Casio CZ/ VZ/ FZ - Pro Series
Index last updated: 2026-04-28 22:42 UTC
Are the CZ-3000/5000 velocity sensitive?
2012-12-01 by mz82003
I'm new to the CZ community and I'm currentmly on the search of an 8-voice 16-DCO CZ synth.
I know the CZ-1 is the only one in the family whith a keyboard that can generate velocity and AT, but I'm wondering:
Are the CZ-3000/5000 velocity sensitive, i.e. can they be programmed to respond to velocity when used with a sequencer or a master kb?
Thanks.
Re: [CZsynth] Are the CZ-3000/5000 velocity sensitive?
2012-12-01 by Jason Adkins
Hiya,
I think they are,like the Yamaha DX27/100 for example.
J
On 1 Dec 2012, at 20:22, mz82003 wrote:
> Hi,
> Thanks.
2012-12-01 by 350ypvs@googlemail.com
As far as I'm aware, only the CZ-1 is velocity sensitive. None of the other
CZ's to my knowledge are velocity/ after-touch sensitive, even via MIDI.
All models bar the CZ101/ 1000/ 230S are 8 voice/ 16 DCO synths. The 101/
1000/ 230S are 4 voice/ 8 DCO (or 8 voice with just a single DCO line).
CZ-1's come up occasionally but seem to be one of the rarest of the CZ
models. 101/ 1000/ 3000/ 5000 are more plentiful.
Hope this helps!
Chas
On 1 December 2012 20:22, mz82003 <mz82003@...> wrote:
> Hi,
> 16-DCO CZ synth.
> Thanks.
2012-12-02 by Jason Adkins
Sorry I think your correct,its a long time since I used an CZ3000/5000
I just assumed it could be,I was using it as a controller too because
I  never had money at the time I just would have thought it would have
responded to velocity over midi but I sold them before I actually got
a velocity sensitive keyboard to try them out.
> the other
> MIDI.
> 101/
> line).
> Hope this helps!
> Chas
>> Hi,
>> 8-voice
>> 16-DCO CZ synth.
>> can
>> programmed to
>> Thanks.
2012-12-02 by charlie midi gfa
fz has similar engine as cz and is velo senctive ..a.T   too!
if you don't need controller than try for a fz or vz as matter of fact
cz-1 only  gm entry level synt,,other have no velo or a.t.
chaz
To: <CZsynth@yahoogroups.com>
Sent: Saturday, December 01, 2012 7:36 PM
Subject: Re: [CZsynth] Are the CZ-3000/5000 velocity sensitive?
>> the other
>> MIDI.
>> 101/
>> line).
>> Hope this helps!
>> Chas
>>> Hi,
>>> 8-voice
>>> 16-DCO CZ synth.
>>> can
>>> programmed to
>>> Thanks.
>> Yahoo! Groups Links
Re: Are the CZ-3000/5000 velocity sensitive?
2012-12-03 by jpshea
To answer this question (and indeed for any MIDI synth), just check the device's MIDI Implementation Chart.
In particular, make sure there's a "yes" under the Note On Velocity - receive column.
Here's the ref from MMA:
http://www.midi.org/techspecs/midi_chart-v2.pdf
Normally, you'll find the implementation chart at the back of the user manual.
JPS
> > the other
> > MIDI.
> > 101/
> > line).
> > Hope this helps!
> > Chas
> >> Hi,
> >> 8-voice
> >> 16-DCO CZ synth.
> >> can
> >> programmed to
> >> Thanks.
> > Yahoo! Groups Links
2012-12-03 by Daniel Forró
CZ3000 transmits velocity value 64, and changes received velocity
1-127 to value 64.
CZ101 the same.
In CZ5000 Owner's manual velocity isn't mentioned at all, so it's not
transmitted and received.
CZ1000, CZ230S the same.
There's no parameter concerning programming the reaction to received
velocity.
Daniel Forro
On 2 Dec, 2012, at 5:22 AM, mz82003 wrote:
> Hi,
2012-12-03 by charlie midi gfa
okay messages are still delayed ?
sent friday i think
and this one is sent sunday at 10:30pm
chaz
Sent: Saturday, December 01, 2012 7:56 PM
> chaz
> From: "Jason Adkins" <jason_ralf808@...>
>>> the other
>>> MIDI.
>>> 101/
>>> line).
>>> Hope this helps!
>>> Chas
>>>> Hi,
>>>> 8-voice
>>>> 16-DCO CZ synth.
>>>> can
>>>> programmed to
>>>> Thanks.
>>> Yahoo! Groups Links
>> Yahoo! Groups Links
2012-12-03 by Summa
Sure, since you're moderated.
> sent friday i think
> chaz
> From: "charlie midi gfa" <charles.copp@...>
> > fact
> > chaz
> >> CZ3000/5000  I just assumed it could be,I was using it as a
> >> controller too because  I  never had money at the time I just would
> >> have thought it would have  responded to velocity over midi but I
> >> sold them before I actually got  a velocity sensitive keyboard to
> >> try them out.
> >>> the other CZ's to my knowledge are velocity/ after-touch
> >>> The  101/ 1000/ 230S are 4 voice/ 8 DCO (or 8 voice with just a
> >>> single DCO  line).
> >>> the CZ models. 101/ 1000/ 3000/ 5000 are more plentiful.
> >>> Hope this helps!
> >>> Chas
> >>>> Hi,
> >>>> programmed to
> >>>> Thanks.
> >>> Yahoo! Groups Links
> >> Yahoo! Groups Links
> > Yahoo! Groups Links
CZ/VZ 		mailing list	: http://groups.yahoo.com/group/CZsynth
FMHeaven	mailing list	: http://groups.yahoo.com/group/fmheaven/
FS1R		mailing list	: http://groups.yahoo.com/group/fs1r/
Vokator		mailing list	: http://groups.yahoo.com/group/vokator
FM-Synthesis	mailing list	: http://groups.yahoo.com/group/fm-
synthesis/
http://www.summasounds.de/
HOW COME I AM MODERATED? ITS ONLY BEEN 23 YEARS MAKING MIDI MUSIC ....
ANYBODY ELSE MODERATED...?
CHAZ
Sent: Sunday, December 02, 2012 10:47 PM
>> sent friday i think
>> chaz
>> > fact
>> > chaz
>> >> try them out.
>> >>> single DCO  line).
>> >>> Hope this helps!
>> >>> Chas
>> >>>> Hi,
>> >>>> programmed to
>> >>>> Thanks.
>> >>> Yahoo! Groups Links
>> >> Yahoo! Groups Links
>> > Yahoo! Groups Links
>> Yahoo! Groups Links
> synthesis/
2012-12-03 by jammie
i also get my messages late
but not just on cz
i also get them week late on the k5000 forum
and on one of the kurzweil forums im on and i have been a member of these forums for for a very long time
  To: CZsynth@yahoogroups.com
  Sent: Monday, December 03, 2012 4:00 AM
  CHAZ
  >> sent friday i think
  >> chaz
  >> > fact
  >> > chaz
  >> >> try them out.
  >> >>> single DCO line).
  >> >>> Hope this helps!
  >> >>> Chas
  >> >>>> Hi,
  >> >>>> programmed to
  >> >>>> Thanks.
  >> >>> Yahoo! Groups Links
  >> >> Yahoo! Groups Links
  >> > Yahoo! Groups Links
  >> Yahoo! Groups Links
  > synthesis/
2012-12-03 by Summa
Daniel,
this is happening all the time and I could only guess what false
information could do to an inexperienced user. Someone might spending
his last dime buying CZ-1 when searching for a GM Synth.
If someone on this forum feels up to correct Charles in cases he's
spreading superficial knowledge with such a confidence, I'd be happy
to end moderating him.
...Summa
On 3 Dec 2012 at 14:33, Daniel Forró wrote:
> CZ1 has nothing common with GM standard.
> Daniel Forro
On 3 Dec 2012 at 14:30, Daniel Forró wrote:
> New? Jupiter 80 was introduced in 2011...
> Just those patch sets are new.
> Daniel Forro
> On 3 Dec, 2012, at 9:26 AM, charlie midi gfa wrote:
> > http://www.rolandus.com/go/jupiter-80/
> > yep powerfull
> > a new take on the old grand daddy synth
synthesis/
2012-12-03 by steve_the_composer
In my experience:
--neither the CZ-3000 nor the CZ-5000 (a) respond to or (b) transmit non-zero velocity data other than treating it all as 64 (as has been mentioned).
--the CZ-3000 is a CZ-5000 without the sequencer.
--the CZ-3000 does allow sequencer sysex commands to access the memory [storage] that would be used if it were a CZ-5000 and had a sequencer.
As for reading manuals and midi implementation charts (someone suggested doing so), while in general that is the first place to look, sometimes (with some gear) there can be undocumented features.
For example, the CZ sequencer (true with the synth engine, too) can have data sent to it via sysex bulk data messages that you cannot do via the panel.
Steve
--- In CZsynth@yahoogroups.com, "mz82003" <mz82003@...> wrote:
> Hi,
> Thanks.
Re: CZ1 Patches - Samples
2012-12-03 by narfman96
I created 471 patches for the CZ1 and uploaded them here in the group. These were the best CZ patches I found and then I added velocity and aftertouch settings to them to make them more expressive for the CZ1.
http://launch.groups.yahoo.com/group/CZsynth/files/CZ%20-%20Sounds.../
There are also 3 other banks in the same location.
Glad to help out the god of thunder... Narf
--- In CZsynth@yahoogroups.com, Þórhallur Skúlason <djthor54@...> wrote:
> hi
> Where can I find Patch-Banks (Sysex format) for CZ1?
> Best
> THOR
2012-12-04 by charlie midi gfa
daniel whats the correct term i should use?
it has velocity
it has after touch
probally program change too....
its a step closer to the actual GM standard,
 at least if  used as a controller  for some gm devices
its got pitch bend . modulation .....too
before i google it
is gm a set of patches
or
 is gm general midi
i think i answered the original post quite well except had a few day delay
charlie
Sent: Monday, December 03, 2012 4:04 PM
Daniel,
...Summa
> Daniel Forro
> Daniel Forro
> > yep powerfull
synthesis/
Yahoo! Groups Links
Re: [CZsynth] Re: CZ1 Patches - Samples
can a cz read cz101 patches?
if so i have a bank or two i compilled or made
charlie
Sent: Monday, December 03, 2012 5:30 PM
Subject: [CZsynth] Re: CZ1 Patches - Samples
> hi
> Best
> THOR
Yahoo! Groups Links
2012-12-04 by Þórhallur Skúlason
> charlie
> From: "narfman96" <narfman96@yahoo.com>
> --- In CZsynth@yahoogroups.com, ��rhallur Sk�lason <djthor54@...> wrote:
> > hi
> > Best
> > THOR
2012-12-04 by Daniel Forró
Correct term for what?
Almost all MIDI instruments have velocity, aftertouch, program change,
pitch bend, modulation, sustain... It's a basic MIDI function set. Of
course such instrument can control any other MIDI instrument, also GM
instruments.
GM is General MIDI standard. Part of it are all those mentioned
features. But the main reason for inventing GM was deeper
standardization of patch set, controller set, drum sounds assigning to
keys, velocity and controllers curves and some other features. Before
GM there were some other standards, like Roland C/M (MT32), Yamaha PK,
DOC, RX...
GM was introduced in 1991, Casio CZ was produced few years before, so
it's not GM compatible.
And later better standards came - 1991 Roland GS, 1993 Yamaha TG300B,
since 1994 few generations of Yamaha XG, since 1999 GM2, Yamaha XF...
Daniel Forro
> it has velocity
> it has after touch
> before i google it
> or
> is gm general midi
> delay
> charlie
2012-12-04 by Simon Beck
GM stands for General MIDI. It is a set of atandards intended to ensure that MIDI sequence data files are played back using appropriate sounds, although the type of sound generation, realism and exact sound used are not specified. If you have a MIDI file of, say a jazz trio of grand piano, upright bass and drums and you play it into a GM-compatible synth, you can be sure that the sounds used will at least vaguely resemble a piano, acoustic bass and drums, although the actual sounds may not be the same as those on a different GM-compatible unit.
The original GM sound set comprised 128 sounds covering orchestral, electric and ethnic instruments, plus drums, synth pads, synth effects and a few seemingly random sound effects. There were many omissions - no Wurlitzer electric piano, combo organ, contra-bassoon, tabla, mandolin etc. Many of these have been provided by the revised GM2 spec.
> before i google it
or
is gm general midi
2012-12-04 by José Ángel Morente
On Tue, Dec 4, 2012 at 4:01 AM, charlie midi gfa
> it has velocity
> it has after touch
I guess you are confusing 'MIDI' with 'General MIDI'.
http://en.wikipedia.org/wiki/General_midi
GM is mainly a standardization for patch numbers and instruments. Thus, a
GM enabled synthesizer would always play a "piano" on patch number 01, a
violin on patch 41, etc.
Furthermore, it should be able to play a standard GM drum kit on MIDI
channel 10 and be 16 part multitimbral.
Velocity, pressure, pitch bend, etc. are usually found on many non-GM
synthesizers (before and after GM was established).
2012-12-04 by Summa
At least no exactly defined standard like GM
> it has velocity
> it has after touch
But missing about 80% of the GM specs...
but not even close, a Synth like the MT32 is an entry level GM-
Synth...
GM has nothing to do with the ability as Keyboard Controller...
Like about 90% of the polyphonic synths
> before i google it
> or
>  is gm general midi
It's a combination of both and alot more than that...
Minimums specs for a GM device:
GM synthesizers are required to be able to:
Allow 24 voices to be active simultaneously (including at least 16
melodic and 8 percussive voices)
Respond to note velocity
Support all 16 channels simultaneously (with channel 10 reserved for
percussion)
Support polyphony (multiple simultaneous notes) on each channel
Have a look at:
> charlie
> From: "Summa" <flotorian@freenet.de>
> Daniel,
> ...Summa
> > Daniel Forro
> > Daniel Forro
> > > yep powerfull
> synthesis/
synthesis/
2012-12-04 by Summa
> Synth...
Specification wise, since it's not completely covering the standard,
it's one of the predecessors to GM.
synthesis/
2012-12-04 by Jason Adkins
Isn't this a bit off topic? I'll throw the D110 into the ring as GM
non GM too.
I think the moderator needs moderating..... ;)
J
>> Synth...
> synthesis/
More precisely I wanted to say (in the case of CZ5000, 1000, 230S): of
course velocity is transmitted and received, because it's part of Note
On (and Note Off) message, but probably the same way as CZ3000 and 101.
Daniel Forro
> 1-127 to value 64.
> CZ101 the same.
> velocity.
2012-12-04 by Summa
> non GM too.
> J
Mistakenly sent out the first mail a bit too early, had a long night
and a DYI Neighbour hammering thru the morning and even my earplugs
weren't able to block this ;) Very noisy but unfortunately not
exactly rhythmic :-S
I'm not sure if something like the Roland utility or GM Instrument
Definition file that remaps the MT32 sounds to GM order is avaible
for the D110 as well.
http://www.queststudios.com/roland/utilities.html
> >> Synth...
> > synthesis/
> > Yahoo! Groups Links
synthesis/
Oh God I know what you mean I live next door to a wanker like that...
Bloody asshole,I will force him to hammer at the rhythm of the James
Brown band
>> non GM too.
>> J
>>>> Synth...
>>> synthesis/
>>> Yahoo! Groups Links
>> Yahoo! Groups Links
> synthesis/
