Embedded Creations' SP Duo
2005-07-09 by Brian Dean
I haven't seen anything posted here about this device so I thought I'd
direct folks over to Embedded Creatoins to check out their SP Duo AVR
programmer:
http://www.embedded-creations.com/spduo/overview.htm
I've recently tried one of these out and it is very cool. I use
AVRDUDE of course, but any programmer that supports the STK500 should
work with it. The unique thing about this programmer is that it uses
the STK500 programming protocol, however, it can program using either
the serial ISP method or the JTAG interface. I thought that was
pretty slick.
So you actually get two programmers in one, and two ways to program
which can be convenient if you accidentally change your fuse bits in a
way that locks you out of programming on one interface but not the
other.
Also, it is FAST! About 3x faster than a typical Atmel AVRISP
programmer.
For $50, I think is a good buy. BTW, I am not in any way affiliated
or associated with Embedded Creations - I just like their product.
-Brian
Brian Dean
ATmega128 based MAVRIC controllers
http://www.bdmicro.com/
