pc-based groove check program.
2008-04-06 by Asbjørn Bjørnstad
Hi, I find the lcd display a tad small to look at while practicing, and my monitor is so conveniently placed that I wrote a program that you can run on your PC that shows you your hits and a metronome track. It's a pretty rough first version, but if you'd like to try it out you can download it from http://www.xsit.com.sg/downloads.html (Screenshots at http://www.xsit.com.sg/beater/screenshots.html ) One of the things I haven't fixed properly is automatic midi setup. So you have to run the msDrivers.exe file that is in the same directory as the app itself. (Should be \Program Files\Beater unless you change it.) click on one of the squares in the middle to make it red, and then on the midi input for your drum set to highlight it. Then exit the program and launch Beater. (Corny name, I know.) If anyone have problems or suggestions for improvements I'd like to hear it. -- -asbjxrn
