question about DTX hihat input
2005-01-04 by Michael Walker
Hi! i just got a DXT "brain" and hooked it up to my new pads. But i
find the Hihat is stuck "open" with my old hihat "switch". I realize
that i am going to have to buy (or make) a variable Hihat pedal to
take advantage of the variable HH function ( way-cool.. SLOSHY
HIHATS!)
but its gonna be weeks or months until i can get one here in MOSCOW (
Russia) since the yamaha dealer is out of stock on all the yamaha
pedals.. and i dont think there is a pintech dealer here!
SO.. i was wondering does anybody know the "pinout" for the Yamaha
hihat control input? Its some sort of Control voltage across three
wires, right?
I would like to be able to at least jury-rig a cable so that I can
switch from open to closed with a footswitch... if anyone knows how
to do this i would greatly appreciate it! Or even if i can just lock
the hihats "closed" it would be useful for the moment ( rather than
editing all the kits)
Speaking of editing, is there a good software editor/librarian for
the DTX? (I have the original model)
Thanks in Advance!
Re: question about DTX hihat input
2005-01-04 by Keith
> wires, right?
If someone has taken one apart then they may be of more use than me,
but putting a multimeter on the pedal shows that the cable ring has a
1k resistor connected to the screen when the high hat is closed.  The
resistance progressively reduces down to 1k as the high hat is closed.
 The tip is strange because that also reduces as the high hat is
closed, but only as low as 150k.  I am not sure if one is position and
the other is pressure sensitive.  So if you can lay your hands on a
couple of resistors you should at least be able to fudge it shut (1k &
150k).  A couple of potentiometers and you could make your own.
If I get chance I will open mine up.
Keith.
2005-01-04 by emf
a
The
closed.
and
(1k &
Keith and all,
Take a look at the the HH65's guts in the photo section
under "insides." That'll give you at least an idea of what to expect
when you start re-inventing the wheel.
Ed
2005-01-04 by Keith
> Keith and all,
> Ed
You are right - I should have looked there first - I was in a rush and
thought about your pictures after I posted.
It looks like a few force sensitive switches with series resistors to
give a few zones as you squash your foot down.  I am still puzzled by
why it uses both connections on the stereo plug.
Now I will just have to take it apart!
Keith.
2005-01-05 by emf
and
to
by
OGD, our resident electronics surgeon, must be sleeping in today.
Otherwise he'd be all over this question. He probably knows why both
connections come into play.
2005-01-05 by Keith
Well, I have just had to take mine apart then.
There are four "zones" and the force sensitive resistor progressively
shorts them out.  Three of the resistors are in series and
progressively shorted out with 1k always in series.  The resistors are
10k, 47k and 150k.  This means you get 1k, 11k, 58k, and 208k
approximately.  I am still puzzled by the tip of the plug.  It has a
150k resistor in series and seems to detect the bottom of the stroke,
but will give higher resitances at other points.  There is also a
diode and resistor across the 1k in series with the ring.
Kkeith.
2005-01-05 by emf
progressively
are
stroke,
Keith,
Could the tip be responsible for the foot splash at the bottom of the
stroke?
Ed
2005-01-06 by Keith
> stroke?
> Ed
It is possible, it just seems strange that it has 150k in series with
it.  I will have to play around with some resistors and see what happens.
Oh, and I just ordered a TP100 as a snare.  I find the TP65 a little
small and the postioning difficult so a 10" pad which is freestanding
sounded like a good idea.
Also, I have a Logitech Z2300 for amplification.  I think it is pretty
good - 120W of bass and 40W for each satellite speaker and not
expensive.  Not giggable, but good for practive.
Keith.
2005-01-06 by emf
with
happens.
freestanding
pretty
Keith,
You'll probably have to keep the volume and gain parameters down when
using the Logitech. But when convenient, can you give us a report on
how this system behaves with the DTXpress? Can you hear any strain,
breakup, distortion, etc., when you turn it up a little? Are the
toms/kick through the woofer and the snare/cymbals/transients through
the tweeter convincing and well-defined or legless and indistinct?
Overall, is the Logitech a satisfactory way to amplify the kit
compared to a modest keyboard amp? My suspicion is that, at the very
least, body is seriously thin at low levels, and clarity suffers at
higher levels, but in the interests of saving money, the thunder and
lightening may be expendable for some people who don't want to wear
cans all the time, although once you've felt the power,it's hard to
be satisfied with less.
Ed
2005-01-06 by Keith
> Ed
Ed,
I am impressed with the Logitech and have not heard any distortion
from it yet, and it goes pretty loud.  The reason I chose it was that
it uses a sub-woofer which, while a little smaller than the Yamaha
one, is claimed to be a proper 6th order design.  I spent a lot of
time looking at speaker design for Hi-Fi a while ago and decided that
a well designed sub-woofer can give seriously good bass.  It is what
Bose have been using for years (and I thought they had patents on some
designs).  I am dubious as to the design pedigree of some of the
keyboard speaker enclosures.
Yesterday at the end of my drum lesson I cranked up the volume and let
the drum teacher have a play and he seemed impressed, particulalry
with the floor tom sound (Room1 Lo).  Still no distortion.
There is a sub-woofer adjustment knob on the wired remote which is
useful because in my small room the bass resonates a bit if it is
turned up too far.  It helps to balance out the midrange and bass as well.
I cannot yet compare with a keyboard amp but when I get chance I am
hoping to get round to meeting John Allsop who is local and has the
Behringer KX1200.  I was planning on buying one of those but it got
the thumbs down from 'er indoors when she saw a picture and the
dimensions!  The Logitech is also half the price.
I have been using computer speakers since I bought the DTXpress III
but they were "80W" PMPO which probably translates to around 5W RMS.
There was no kick to the bass and if you turned it up to drown out the
stick noise the bass distorted horribly.  I managed to avoid blowing
them up, although that was plan B to get the wife to agree to some new
ones - turn it up so you rip the cones to bits and have to buy some
new ones!
I did try some Wharfdale Active Diamonds I had lying around, but they
were woolly sounding and distorted on the bass at anything above
modest volumes.  The Logitechs are made for home theatre so are
designed to shake the room a bit I think.
Keith.
Re: subwoofers (question about DTX hihat input)
2005-01-06 by emf
> Ed,
that
that
some
let
as well.
Keith,
It sounds impressive for computer-system performance. Bose holds the
patent on dual-chamber 6th-order design. Though this design is said
to increase efficiency and decrease audible distortion, it apparently
is a bitch to construct and puts the driver at risk for damage unless
the build quality is extraordinary or some serious means of negating
the limits on driver excursion enter into it. I've never heard a
reputedly high-quality Bose subwoofer in action, but the scuttle is
that Bose's transient performance isn't too good, and the overall
effect is more suited to something like sound reinforcement than
accurate musical reproduction. I've been a high-end audio enthusiast
for a long time--listening and reading, anyway--and Bose usually gets
short shrift, if any, in the press. But there apparently isn't a
subwoofer design in existence that doesn't have its drawbacks--the
most obvious being a tradeoff between punchy and deep. Of course, if
money and size are no objects, the odds of a more complete success go
up considerably, but who has the money or the space? I suspect that
many of the pro audio designs are maximized to protect the elements
from heavy abuse rather than to optimize fidelity. Personally, I
don't like boomy and indistinct; I like my toms and kick to have snap
and at least a reasonable frequency response. A home theater
subwoofer that doesn't have to meet the needs of critical music
appreciation could easily thrive on high efficiency and a bottom end
of 40Hz or so, even if it really plays only one note. Given that
dipoles have become an important part of the THX home theater
environment, especially in the surround channels, a subwoofer of that
type might be right at home. Since E-drum kicks and toms aren't note-
specific either, ballpark accuracy in the bass frequencies could
suffice there as well, as long as the elements were able to handle
the huge demands placed on them.
Ed
2005-01-06 by Keith
I remember hearing a really impressive Bose system in Harrogate in the
late 1970s (Annual Hi-Fi show in the UK back then).  It filled a large
hall.  I seem to remember they were always fussy about postioning and
had to be just the right distance from walls - not too far away, not
too close.
> Personally, I
I think you are right.  I plugged a CD player into the Logitech and it
isn't what I would call Hi-Fi - I don't think the freqeuncy response
is flat enough for that.  Sub-woofer systems often seem to suffer from
a mid range hole.  But it produces a good range of frequencies without
sloppy bass and LOUD without distortion which is what I wanted.
If you like Hi-Fi, then you might like my Castle Harlech speakers with
two different quarter wave pipes (powered by a 20W class A amplifier).
http://www.castle.uk.com/pages/classic_harlech.htm
Keith.
2005-01-06 by emf
with
amplifier).
Keith,
At the risk of corrupting our e-drum pedigree, I'd love to hear your
speakers. They don't appear to have a US distributor. You may have to
lug them over to my place, or maybe Stewart can take them with him on
his next visit.  Seriously, is the 20w class A amp a valve design?
Who makes it? My favorite British system of all time, which I haven't
heard for some time, was a Meridian from top to bottom. A bunch of
friends who ran a high-end salon played me a demo of Jim Keltner
drumming solo through it. I couldn't believe my ears. It was the only
time that I've ever closed my eyes and truly believed that the music
from a stereo system was live. Unfortunately, the system cost about
$50,000 in the 1990s.
On the Bose thing, a friend of mine designed their new tower
amplification system, with dedicated subwoofer(s)--the Personal
Amplification System--mainly for small-to-medium stage use. He was
going to set it up for me so that we could audition it for e-drums--
an accidental use that seemed promising. But, first, inventory was
too small to spare a review sample, and then we both got too busy. I
may be seeing him soon; maybe we can still get it done. Expensive
though. His name is Paul Fidlin. He worked for Fender and then
Celestion before getting the more secure gig at Bose. I was later to
find out that he designed Celestion's first serious sub-satellite
system back in the late 1980s, I think, which I coveted at the time
even if only for its looks.
Ed
2005-01-06 by Keith
The amp is actually a Pioneer M73!  It is little known over here, but
I picked one up with pre-amp and CD half price ex demo from a small
shop which tried to set themselves up as a top end demo place and I
think couldn't sell much of the expensive stuff.  It can be switched
to class AB to give 120W per channel.  It gets HOT in class A (takes
up to 1000W from the mains).  I had some home built KEF 105.2 speakers
at the time (CS9 was the home constructor series with the mid range
and tweeter in the main box and a modified crossover to compensate for
the small loss of physical volume, rather than perched on top like the
original 105.2).  They had a 15" bass but were infinite baffle.  It
was after auditioning lots of speakers that I realised you don't need
a big woofer for big bass.  The twin 5" 1/4 wave design is far tighter
than the 15" KEF in the infinite baffle design.  The two 1/4 waves are
tuned to different frequencies.  It may not be obvious from the
picture but one of the 5" units points upwards, the other forwards.
They also do a larger one, the Howard, but in the auditioning room I
preferred the Harlech.
Keith.
Re: [DTXpress] Re: subwoofers (question about DTX hihat input)
2005-01-06 by Vernon Graner
>> speakers with two different quarter wave pipes (powered
> Keith,
<snip>
As amplifier "classes" seem to be of interest, in case anyone wants to
experiment with a Class "D" amplifier design ("D" or "Digital" amplifier
that creates next to no heat at rated power, *very* efficient), Ramsey
has them for sale as kits with a very good set of "teaching" docs
included so you learn amplifier theory as you build. Their kit is here:
http://www.ramseyelectronics.com/cgi-bin/commerce.exe?preadd=action&key=UAM2
or
http://tinyurl.com/5hgqh
Vern
Vern Graner CNE/CNA/SSE    | "If the network is down, then you're
Senior Systems Engineer    | obviously incompetent so why are we
Texas Information Services | paying you? Of course, if the network
http://www.txis.com        | is up, then we obviously don't need
Austin Office 512 328-8947 | you, so why are we paying you?" \ufffdVLG
