This assembly oughta be something silly...
2005-06-14 by Alex De Lara
Ok, this must be something idiotic that I cannot figure out.
The Z register is being properly loaded with the correct
address of the string, but the string's bytes are never
loaded in r16.
Why it always gets 0xff ? Obviously it is reading from
somewhere else :-)
What's the trick ?
.include "m162def.inc" ; includes the 162 definitions file
.cseg
.org 0x0000
rjmp INIT ; this is a very silly program
INIT:
ldi r16,LOW(RAMEND) ; Initiatize Stackpointer
out SPL,r16 ; Needed otherwise returns from
ldi r16,HIGH(RAMEND) ; calls go to 0000h
out SPH,r16 ;
;; rcall USART_init ; will implement later.
String_out: ; load begin of string in Z
ldi ZH,high(Test_str) ; Load Z register high
ldi ZL,low(Test_str) ; Load Z register low
loop1: ; come back here till done
ld r16,Z+ ; get byte and incr ptr
cpi r16,0 ; found the end ?
breq String_out ; restart the loop
char_spit:
;; rcall USART_spit ; will implement later
rjmp loop1 ;
.dseg
Test_str:
.db "The old brown fox jumps over the lazy dog."
.db 0x0d, 0x0a, 0
