AVR-Chat
PWM
PWM
2006-01-08 by Anurag Chugh
why only PWM?.. why not use an R2R ladder instead with precision resistors...
i know they would hog a whole PORT but arent they easier to implement ??
and they can do DC output values too... a simple opam in front (voltage follower) will boost current output too...
i am sure most people dont use R2R... but please tell me why?? i know there must be a reason...
Anurag
Re: [AVR-Chat] PWM
2006-01-08 by Russell Shaw
> resistors...
R2R is a high component count and uses more space (16 resistors) compared
to one RC filter DAC. The RC filter DAC also does DC output. R2R needs
high tolerance resistors to guarantee monotonicity, but that can be
undone if there are differences between the pin driver voltages.
R2R is better for high-speed things.
Re: [AVR-Chat] PWM
2006-01-09 by Jim Wagner
Each has its place.
R-2R networks take much less filtering. Response speed is
faster. Parts count is higher and it may take parts with
some precision.
PWM is (often) low parts count UNLESS you try to
reconstruct signals that are too close to the PWM
repetition frequency. Then, you can need multiple-pole
filters that require op-amps or more.
Jim
On Sun, 8 Jan 2006 23:18:34 +0530
> to implement ??
> Anurag
The Think Different Store
http://www.thinkdifferentstore.com/
For All Your Mac Gear
Re: [AVR-Chat] PWM
Sorry, but wrong about the tolerance!
Each successive leg has half the tolerance contribution of
the leg just above it in the ladder. With 1% resistors, the
over-all tolerance will be in the 3-4% range.
What may be more critical is monotonicity, especially the
step going from 0x7f to 0x80 (in an 8-bit) DAC.
An R-2R DAC also relies on the on-resistance of the FETs in
the logic output circuit.
Jim
On Mon, 09 Jan 2006 15:59:30 -0600
 Thomas Keller <tkeller1@neb.rr.com> wrote:
> precision
> > resistors...
> in front
> me why?? i know
> Anarag:
>   I can speak only for myself.   Consider an R-2R ladder
> for 8 bit DAC:
> it contains 16 resistance elements.  Now, let us assume
> that each of these resistance elements is an indiivdual
> 1% tolerance resistor.  Total overall tolerance of the
> R2R ladder is now 16% (not very good, is it?)   1%
> resistors cost between $0.15 and $0.25, depending on
> where you purchase them and how many you purchase 9unless
> you're puschasing thousands, of course).  Somewhere
> between $2.40 and $4.00 for A +/- 16% dac?  *HORRIBLE*
> Assuming you can obtain (at any price) +/- .1% resistors
> (at any price), you still have only +/- 1.6% tolerance,
> at a trmendously higher price.
>   Now, consider 8 bit PWM as implemented using an AVR.
>  Tolerance is
> going to be +/- 1/255 of Vcc.  Assuming a +/- 5%
> tolerance on your Vcc (which you *REALLY* ought to have,
> for correct AVR operation), this yields an "absolute"
> tolerance of  +/- 1.9%, at ZERO additional hardware cost
> (unless you need post filtering, in which case, a .25W,
> 5% resistor and a small cap cost what, maybe $0.25 in
> combination?).  Of course, there is the question of
> software devlopment costs, but 1) those are one time
> engineering costs, not repeating BOM (bill of materials)
> costs, and 2) let's face it, PWMing ADC is pretty
> straight forward, and takes very little time and effort
> to program, thanks to the foresight and engineering
> skills of the engineers at Atmel.
>   Granted, 8 bit PWWM isn;t going to yield great results
> for, say audio
> purposes, but then, neither is an 8 bit R2R ladder (in
> fact, pretty much exactly the same results, in terms of
> signal fidelity/distortion).
>   If I have gone on too long, my apologies.
> Tom
Re: [AVR-Chat] PWM
2006-01-09 by Thomas Keller
Anarag:
I can speak only for myself. Consider an R-2R ladder for 8 bit DAC: it contains 16 resistance elements. Now, let us assume that each of these resistance elements is an indiivdual 1% tolerance resistor. Total overall tolerance of the R2R ladder is now 16% (not very good, is it?) 1% resistors cost between $0.15 and $0.25, depending on where you purchase them and how many you purchase 9unless you're puschasing thousands, of course). Somewhere between $2.40 and $4.00 for A +/- 16% dac? *HORRIBLE*
Assuming you can obtain (at any price) +/- .1% resistors (at any price), you still have only +/- 1.6% tolerance, at a trmendously higher price.
Now, consider 8 bit PWM as implemented using an AVR. Tolerance is going to be +/- 1/255 of Vcc. Assuming a +/- 5% tolerance on your Vcc (which you *REALLY* ought to have, for correct AVR operation), this yields an "absolute" tolerance of +/- 1.9%, at ZERO additional hardware cost (unless you need post filtering, in which case, a .25W, 5% resistor and a small cap cost what, maybe $0.25 in combination?). Of course, there is the question of software devlopment costs, but 1) those are one time engineering costs, not repeating BOM (bill of materials) costs, and 2) let's face it, PWMing ADC is pretty straight forward, and takes very little time and effort to program, thanks to the foresight and engineering skills of the engineers at Atmel.
Granted, 8 bit PWWM isn;t going to yield great results for, say audio purposes, but then, neither is an 8 bit R2R ladder (in fact, pretty much exactly the same results, in terms of signal fidelity/distortion).
Tom
Re: [AVR-Chat] PWM
2006-01-09 by Tom Becker
> ... assume that each of these resistance elements is an individual 1%
tolerance resistor.  Total overall tolerance of the R2R ladder is now 16%...
How do you arrive at that?
Tom
Re: [AVR-Chat] PWM
Jim Wagner wrote:
>Each has its place.
>some precision.
  Sure, but on the other hand, if you need to rresort to complex and
expensive mutlipole filters, you're probably trying to reconstruct
compelx signals with a processor that is poorly chosen for the task
(e.g., isn't fast enough).  Moreover, if your signals are so compl;ex
that multippole filters are needed, in all probabilty, you should be
working a a greater resoltion than 8 bits to begin with.
  Of course, some of the AVRs, IIRC, can support up to 10 bit PWM (still
pretty low resolution for fancy signal porocessing,though).
Tom
Re: [AVR-Chat] PWM
  Simple mathematics.  The reason tht tolerances are specified as plus
and minuse is that with any individual ocmponent, you can never know
which way the value will be off, or by what specific quantity.
  So, with 16 devices each specified to be within + or - 1%, the overall
tolerance of the network is plus or minus 16%.
  Each comnponent contributes to the overalkl tolerance of  the system.,
Re: [AVR-Chat] PWM
2006-01-09 by gtbecker@rightime.com
> ... Each component contributes to the overall tolerance of  the system...
 I have no doubt, but the tolerances simply add?
 What happens if, in this case of 16 resistors, one uses 10%-tolerance resistors?  The sum exceeds 100%?  Does the error of either LSB resistance contribute to the system error as do the MSB resistances?
 Tom
Yahoo! Groups Links
Re: [AVR-Chat] PWM
2006-01-09 by Micah Stevens
If you have 10, 100 ohm resistors in series, and each is 1% tolarance, the
tolarance of the total group is +- 10%.. That is indeed correct, and if each
is +-10%, then the total tolerance is +-100%.. odd as it may sound.
In this R2R circuit though, this is not a series circuit. However, without
really taking the time to do the calculations, I would suspect a similar
outcome. Each resistor's tolerance would contribute to the tolerance of the
circuit as a whole in an additive or subtractive manner.
I would agree with Thomas in this regard.
-Micah
>  > system...
>  Tom
>  Yahoo! Groups Links
> SPONSORED LINKS
> Atmel avr   Microcontrollers   Intel microprocessors
>   Pic microcontrollers
> YAHOO! GROUPS LINKS
>  Visit your group "AVR-Chat" on the web.
>  To unsubscribe from this group, send an email to:
>  AVR-Chat-unsubscribe@yahoogroups.com
>  Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Re: [AVR-Chat] PWM
Why? This isn't a divider circuit. I think I see what you're getting at, but
I'm not sure I'm buying it.
-Micah
>  Jim
>  > precision
>  > > resistors...
>  > in front
>  > me why?? i know
>  > Anarag:
>  > for 8 bit DAC:
>  >  Tolerance is
>  > for, say audio
>  > Tom
> YAHOO! GROUPS LINKS
Re: [AVR-Chat] PWM
2006-01-09 by John Samperi
At 09:08 AM 10/01/2006, you wrote:
>you can never know
Which could be 0%...in theory of course :-). I have used a Burns R2R resnet
for the past 12 years or so to generate sounds for pedestrian crossing
signals, it is not a HIFI system but never noticed any difference in sound
in the some 20,000 units made (shipped to a few countries too).
By the way the cost is nowhere near the >$2 mentioned  before, it takes very
little room, don't need a buffer as I use the audio amp for buffering.
Regards
John Samperi
Ampertronics Pty. Ltd.
11 Brokenwood Place Baulkham Hills, NSW 2153 AUSTRALIA
Tel. (02) 9674-6495       Fax (02) 9674-8745
Email: john@ampertronics.com.au
Website  http://www.ampertronics.com.au
*Electronic Design * Custom Products * Contract Assembly
Re: [AVR-Chat] PWM
2006-01-09 by Dave Hylands
Hi Micah,
I don't agree.
Let's take the example, of 10 x 100 ohm resistors with 1% tolerance.
Let's suppose that they're all 99 ohms (worst case low-side
resistance).
If you add up all 10, you get 990 ohms which is still within 1% of the
nominal 1000 ohms that you should have. I don't see where how you
could possibly get 10% of error.
Dave Hylands
Vancouver, BC, Canada
http://www.DaveHylands.com/
Re: [AVR-Chat] PWM
Hi Dave,
Hmm.. I might be a complete fool. I was working on a tube amplifier quite a
while ago where this bit me in the arse because I was thinking percentages
and was off by quite a bit of ohms, but your math is quite correct. Sorry
about typing before thinking.
-Micah
On Monday 09 January 2006 2:38 pm, Dave Hylands wrote:
>  Hi Micah,
>  > the tolarance of the total group is +- 10%.. That is indeed correct, and
>  > if each is +-10%, then the total tolerance is +-100%.. odd as it may
>  > sound.
>  I don't agree.
>  resistance).
>  Dave Hylands
> YAHOO! GROUPS LINKS
Re: [AVR-Chat] PWM
  Quite right.  My bad.
  True enough, I hadn't even thought ot address that issue
tom
Re: [AVR-Chat] PWM
2006-01-10 by Johnathan Corgan
Uh, no.
Ten, 100 ohm, 10% tolerance resistors in series add to 1000 ohms.
If they are all at the maximum of their range, 110 ohms, then their sum
is 1100 ohms, still +10% of 1000 ohms.
Likewise, at the minimum of their range, 90 ohms, then their sum is 900
ohms, or -10% of 1000 ohms.
Same for 1% resistors.  Same for parallel connection vs. series connection.
-Johnathan
Re: [AVR-Chat] PWM
2006-01-10 by kholt@sonic.net
For my scope testpoints, in my data paths, I always leave
6pin headers for a simple D-A, based on only 6 resistors:
1R,2R,4R,8R,16R,32R.  R's are 1% values, multiples  usually
of 2.048K or another standard value.  Standard 1% values are
not always spot-on the power-of-2 value, however, but I select them
easily with a DVM.  I tie the common sides of the resistors all together
and to the scope probe or audio amp.  It look pretty good, and sounds
reasonable, when the digital outputs are modern CMOS parts.
Sometimes the 6 resistors are permantly soldered onto the board,
standing up(to save space), for a permanent analog testpoint.
Ken
>>you can never know
> resnet
> very
> Regards
> John Samperi
RE: [AVR-Chat] PWM
2006-01-10 by Randy Ledyard
Hey Tom
No argument with your facts there, but have you looked at Futurlec (www.futurlec.com) ?
They list 1% metal film resistors for $0.20/10 - or 2cents each - the only problem with them is they take a long time to ship - from AUS or HongKong - not sure
From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com]On Behalf Of Thomas Keller
Sent: Monday, January 09, 2006 5:00 PM
To: AVR-Chat@yahoogroups.com
Subject: Re: [AVR-Chat] PWM
Re: [AVR-Chat] PWM
2006-01-10 by Robert Adsett
Not quite in the same line of thought but no one has mentioned the other
reason to prefer PWM over R2R in some situations and that is power.  Feed
the PWM into a power device rather than an RC filter and with a slowly
responding load like a heater tank or a motor the load itself acts as the
low pass filter and you avoid the losses that a linear solution would
entail.  At the cost of ending up with high frequency current transients of
course.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,   be
they legal, genetic, or physical.  If you don't believe me, try to chew a
radio signal. "  -- Kelvin Throop, III
http://www.aeolusdevelopment.com/
Re: [AVR-Chat] PWM
2006-01-10 by Roy E. Burrage
It actually is a divider, Micah. Each leg of the R2R ladder divides the output current by 2.
REB
-Micah
 Jim
Re: [AVR-Chat] PWM
2006-01-10 by Micah Stevens
Alright, I think me and my big mouth got schooled on this one. Thanks for the
insight.
-Micah
> REB
> > but I'm not sure I'm buying it.
> >-Micah
> >> Jim
Re: [AVR-Chat] PWM
2006-01-10 by gouy yann
hi all,
if I correctly remember, to known the global error from the individual errors
is somehow like computing the derivative of a function.
where A and B are transfert functions with dA and dB their respective error.
d(A+B) = dA + dB
d(A-B) = dA + dB (always the worst case)
d(A.B) = B.dA + A.dB
d(A/B) = (B.dA + A.dB) / (A.B)
these are the basic relations, just fancy how it quickly becomes quite heavy!!!
regards
   Yann
> each
> Uh, no.
> -Johnathan
___________________________________________________________________________
Nouveau : téléphonez moins cher avec Yahoo! Messenger ! Découvez les tarifs exceptionnels pour appeler la France et l'international.
Téléchargez sur http://fr.messenger.yahoo.com
Re: [AVR-Chat] PWM
2006-01-10 by Thomas Keller
> (www.futurlec.com <http://www.futurlec.com>) ?
> HongKong - not sure
Randy,
  Thanks for the tip.  Being in the US, I don't generally consider
overseas suppliers, because of the shipping times, and thr shipping
costs invovled.
  And yes, I have seen similar pricing from US vendors, as well.  I was
thinking in term sof the average hobbyist, who often purchases things
like resistors one at a time from a shop such as Radio Shack ()or some
equivalent).
  As it turns out, price may be the only issue on which I *am* correct.
Ah, well, I am iused to having my foot in my mouth (I have even learned
to pass on condiments).
tom
Re: [AVR-Chat] PWM
>>course.
  Quite so.  In the  case of the purely resistive load (e.g., a heater
element),, a complete win.  In the case of rreactive loads such as
motoros or speakers, the high frewquency transients *CAN* generate a lot
of heat.  One reason, among many, why it is best when choosing induction
motors for PWM speed control to seelct motors rated for "inverter service.."
   They have internal insulation that is specoificed to handle both more
heat, and higher voltages (the high frequency currents can also result
in high voltage spiking withint the motor windings).
   When worlkgin with PWM for audipo (e.g., Class "D" a,ploifiers) one
must either use specially designed class D driver chips which use
techniques permitting filkterless output, or provide appropriate output
low-pass filtering.  Low pass filtering for a 10 Amp AC circuit can get
expensive, which is why filterless driver chips are all the rage with
designers and chip vendors.
   Withoiut the lowpass filter, or a filterless driver chip, you run a
sigificant risk of cooking the voicecoils in your speaker drivers.
Particularly in the tweeters.  That can get expensive pretty doggoned fast!
tom
Re: [AVR-Chat] PWM
2006-01-10 by Jim Wagner
This is absolutely true and is a point worth making.
Some loads work well directly driven by PWM. Heaters and
motors are good examples. Typically, these are devices with
a long mechanical time-constant compared to the PWM period.
When you can do this, it it typically more efficient
(power-wise). Fewer or no heat-sinks. Switching devices are
used instead of analog things where linearity may be an
issue. All of these create a cost benefit for PWM.
All of that said, the cases where you can use PWM in this
way are limited. But, where you can, it really helps.
Jim
On Mon, 09 Jan 2006 23:59:34 -0500
> to implement ??
> front (voltage
> mentioned the other
> is power.  Feed
> with a slowly
> itself acts as the
> solution would
> course.
> Robert
> restrictions,   be
> me, try to chew a
