> --- In DTXpress@yahoogroups.com, "jtatsuoka" <jtatsuoka@y...> wrote:
>> it looks like I will have to build an
>> attenuation box for all my inputs.
>> Are all Yamaha pad users getting 99% only on the loudest hits?
> Hi Jun,
> The attenuation box is an interesting approach, but I wonder if it's
> necessary. You haven't had the DXTpress that long. Twiddling with
> min. vel. and gain, as well as your technique, should be able to
> create a situation in which you're not getting bombarded with 99
> every time that you hit a pad (the dreaded machine gun effect).
> Crossfading, in fact, works on the principle that you can vary the
> velocity of hits to create different responses from the triggers.
> One very important thing you learn with e-drums is that they are a
> finesse instrument. Sheer power reaches the law of diminishing
> returns much more quickly with electronic triggers than with
> acoustic percussion. Before you start building extra gear to mediate
> between the module and pads, you might get to know what you already
> have a little better (then maybe you can build the box).
> Ed
> Community email addresses:
> Post message: DTXpress@onelist.com
> Subscribe: DTXpress-subscribe@onelist.com
> Unsubscribe: DTXpress-unsubscribe@onelist.com
> List owner: DTXpress-owner@onelist.com
> Shortcut URL to this page:
> http://www.onelist.com/community/DTXpress
