L/Mono
2003-08-28 by narrowgatedrummer
Is the L/mono line out a balanced output? Thanks, Billy...BTW...downloaded the manual here at work and didnt find the answer. Thanks.
2003-08-28 by rdamon@mckinney-usa.com
narrowgatedrummer wrote: "Is the L/mono line out a balanced output?" At first this sounded like a trick question. I had always thought of mono=unbalanced, stereo=balanced, but after doing a quick web search there is mono=unbalanced/balanced, where the tip/ring are unbonded/bonded, respectively. Assuming I correctly understood what I read. (I have been burning the midnight oil the past week, and the candle at both ends and in the middle too! So don't shoot me if I wrong.) You are right, the manual does not say if it is a mono un-balanced or mono balanced (with tip/ring bonded). My guess would be un-balanced. You can't tell from looking an the circuit board jack. So if nobody here knows for sure, then we would need to ask Yamaha Tech. support or if you have a TRS jack with a pig tale, you could plug it in and check the resistance between the Tip/Ring. If you get an open circuit between Tip/Ring then they are not bonded and thus un-balanced. This is my "Friday" heading into a 4-day weekend, so I have only one real thought about now. OGD > ************************************************************************** The information transmitted herewith is sensitive information intended only for use to the individual or entity to which it is addressed. If the reader of this message is not the intended recipient, you are hereby notified that any review, retransmission, dissemination, distribution, copying or other use of, or taking of any action in reliance upon, this information is strictly prohibited. If you have received this communication in error, please contact the sender and delete the material from your computer. ________________________________________________________________________ This email has been scanned for all viruses by the MessageLabs Email Security System. For more information on a proactive email security service working around the clock, around the globe, visit http://www.messagelabs.com ________________________________________________________________________
2003-08-29 by hairytrigger
In the original DTXpress, the outputs are UNbalanced. On the Specs. page(64) They are listed as " (mono phone jack) ." Balanced needs stereo(TRS) jacks. As for the DTXpress II....Looks in the Specs. Scott --- In DTXpress@yahoogroups.com, rdamon@m... wrote: > narrowgatedrummer wrote: "Is the L/mono line out a balanced output?" > > At first this sounded like a trick question. I had always thought of > mono=unbalanced, stereo=balanced, but after doing a quick web search there > is mono=unbalanced/balanced, where the tip/ring are unbonded/bonded, > respectively. Assuming I correctly understood what I read. (I have been > burning the midnight oil the past week, and the candle at both ends and in > the middle too! So don't shoot me if I wrong.) > You are right, the manual does not say if it is a mono un-balanced or mono > balanced (with tip/ring bonded). My guess would be un-balanced. You can't > tell from looking an the circuit board jack. So if nobody here knows for > sure, then we would need to ask Yamaha Tech. support or if you have a TRS > jack with a pig tale, you could plug it in and check the resistance between > the Tip/Ring. If you get an open circuit between Tip/Ring then they are not > bonded and thus un-balanced. > > This is my "Friday" heading into a 4-day weekend, so I have only one real > thought about now. > > OGD > > > > ********************************************************************** **** > The information transmitted herewith is sensitive information intended only > for use to the individual or entity to which it is addressed. If the reader > of this message is not the intended recipient, you are hereby notified that > any review, retransmission, dissemination, distribution, copying or other > use of, or taking of any action in reliance upon, this information is > strictly prohibited. If you have received this communication in error, > please contact the sender and delete the material from your computer. > > ______________________________________________________________________ __ > This email has been scanned for all viruses by the MessageLabs Email > Security System. For more information on a proactive email security > service working around the clock, around the globe, visit > http://www.messagelabs.com > ______________________________________________________________________ __
2003-08-29 by narrowgatedrummer
Hair Trigger. The DTXpress2 manual dosent spec it out. I did however call and a "Martin" called me back to inform me that it too is UNbalanced. Later, Billy
