Tp120 missed triggers
2008-03-02 by Nick Falconer
Hi All been noticing recently at practises with my band that I'm getting occasional missed triggers on my TP120 snare (attached to DTX 3 Special). Think I've traced it to problems with the pad picking up general vibrations from the rest of the band - I can see low levels of input on the DTX display snare channel when I'm not playing anything, and I can feel vibrations by touching the pad either on the head or the underside. So I'm assuming maybe the pad reject settings may be causing missed triggers perhaps? Has anyone else experienced anything similar and found a work around? Should I fiddle with the reject settings? I don't think I can dampen the head as you might on a real snare drum. Or maybe I just need to get the rest of the band to turn down (bet they won't go for that!) Nick
