DTX1 Cymbal Replacement
2004-09-08 by Frank & Susan Malinowski
My son has a DTXPRESS 1 that has a staticy cymbal, I pretty sure the
sensor is wearing out not a problem with cables or connections. I do
not know if this is fixable but I am willing to order a replacement as
he is pretty serious as a drummer. But as long as I am ordering a
replacement is there an optimal "upgrade" cymbal that will work with
the first generation DTXpress? If there is a simple sensor fix please
let me know I'm not a drummer or musician but comfortable with
electronics.
Re: DTX1 Cymbal Replacement
2004-09-08 by oldguydrummer
--- In DTXpress@yahoogroups.com, Frank & Susan Malinowski
do
as
with
please
> electronics.
Look in the photo archive here under "Inside the Dtxpress" and you
can see what the insides of one of the cymbal pads look like. You
have piezo glued to the underside of the plastic housing. If it has
gone bad and you are handy, you can replace it.
If it is the connector that is just dirty, then use a little alcohol
on a q-tip. If the PCB or the connector is cracked and you are versed
in repairing PCB's, you maybe able to resolder and repair it.
Replacing the PCB would cost as much as a new cymbal pad.
The newer PCY130 (mono) and the PCY130S would work fine on the
Dtxpress modules I/II/III. The PCY150S would work but you would only
get two zones to work and not three. The PCY65/65S will also work
with that module and is much less expensive.
OGD
Re: [DTXpress] DTX1 Cymbal Replacement
2004-09-08 by Anthony Robinson
You can get him a Pintech Zenbal, which is an upgrade to the DTXPress Cymbals, the cymbals are about $159 list, however, you can pick one up on Musicians friend for $111. I own 3 of these cymbals and they work very very well.  The cymbals are Zenbal ZB2's.  HTH.
Frank & Susan Malinowski <yakers@...> wrote:My son has a DTXPRESS 1 that has a staticy cymbal, I pretty sure the
electronics.
Community email addresses:
  Post message: DTXpress@yahoogroups.com
  Subscribe:    DTXpress-subscribe@yahoogroups.com
  Unsubscribe:  DTXpress-unsubscribe@yahoogroups.com
  List owner:   DTXpress-owner@yahoogroups.com
Shortcut URL to this page:
  http://groups.yahoo.com/group/DTXpress
Alternate DTXpress site:
  http://www.dtxpressions.com
Yahoo! Groups SponsorADVERTISEMENT
Yahoo! Groups Links
   To visit your group on the web, go to:
http://groups.yahoo.com/group/DTXpress/
Do you Yahoo!?
Win 1 of 4,000 free domain names from Yahoo! Enter now.
