Compatibility Question
2004-11-20 by danielmouly
I'm new to this group and I'd like to know what brnds/models of mesh
snares I can attach to my good old DTXPress I kit ?
Christmas is coming soon, and I'd like to add this kind of item to
my wish list.
Many thanks in advance.
Best regards
Daniel
Re: Compatibility Question
2004-11-20 by emf
--- In DTXpress@yahoogroups.com, "danielmouly" <danielmouly@y...>
wrote:
> Hi,
mesh
> my wish list.
Hi Daniel,
Good to have you with us. The most popular, and probably not
coincidentally the most affordable, is the 10" ConcertCast dual-zone
snare from Pintech; the price usually hovers a little above $100 new.
They also show up on ebay fairly often, and Ed Morin at Drumbalaya
often stocks used ones with his new ones. Pintech also has a 14" full-
fledged snare called the AX14S, which is usually $180 new. I've
written a lot on this forum about how the Pintech meshes do with the
Yamaha modules. Run a search on Pintech, pot (for potentiometer),
ConcertCast, or AX14S.  Something recent should pop up--as recently
as a couple of days ago.
Hart makes a really attractive snare, and once upon a time, it didn't
work at all well with any Yamahas. I've heard fairly recently,
however, that the TE3-triggered Harts don't seem to have the old
problems. If you're interested in the Harts, which are more expensive
than the Pintech options, check out Hart Dynamics Int'l's website and
call their number. Binky may be able to help with mix and match. Hart
was supposed to have hosted Tony Verderosa some months ago for the
sole purpose of evaluating their components through Yamaha
electronics (although I've heard that tune before).
The Rolands should work, maybe with a compromise or two, but my (and
others') biggest gripe about them is their cost. But it's what the
market will bear for the industry leader.
The main issue with all of the mesh snares is the sensitivity of the
triggering from soft to loud, and drummers don't have the same
tolerance or demands. It's always best to try before you buy, but if
you can't, make sure that you can return anything that doesn't
satisfy you. Personally, I lean toward the Pintechs, partially
because I know them best. If you have a Guitar Center nearby, see if
you can attach a Roland to a DTXpress module and flail away for a
while with various trigger settings using your own headphones. Some
GCs even have a Pintech kit on hand (what do you think McConaghy?).
You have to be savvy about pad type, velocity curves, and the Yamaha
DIP switches on the back to get an accurate reading of dynamic range.
You might be able to get away with connecting a 10" Pintech on the
rack where your Yamaha snare is, though you'll have to turn the
clamp, but ulimately a separate stand is better for positioning. All
of the other snares definitely need stands. One benefit of severing
the mesh snares from the rack is that they won't be subject to
crosstalk, allowing for low rejection numbers, a low minumum
velocity, and high gain (if it appeals to you). Consider also that a
big 13 or 14 inch snare will seem really incongruous with the 8.5"
Yamaha toms and relatively small rack. That's one reason to go with
the small Pintech. I've assumed that you want dual zones so that you
can use the rim as well. Only the Pintech ConcertCasts offer a single
zone, if I'm not mistaken.
Ed
2004-11-22 by danielmouly
Ed,
Thanks a lot for all this valuable information. I'll do the searches
you suggest, and then I'll visit a drum shop to see what I can find.
I'm living near Bordeaux, France, and I'm not sure all the brands
and models you mention will be available, but I'll see...
Thanks again, and I'll keep the group informed of my experience.
Regards
Daniel
> wrote:
> > Hi,
> mesh
to
> > my wish list.
> Hi Daniel,
zone
new.
full-
recently
didn't
expensive
and
Hart
(and
if
if
Some
McConaghy?).
Yamaha
range.
All
severing
a
with
you
single
> Ed
