To double bass or not to?
2003-01-30 by zolerz <zoler@aol.com>
Hi --Newbie question---should a beginner start with just one bass
pedal or two?
Re: To double bass or not to?
2003-01-30 by Brett <baaron_123@yahoo.com>
First off, I'm assuming by newbie, you mean new at drumming.  Coming
from my own point of view...and everyones will be different, you
should start with one pedal and begin to master the basics first.
Once you get comfortable with being able to get good speed and
technique with one pedal, consider moving on to a second pedal.  no
sense making the learning process any harder than it has to be.  Good
luck!
Brett
--- In DTXpress@yahoogroups.com, "zolerz <zoler@a...>" <zoler@a...>
> pedal or two?
> Thanks
2003-01-30 by underneathheaven <realvast@swbell.net>
Hey zolerz, welcome to the fun world of drums!!  I just started to
learn double bassing after playing drums in junior high and high
school five years ago.  I must say that knowing how to play a set in
the first place really helps in learning an additional pedal.  With
a single bass set up, your left foot will be learning the ways of
the hi-hat.  This is totally different from using your left foot to
double bass.  Suddenly, your left foot, which is used to opening and
closing a hi hat, isn't prepared for the power and technique used in
bassing.  (Trust me, I'm going through that right now!)  What I'm
trying to say is, don't make your left foot learn two seperate
methods at the same time.  This will just take up more of your time
learning how to play and be much more frustrating.  Your gonna have
your hands full without a double pedal, but soon you'll began to
discover things get easier as time goes by.  So I would start with
one bass pedal.  Learning to play is gonna be a lot of fun
regardless of the number of bass drums you use and knowing how to
play is even funner!  Just Don't give up!
> pedal or two?
> Thanks
