AVR-Chat
ATTiny2313 vs. AT90S2313
2005-07-26 by n4ij
I received a small Olimex development board that included a Tiny2313.
The 7805 voltage regulator is apparently bad and puts out the same as
it's input voltage (12volts). Needless to say, I suspect that 12volts
on the Tin2313 has zapped it.  But, I got curious and looked at the
differences between the 2313 and tiny2313. One of the differences is
that there is a fuse bit for the oscillator.  Being new to AVR - if
the fuse bit is set, is it correct that that is the confiugration
forever?  A fuse bit is just like a regular fuse, I assume. Blow it
and it is blown.  I barely know anything about the 2313 and guess I
need to change to the Tiny2313.....
Doug
Re: [AVR-Chat] ATTiny2313 vs. AT90S2313
2005-07-26 by Dave VanHorn
Almost certainly.
>forever?
Nope, fuse bits can be reset, IF you have the right programmer.
It is possible to get it into a state where the simple programmers
can't talk to it anymore.
>and it is blown.
Nope, completely eraseable. :)
2005-07-26 by Zack Widup
> >and it is blown.
I have wondered where the term came from.  Is it a holdover from the old
PROM fuses? I still have a couple AMD 27S27's around here somewhere that
actually DO burn out "fuses" in the device when they're programmed.
Zack
