Re: [DTXpress] Re: Retrofit Trippin
2003-07-13 by Stephanie
>  I have the small Pearl Rhythm Traveler
>  drum kit.They come with a set of mesh
>  heads for silent practice.I'm wondering
>  if these drums can be fitted with drum
>  triggers?
Yes, you can!  And I've heard that the ddrum Red Shot triggers are good for
this.  You simply take a tension rod out and put the trigger in its place.
Then you just hook up a 1/4" cable to your brain and you're done!  This is
the simpler way to go if you don't want to modify your drum shells.
Stephanie
2003-07-13 by cruzinoff@webtv.net
triggers?
Sam Rafael
