Triggers on cymbals
2003-08-07 by narrowgatedrummer
I havent tried this yet but, can I set the triggers for the cymals to NOT go off while Im rolling around on the toms? Its driving me nuts! I do love this kit though...endless sounds and effects! Been sweatin half the day with it! Put my Zil. Cymbals in place with it...cranked up the Genz Benz and Jammed! Thanks, Billy
2003-08-07 by liberatusvirus
--- In DTXpress@yahoogroups.com, "narrowgatedrummer" <buoymaster@c...> wrote: > I havent tried this yet but, can I set the triggers for the cymals > to NOT go off while Im rolling around on the toms? > Its driving me nuts! Billy, Pull out the manual and read about rejection/specific rejection under the trigger heading. These are the settings that deal directly with crosstalk. The rejection number is a measure of how much protection an individual trigger needs to withstand general vibrations caused by hitting other triggers on the rack. Specific rejection helps a pad to resist vibrations that originate on a another pad in particular. This protection comes in the form of muting the pad for a nano second when the module detects an offending event from another trigger at the level reflected in the designated number. The higher a trigger's rejection number, the more likely it is to remain silent when you want it to make a noise. So the rejection numbers should be kept only as high as necessary to get the job done. Gain and min. velocity come into play as well. If a trigger is set to fire too hot and too easily, crosstalk will always be a threat. All of these parameters need to be mutually adjusted, and that will take some time to get right.
2003-08-07 by rdamon@mckinney-usa.com
Narrowgatedrummer wrote: "I havent tried this yet but, can I set the triggers for the cymals > to NOT go off while Im rolling around on the toms?" > The way I trouble shooted the triggering problems was to watch the module lcd screen. When you strike a pad the level of the strike will be indicated and any other pads that are also triggering will be noticable. You can go into the trigger setup menu and set the "specific rejection" trigger setting for a pad to tell it not to trigger if the pad next to it is struck. So, if you strike tom1 and ride 1 also sounds then set the trigger for ride 1 to "specifically reject" tom 1. If you strike tom 2 and crash 1 also sounds then set the trigger for crash 1 to specifically reject tom 2. Another thing to consider is that striking the edge of the drum pads as oppose to the center of the pad will generate more vibration that will be transmitted back through the frame. The is what cause the problem between the snare and the hihat, based on the factory settings. Since both pads are mounted on the same arm, their rejection of each other or set high so that striking one doesn't trigger the other. Thus, I you are a heavy hitter, moving the hi-hat pad to the alternate mounting location may make sense. (On the same arm as the module, and then eliminate the specific rejection between the two pads.) If you ever get a bell pad and mount it on the same arm as a cymbal pad, then like wise you will have to tell the bell pad trigger to reject the cymbal pad and tell the cymbal pad to reject the bell pad. Hope that helps. OldGuyDrummer ************************************************************************** The information transmitted herewith is sensitive information intended only for use to the individual or entity to which it is addressed. If the reader of this message is not the intended recipient, you are hereby notified that any review, retransmission, dissemination, distribution, copying or other use of, or taking of any action in reliance upon, this information is strictly prohibited. If you have received this communication in error, please contact the sender and delete the material from your computer. ________________________________________________________________________ This email has been scanned for all viruses by the MessageLabs Email Security System. For more information on a proactive email security service working around the clock, around the globe, visit http://www.messagelabs.com ________________________________________________________________________
