentley wrote: > >> How important is polyphony with regard to a brain... The premium on polyphony goes up only to the extent that a module offers possibilities for simultaneous notes. For instance, the ability to stack five drum voices (as opposed to the Xpress' two) or to build chords or short musical phrases on pads can quickly use up available polyphonic real estate. Of course, a company could also offer high polyphony as a selling point, though, as Paul says, more is better, even if the law of diminishing returns (at least for most of us) applies.
