AVR-Chat
Another push here... Serial on ATmega128
2005-07-06 by Alex De Lara
Hello,
I read this on other answer and was wondering if fuse setting
>> From: "wbounce" <wbounce@...>
>> Subject: RE: [AVR-Chat] help problem in uart 	wbounce1
>> Send Email Send Email
>> I know you go other responses but garbage on the uart
>> could also mean wrong baud or corrupt fuse settings.
could be part of the reason why I cannot get anything to spit
out of my ATmega128 serial...
I thought that just using the examples from the datasheet
would suffice to program the usart, baudrate and send a
character...
Also, does the baud rate prescaler use the system clock
(internally) by default ?  Is that correct ?
(meaning I should  not have to mess up with the fuses -CKSEL-
currently 0001 - also tried 0100 - both for the internal
calibrated osc).
I just wanted to go plain here and see something coming out....
Actually, have installed 4 leds that I can turn or/off/shift
and they are working fine, at least I can see that stuff
is being executed.
The ATmega103-compatibility-mode-fuse is off, meaning that I
had to use STS to write the UBBRH register.
(i know, i know... without an scope things are nastier than
it should ...  but I use the leds outputs as trace points yikes ! )
-Thanks for reading.
Re: [AVR-Chat] Another push here... Serial on ATmega128
2005-07-06 by Dave VanHorn
>calibrated osc).
A couple of things to be aware of:
You definitely want the CKOPT fuse checked, in the studio programmer.
Otherwise, you have selected "vittoz" mode oscillator, which has low
amplitude, and can cause odd timing results, wrong baud rates, and
all sorts of other grief, unless you know exactly what you are doing,
and pay a LOT of attention to oscillator design.
If you do a reboot in your code, do it through the WDT. Do not push
zeroes and do a return.
I forgot about this little nugget a couple days ago, and was
wondering why my uart wasn't sending anything even though it was set
up correctly.
A hardware reset gets to parts of the chip that you can't get to by software.
Yes, the default prescaler source is the internal CPU clock, which is
the crystal, resonator, or whatever you have selected.
Crystals are accurate enough for serial work. Most resonators are as
well. The internal RC or external RC is not, except under special conditions.
It sounds like you're trying to use the internal RC for serial which
will bring misery, because it will almost work. Or it will work now,
and fail later.
Re: Another push here... Serial on ATmega128
> >calibrated osc).
> has low amplitude, and can cause odd timing results, wrong
I noticed this information on the datasheet as I wasn't really
willing to make any changes on this. So CKOPT is ON.
So far, I'm just using the "push-button" to force the
hard reset. For all God's hardware designs, it should do ;-)
> Do not push  zeroes and do a return.
Though this is a cute trick, I never used it before
(maybe because I could use PCHL on 8085 or EX PC, HL on Z80 grin :-)
> it was set up correctly.
> to by software.
Absolutely. And the WDT is excellent for this purpose.
(Well.. that's what is in there for)
> which is the crystal, resonator, or whatever you have selected.
I did not try to select anything special, other than the xtal,
after all, it's already there and I never had any problem in
the past using crystals.
> are as well. The internal RC or external RC is not, except
I'll take note of this. Thanks.
> serial which will bring misery, because it will almost work.
I'm already feeling miserable !
Shoot !!! Just checked the CKSEL table on the datasheet
and 0100 - 0001 does actually select "Calibrated internal
RC oscilattor"
Hmm... after a few paragraphs it actually says it ships
with 0001 (the internal rc thing) where I though the default
would be the crystal.
I will test the new settings (1111) tonite. Thanks for the hint !
So, basically just checking
1) Setting CKOPT on
2) Setting CKSEL 1111
3) Programming the baud rate
4) Enabling TX/RX
Should get it (finally and hopefulle) going....
Thanks for the pointers. It's always very interesting and
entertaining to hear for others.
-Alex
Re: [AVR-Chat] Re: Another push here... Serial on ATmega128
>RC oscilattor"
If so, you'd have to have a crystal attached to program it.
They have their reasons.
Beware though, the osc they select is relatively slow, so setting too
fast a programming clock will cause errors.
250kHz or slower for new devices, 2 MHz for an 8 MHz system, once
it's up and running at speed.
That's what we're here for. Helping each other find the potholes,
mostly by yelling when we fall in one :)
2005-07-07 by Kathy Quinlan
> 1) Setting CKOPT on
> 4) Enabling TX/RX
If not, check and change the Mega103 compat mode, I had a new Mega64
from the factory last week, and I had to untick the M103 fuse to get the
serial working (I think I was using Serial Port 1)
Kat.
