AVR-Chat
codevision problems
codevision problems
2005-06-06 by mirekwind
does anyone know why codevision refuses to create COF file even if such
format is selected in project setup? Also "Errors occured during
assembly" is displayed but .asm file is created without errors.
thanks for any feedback
Challenge
2005-06-07 by Dave VanHorn
Speed contest: 	 Fast code desired, space is no object.
Task: 			Make UP look like Down by rotating all the bits in a byte.
Input in TEMP, output in TEMP2 or for bonus points, in TEMP, such that
Input: 	7,6,5,4,3,2,1,0      10101110 or AE
Routine happens, then
Output: 0,1,2,3,4,5,6,7    01110101 or 75
The obvious solution is to clear the output and set the bits with
SBRC like this:
;Bit swap end for end.
Untwist:
	push	TEMP2			;
	clr	TEMP2			;
	sbrc	TEMP,0		;
	sbr	TEMP2,1<<7		;
	sbrc	TEMP,1		;
	sbr	TEMP2,1<<6		;
	sbrc	TEMP,2		;
	sbr	TEMP2,1<<5		;
	sbrc	TEMP,3		;
	sbr	TEMP2,1<<4		;
	sbrc	TEMP,4		;
	sbr	TEMP2,1<<3		;
	sbrc	TEMP,5		;
	sbr	TEMP2,1<<2		;
	sbrc	TEMP,6		;
	sbr	TEMP2,1<<1		;
	sbrc	TEMP,7		;
	sbr	TEMP2,1<<0		;
	mov	TEMP,TEMP2		;
	pop	TEMP2
	ret				;
Re: [AVR-Chat] Challenge
2005-06-07 by Richard Reeves
Look-up table:
fred:
	ldi	zl,	low(reverse*2)
	ldi	zh,	high(reverse*2)
	add	zl,	temp
	lpm	temp,z
	ret
.org	$xx00
reverse:	.db		<insert 256 byte table>
I think that's six cycles if it's not a subroutine.
Richard
"Iz dana u dan ona dolazi i odlazi u talasima"
   http://www.van-gogh.co.yu/
2005-06-07 by James Hatley
Hi Dave,
How about ROL TEMP then ROR TEMP2 etc. enough to move number.
Jim
To: <AVR-Chat@yahoogroups.com>
Sent: Tuesday, June 07, 2005 1:35 PM
Subject: [AVR-Chat] Challenge
> SBRC like this:
> Untwist:
> push TEMP2 ;
> clr TEMP2 ;
> sbrc TEMP,0 ;
> sbr TEMP2,1<<7 ;
> sbrc TEMP,1 ;
> sbr TEMP2,1<<6 ;
> sbrc TEMP,2 ;
> sbr TEMP2,1<<5 ;
> sbrc TEMP,3 ;
> sbr TEMP2,1<<4 ;
> sbrc TEMP,4 ;
> sbr TEMP2,1<<3 ;
> sbrc TEMP,5 ;
> sbr TEMP2,1<<2 ;
> sbrc TEMP,6 ;
> sbr TEMP2,1<<1 ;
> sbrc TEMP,7 ;
> sbr TEMP2,1<<0 ;
> mov TEMP,TEMP2 ;
> pop TEMP2
> ret ;
2005-06-07 by erikc
James Hatley wrote:
> Hi Dave,
> Jim
Use TEMP to index into an array, result either to TEMP or TEMP2.  After
all, space is no object.
erikc
2005-06-07 by Richard Austin
> SBRC like this:
> Untwist:
> 	push	TEMP2			;
> 	clr	TEMP2			;
> 	sbrc	TEMP,0		;
> 	sbr	TEMP2,1<<7		;
> 	sbrc	TEMP,1		;
> 	sbr	TEMP2,1<<6		;
> 	sbrc	TEMP,2		;
> 	sbr	TEMP2,1<<5		;
> 	sbrc	TEMP,3		;
> 	sbr	TEMP2,1<<4		;
> 	sbrc	TEMP,4		;
> 	sbr	TEMP2,1<<3		;
> 	sbrc	TEMP,5		;
> 	sbr	TEMP2,1<<2		;
> 	sbrc	TEMP,6		;
> 	sbr	TEMP2,1<<1		;
> 	sbrc	TEMP,7		;
> 	sbr	TEMP2,1<<0		;
> 	mov	TEMP,TEMP2		;
> 	pop	TEMP2
> 	ret				;
Solution 1
Cross wire port A to Port B (or any other port combination. Output byte
on one port and read back on another.
Solution 2
Use a look up table and index the answer by the question byte. 256 bytes
+ the load register with answer.
Don't think you can can quicker than these.
>Look-up table:
>fred:
>         add     zl,     temp
>         lpm     temp,z
>         ret
We have to add another instruction, unless as you specified, the
table is positioned on a boundary.
That wasn't completely clear, but it does get there.
>Solution 1
I like it!  :)
Interestingly enough, it's not THAT much faster than the table, but
down here it counts.
I'm pretty sure this table is right.
reverse:    ; 0   1   2   3   4   5   6   7   8   9   A   B   C   D   E   F
                 .db
$00,$80,$40,$C0,$20,$A0,$60,$E0,$10,$90,$50,$D0,$30,$B0,$70,$F0 ;$0X
                 .db
$08,$88,$48,$C8,$28,$A8,$68,$E8,$18,$98,$58,$D8,$38,$B8,$78,$F8 ;$1X
                 .db
$04,$84,$44,$C4,$24,$A4,$64,$E4,$14,$94,$54,$D4,$34,$B4,$74,$F4 ;$2X
                 .db
$0C,$8C,$4C,$CC,$2C,$AC,$6C,$EC,$1C,$9C,$5C,$DC,$3C,$BC,$7C,$FC ;$3X
                 .db
$02,$82,$42,$C2,$22,$A2,$62,$E2,$12,$92,$52,$D2,$32,$B2,$72,$F2 ;$4X
                 .db
$0A,$8A,$4A,$CA,$2A,$AA,$6A,$EA,$1A,$9A,$5A,$DA,$3A,$BA,$7A,$FA ;$5X
                 .db
$06,$86,$46,$C6,$26,$A6,$66,$E6,$16,$96,$56,$D6,$36,$B6,$76,$F6 ;$6X
                 .db
$0E,$8E,$4E,$CE,$2E,$AE,$6E,$EE,$1E,$9E,$5E,$DE,$3E,$BE,$7E,$FE ;$7X
                 .db
$01,$81,$41,$C1,$21,$A1,$61,$E1,$11,$91,$51,$D1,$31,$B1,$71,$F1 ;$8X
                 .db
$09,$89,$49,$C9,$29,$A9,$69,$E9,$19,$99,$59,$D9,$39,$B9,$79,$F9 ;$9X
                 .db
$05,$85,$45,$C5,$25,$A5,$65,$E5,$15,$95,$55,$D5,$35,$B5,$75,$F5 ;$AX
                 .db
$0D,$8D,$4D,$CD,$2D,$AD,$6D,$ED,$1D,$9D,$5D,$DD,$3D,$BD,$7D,$FD ;$BX
                 .db
$03,$83,$43,$C3,$23,$A3,$63,$E3,$13,$93,$53,$D3,$33,$B3,$73,$F3 ;$CX
                 .db
$0B,$8B,$4B,$CB,$2B,$AB,$6B,$EB,$1B,$9B,$5B,$DB,$3B,$BB,$7B,$FB ;$DX
                 .db
$07,$87,$47,$C7,$27,$A7,$67,$E7,$17,$97,$57,$D7,$37,$B7,$77,$F7 ;$EX
                 .db
$0F,$8F,$4F,$CF,$2F,$AF,$6F,$EF,$1F,$9F,$5F,$DF,$3F,$BF,$7F,$FF ;$FX
2005-06-08 by Dave Hylands
And what I often do is write a little C program which I compile on my
PC that I use to generate source code for tables like this (or CRC
lookups etc).
I typically include the C program #if 0'd out in my source file that
uses it as a way of documenting how the table was actually created.
If you don't want to use 256 bytes for the lookup table, you could
also do a pair of (or a single) 16 byte lookup table which flipped 4
bits. Now you have a pretty wide execution time/space tradeoff and you
can picks what's appropriate for your project.
Dave Hylands
Vancouver, BC, Canada
http://www.DaveHylands.com/
2005-06-08 by Dave VanHorn
>lookups etc).
A good idea!
I don't really need it, I was just musing about it.
We have rotate and swap instructions, but not "flip" (or whatever
you'd call it.)
2005-06-08 by Bernd Felsche
> >lookups etc).
> A good idea!
> you'd call it.)
You do... but despite my being able to rake in the millions by
patenting the bleeding obvious in the USA, it's called an
exclusive-or with a 1 for all bits you want to flip. :-)
/"\ Bernd Felsche - Innovative Reckoning, Perth, Western Australia
\ /  ASCII ribbon campaign | I'm a .signature virus!
 X   against HTML mail     | Copy me into your ~/.signature
/ \  and postings          | to help me spread!
2005-06-08 by Jeffrey Engel
Use a table with all the bits "pre-swapped"?
Jeff Engel
> object.
> bits in a byte.
> in TEMP, such that
> the bits with
> SBRC like this:
> Untwist:
> 	push	TEMP2			;
> 	clr	TEMP2			;
> 	sbrc	TEMP,0		;
> 	sbr	TEMP2,1<<7		;
> 	sbrc	TEMP,1		;
> 	sbr	TEMP2,1<<6		;
> 	sbrc	TEMP,2		;
> 	sbr	TEMP2,1<<5		;
> 	sbrc	TEMP,3		;
> 	sbr	TEMP2,1<<4		;
> 	sbrc	TEMP,4		;
> 	sbr	TEMP2,1<<3		;
> 	sbrc	TEMP,5		;
> 	sbr	TEMP2,1<<2		;
> 	sbrc	TEMP,6		;
> 	sbr	TEMP2,1<<1		;
> 	sbrc	TEMP,7		;
> 	sbr	TEMP2,1<<0		;
> 	mov	TEMP,TEMP2		;
> 	pop	TEMP2
> 	ret				;
>     AVR-Chat-unsubscribe@yahoogroups.com
Happiness is - positive intake manifold pressure.
Do You Yahoo!?
http://mail.yahoo.com
2005-06-08 by Peter Gargano
Bernd Felsche wrote:
>>We have rotate and swap instructions, but not "flip" ...
> You do ... it's called an
Arrh, thart be magic and secret information Bernd - not to be
carelessly disseminated to the heathen masses!
P.
2005-06-08 by Paul Maddox
Dave,
you want quick? and space isn't a problem?
use a Look Up Table, and use LPM
simply copy the value from the TEMP register to R30, dump the table location
into R31 (and Left shift it, or just keep a value thats correct to avoid
this step) and the move r0 to Temp2
.EQU    TABLE_LOC =$02
REVERSE:
    LDI        R31,TABLE_LOC
    MOV    R30,TEMP
    LPM
    MOV    TEMP2,R0
.ORG    $0100
REVERSE_TABLE:
.db 0xFF,0xFE,0xFD, etc, etc, etc
not sure the code is 100% correct, but you get the idea.
Paul
Then we have an even shorter variant possible:
>REVERSE:
>     LDI        R31,TABLE_LOC
>     MOV    R30,TEMP
>     LPM TEMP
But, I maybe should have put the table option out as "obvious".
Ok, what if I say "no tables"?
Dave,
what are you? a sadist?
I guess this isn't a 'real world' application, but, more of a question of "I
wonder how you'd do this?"
Paul
At 08:45 AM 6/8/2005, Paul Maddox wrote:
>Dave,
I think I said that :)
Interestingly, with this latest version, we are approaching the
hardware based solution with two instructions and eight wires, as far as speed.
I'm not talking about inversion, I'm talking about reversal, where
the data that was in bit 7 ends up in 0, 6 ends up in 1, and so on,
till 0 ends up in 7.
I just wanted to say, I had to do this before, when a the guy who did the
PCB for a project made a mistake and reversed all the bits on a port and
no-one noticed until the code didn't work properly..
As the board was already assembled and hardwired (SMD) we had to use the
'soft' approach and a LUT was used.
Paul
I had one once where the board maker flipped the layers. He put the
solder layer on the top, and the component layer on the bottom.
Fortunately, DIP chips aren't THAT hard to bend the pins the other way..
Rewiring the keyboard was a bit of a pain.
Excrement Occurs, and it's often up to us to deal with it somehow.
This challenge is proving more interesting than I thought it would, already.
Sorry... If you actually want things that actually work you have to
ask *after* my second coffee in the morning. :-)
Cross-wired ports is an obvious solution for speed. Very hard to
beat in terms of cycles because it's "external microcode".
Re: codevision problems
2005-06-08 by alwelch93021
such
My guess is you have an error in the sources and most likely you have
used an inline assembly instruction.  I had this problem a while back
and you will not see an error in the C compiling but I think you can
find the error in the list file.
If you do not resolve it you can zip up your sources and send to
Codevision and they will reply with an answer as to what the problem
is.
Al Welch
2005-06-08 by Peter Harrison
Paul Maddox wrote:
> Dave,
> Paul
This is indeed a real world application. Some Fast Fourier Transforms
require bit reversal to put all the coefficients back in their rightful
places. There is a fairly classic solution described on this page:
http://netghost.narod.ru/gff/graphics/book/ch06_04.htm
It does not look fast but, as far as I recall, it is. Oh, well, assuming
you want a portable solution in C...
Pete Harrison
2005-06-08 by John Samperi
At 11:49 PM 8/06/2005, you wrote:
>it's called an
Thank goodness....I was awake all night trying to figure out
the above answer....it seems the wires were crossed.....
which is not too bad as a solution..... :-| Heeelp I'm
going crazier....
Regards
John Samperi
                         Ampertronics Pty. Ltd.
   11 Brokenwood Place Baulkham Hills, NSW 2153 AUSTRALIA
          Tel. (02) 9674-6495       Fax (02) 9674-8745
                Email: samperi@ampertronics.com.au
                  Website  http://www.ampertronics.com.au
* Electronic Design   * Custom Products   * Contract Assembly
I2C devantech cmp03 problems.
2005-06-09 by wbounce
I am trying to diagnose a problem I am having with the devantech
compass. I have 3 SRF08 sonars and a cmp03 compass connected to my
MavricII board (M128). Using winavr 3.4.1. I am using a set I2C routines
from Brian Dean's sample programs. I use the same routines to ping the
sonar as I do to read the compass so I am fairly certain they are not
the problem. Because I am pinging all 3 sonars at once, I moved my
reading of the compass to before I do the ping and after I have read the
ranges. I list the compass reading routines bearing16 calls
cmps03_get_word. The ErrorState is consistently being set to -30 which
means a failed start condition. Yet as soon as it returned from
bearing16 it calls the sonar ping which calls the same call but it
succeeds. I have checked the connects to the compass. But after ooking
at the code writing this email up it has to be something other than
that. First 1st thought was bad connection which is usually the problem
when one of the sonars stop working but at least with a sonar it has a
led that flashes when it pings so I can tell it is working. How can I
tell the compass is working? And is there anything in this code that
would cause the I2c to fail?
	tempbearing = bearing16();
	if ( tempbearing > -1)
		CurrentBearing = tempbearing;
	else
		ErrorState = (int8_t)tempbearing;
		printf_P(PSTR("CError %i"),ErrorState);
	printf_P(PSTR("pg "));
    srf08_ping(ALLDEVICES, RANGE_US);      /* initiate a ping, distance
in cm */
int16_t bearing16(void)
  uint16_t d;
  int8_t rc;
printf_P(PSTR("Be "));
  rc = cmps03_get_word(0x60, 2, &d);
  if (rc < 0) {
	ErrorState = rc;
    return (int16_t )rc;
  return d;
int8_t cmps03_get_word(uint8_t device, uint8_t addr, uint16_t * value)
  uint8_t v1, v2;
  /* start condition */
  if (i2c_start(0x08, 0))
    return -30;
  /* address slave device, write */
  if (i2c_sla_rw(device, 0, TW_MT_SLA_ACK, 0))
    return -31;
  /* write register address */
  if (i2c_data_tx(addr, TW_MT_DATA_ACK, 0))
    return -32;
  /* repeated start condition */
  if (i2c_start(0x10, 0))
    return -33;
   /* address slave device, read */
  if (i2c_sla_rw(device, 1, TW_MR_SLA_ACK, 0))
    return -34;
  /* read data byte 1 */
  if (i2c_data_rx(&v1, I2C_ACK, TW_MR_DATA_ACK, 0))
    return -35;
  /* read data byte 2 */
  if (i2c_data_rx(&v2, I2C_NACK, TW_MR_DATA_NACK, 0))
    return -36;
  if (i2c_stop())
    return -37;
  *value = (v1 << 8) | v2 ;
  return 0;
int8_t srf08_ping(uint8_t device, uint8_t cmd)
    return -1;
    return -2;
  /* write address */
  if (i2c_data_tx(0x00, TW_MT_DATA_ACK, 0))
    return -3;
  /* write command */
  if (i2c_data_tx(cmd, TW_MT_DATA_ACK, 0))
    return -4;
  if (i2c_stop())
    return -5;
  return 0;
2005-06-09 by mirekwind
Al,
moving codevision to c:\cvavr fixes the problems. The path cannot have
embedded spaces. Installing it to c:\Program Files\cvavr on Windows XP
causes this problem as "Program Files" contains embedded space.
> such
> is.
> Al Welch
Re: Challenge
2005-06-09 by Joel Kolstad
--- In AVR-Chat@yahoogroups.com, Peter Harrison <peter_harrison@n...>
It appears to require 6 shifts, six ANDs, and 5 ORs... seems unlikely
it would be faster than the "straightforward" implementation?  It looks
like a case of someone trying to be clever after they learned why a
quicksort is better than something like a bubble sort (what he does is
swap bits 0/1, 2/3, 4/5, 6/7... then 0-1/2-3, 4-5/6-7, and finally 0-
3/4-7).  The problem is that with only 8 bits there's not any speedup
yet that I can see -- just as smart general purpose sorting routines
will revert to something like a bubble sort of lists of less than, say,
10 items!
---Joel Kolstad
Re: [AVR-Chat] Re: Challenge
2005-06-09 by Dave VanHorn
>10 items!
Unless someone pops up from left field here with a new solution, I'm
going to say that we have a couple of nice solutions now, and call
this one "done".
The table lookup is, somewhat surprisingly efficient, other than on
code space, especially when the table can be located on an even page.
Interestingly enough, I think it executes in the equivalent of one
instruction on the PIC.  VBG!
The external loopback is fun, if you have the pins available.
That's the point of challenges like this, to encourage "out of the
box" thinking and explore ideas.
So, anyone want to propose a new little problem?
2005-06-09 by Ralph Hilton
>>10 items!
>this one "done".
This one is known but can prove a puzzler if one doesn't know it.
How do you swap the contents of 2 registers without using any other registers or
stack?
Ralph Hilton
http://www.ralphhilton.org
C-Meter: http://www.cmeter.org
FZAOINT http://www.fzaoint.net
>registers or
>stack?
Hmm.  This one makes my head spin :)
2005-06-09 by James Hatley
Roll through carry.
Jim
Sent: Thursday, June 09, 2005 9:35 AM
Subject: Re: [AVR-Chat] Re: Challenge
> >>10 items!
> >this one "done".
registers or
> stack?
> Ralph Hilton
On Thu, 9 Jun 2005 09:50:38 -0700 you wrote:
>Roll through carry.
>Jim
ok. I should have said using no other storage, flags included.
>----- Original Message -----
>From: "Ralph Hilton" <ralph@ralphhilton.org>
>> >>10 items!
>> >this one "done".
>registers or
>> stack?
Ralph Hilton
2005-06-09 by Mark Jordan
> registers or stack?
	Using Carry?  (ROR or ROL 8 times)
>> registers or stack?
Without carry < 8 instructions :-)
Ralph Hilton
2005-06-09 by Zack Widup
I could argue that you're using another register for that!  :-)
(I have used that on rare occasions though).
Zack
On Thu, 9 Jun 2005, James Hatley wrote:
> Roll through carry.
> Jim
> registers or
> > stack?
> > Ralph Hilton
2005-06-09 by wg0z@aol.com
A = A XOR B
B = B XOR A
A = A XOR B
To: AVR-Chat@yahoogroups.com
Sent: Thu, 9 Jun 2005 12:45:19 -0500 (CDT)
Zack
> Roll through carry.
> Jim
> registers or
> > stack?
> > Ralph Hilton
Yahoo! Groups Links
Re: I2C devantech cmp03 problems.
2005-06-09 by arhodes19044
I have not checked your code yet, but.....
Pinging all 3 sonars at the same time?  It sounds (pun intended) to
me as if interference will occur between sensors.
If you are not running the sensors at max firing frequency, then it
probably would be best to:
ping Sensor-1
read Sensor-3
after 70 ms from #1, Ping Sensor-2
read Sensor-1
after 70ms from #2, Ping Sensor-3
read Sensor-2
after 70ms from #3, repeat from the top....
you can add a compass reading in there somewhere.
-Tony
routines
not
read the
which
ooking
problem
has a
can I
that
> 	else
distance
> in cm */
>   uint16_t d;
>   int8_t rc;
>   if (rc < 0) {
> 	ErrorState = rc;
>   return d;
value)
>   uint8_t v1, v2;
>     return -30;
>     return -31;
>     return -32;
>     return -33;
>     return -34;
>     return -35;
>     return -36;
>   if (i2c_stop())
>     return -37;
>   return 0;
>     return -1;
>     return -2;
>   /* write address */
>     return -3;
>   /* write command */
>     return -4;
>   if (i2c_stop())
>     return -5;
>   return 0;
On Thu, 09 Jun 2005 14:11:32 -0400  wg0z@aol.com wrote:
>A = A XOR B
>B = B XOR A
>A = A XOR B
You got it. Your turn to post a puzzle :-)
>> registers or
>> > stack?
Ralph Hilton
2005-06-09 by Andreas Stemmer
> registers or
> stack?
How about this one?
A = A + B
B = A - B
A = A - B
but I don't know how to do the second step in assembler...
Another solution:
eor r1, r2
eor r1, r2
eor r1, r2
should work... but I can't prove it
Andreas
Andreas Stemmer <groovingandi@gmx.de>
Andreas Stemmer wrote:
> Another solution:
> eor r1, r2
> eor r1, r2
> eor r1, r2
Arghhh, ten minutes too late and wrong as well
eor r1, r2
eor r2, r1
eor r1, r2
of course!
Good Job! Jeff ... wg0z ... I wouldn't have thought of that.
Jim  ( k7tt )
Sent: Thursday, June 09, 2005 11:11 AM
A = A XOR B
B = B XOR A
A = A XOR B
Zack
> Roll through carry.
> Jim
> registers or
> > stack?
> > Ralph Hilton
Yahoo! Groups Links
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/AVR-Chat/
Indeed!
I don't see a lot of this sort of thing anymore, here, or on the piclist.
Used to be, several years ago..
Thing is, now we need to collect these useful bits somewhere, so they
don't get lost.
2005-06-09 by Alexandre Guimaraes
I completely agree with you..... How to organize it ?? Where to put it
?? It is a real shame to have this kind of knowledge being lost with time !!
New programmers do not even now how to mask flags in bits !! What about a
sister list in Yahoo to keep just the "knowledge bits" ??
Best regards,
Alexandre Guimaraes
To: <AVR-Chat@yahoogroups.com>; <AVR-Chat@yahoogroups.com>
Sent: Thursday, June 09, 2005 3:41 PM
> Indeed!
> don't get lost.
When you learn assembler for a particular device I've always likened it to
"learning how to think like that device".  Each one has little tricks you
can use to shorten or speed up a program.  They are all different.  I
remember tricks I used with a Z-80 that don't work on a PIC or AVR (or
don't need to because the architecture is so different).
Zack
> Best regards,
> Alexandre Guimaraes
2005-06-09 by Peter Harrison
> Indeed!
OK - how about another classic problem. Again, fine when you know but
worth looking for a solution. Efficient code for counting the ones in an
8 or 16 bit value - say for a majority vote or some such.
Pete Harrison
Ah, bit count, like for parity.
I've hit that before.
2005-06-10 by Kathy Quinlan
> Best regards,
> Alexandre Guimaraes
We have space here on Yahoo, or I can make space available on my server :)
Kat.
2005-06-10 by Peter Gargano
Atmel, or someone closely associated with them (AVR freaks???) should
be the people someone asks for space.
Don't underestimate the works required to get any information into a
coherent and useful format.
I don't spend enough time programming AVR at the moment to know what
existing resources are available, but I suggest augmenting an existing
info repository rather than a new web site/page.  Has anyone checked
that the basis of what's being proposed doesn't already exist?
Is there an AVR-web-ring?
JM$02
P.
> JM$02
> P.
Yes there is an AVR web-ring, and I am a member, as are a fair few
people on this list.
I know exactly what it takes to get data ready for online use, as I run
my own servers, and webhost for a few clients ( mainly non profit orgs)
Kat.
2005-06-10 by Paul Maddox
All,
if someone is willing to spend the time, I'm happy to provide space and a
subdomain of my server (Www.Synth.Net), I don't have the time to do the
webpage and update it, but I can supply the space/bandwidth.
Paul
2005-06-10 by erikc
Paul Maddox wrote:
> All,
> Paul
I'd like to contribute this bit of code, even though it is not mine.
I got it from here
http://www.dattalo.com/technical/software/pic/debounce.html
   a couple of years ago and have used it ever since:
It is an algorithm for debouncing all the inputs on a port
simultaneously.  No loops or branches, just inline code.  The routine is
expected to be called periodically, as by a timer interrupt.
Although the original code is for the PIC, there is an explanation of
the logic written in C which I repeat here with some small changes for
clarity.
static unsigned            // global variables
	clock_A,           // counter LSB
	clock_B,           // counter MSB
         temp,              // temporary location
         delta;             // temporary variable
	debounced_state;   // the result you will read
void debounce(unsigned new_sample)
               // new_sample read from port once per call
   delta = new_sample ^ debounced_state; //Find all of the changes
   clock_A ^= clock_B;    //Increment the counters
   clock_B  = ~clock_B;
   clock_A &= delta;      //Reset the counters if no changes
   clock_B &= delta;      //were detected.
   temp = (clock_A | clock_B);
   debounced_state = temp;
   //debounced_state &= (clock_A | clock_B);
       //Preserve the state of those bits that are being filtered
       // and simultaneously
       //clear the states of those bits that are already filtered.
   debounced_state |= (~temp & new_sample)
   //debounced_state |= (~(clock_A | clock_B) & new_sample);
       //Re-write the bits that are already filtered.
All I can say is that whoever originally came up with this little gem
has to be some kind of genius.
erikc
RE: [AVR-Chat] Re: I2C devantech cmp03 problems.
2005-06-11 by wbounce
Thanks for the reply.
As far as pinging all sonars I did that my other bot with 5 sonars with
no problem. Then I would read them one after the other with no problem.
I had to do that because the I2C bus was inaccessible during the ping.
The sonar docs says
"the SRF08 will not respond to any I2C activity whilst ranging.
Therefore if you try to read from the SRF08 you will get 355 while
ranging because the I2C data line is pulled high if nothing is driving
it. And as soon as the ranging the SRF08 will respond."
I tried to fire them 1 after another and the 1st one would ping
correctly but then the rest would return invalid address.
Therefore I could not have done your ping sensor1 and read sensor3.
I have decided to 1st find out if the compass will work by itself with
nothing else ie no motor, sonars, gps, or wheel encoders. Just read the
compass and display the value. If that works I will add each piece back
in. If that doesn't then the compass is bad.
From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] On
Behalf Of arhodes19044
Sent: Thursday, June 09, 2005 4:15 PM
Subject: [AVR-Chat] Re: I2C devantech cmp03 problems.
ping Sensor-1
read Sensor-3
read Sensor-1
read Sensor-2
-Tony
routines
not
read the
which
ooking
problem
has a
can I
that
> 	else
distance
> in cm */
>   uint16_t d;
>   int8_t rc;
>   if (rc < 0) {
> 	ErrorState = rc;
>   return d;
value)
>   uint8_t v1, v2;
>     return -30;
>     return -31;
>     return -32;
>     return -33;
>     return -34;
>     return -35;
>     return -36;
>   if (i2c_stop())
>     return -37;
>   return 0;
>     return -1;
>     return -2;
>   /* write address */
>     return -3;
>   /* write command */
>     return -4;
>   if (i2c_stop())
>     return -5;
>   return 0;
Yahoo! Groups Links
The compass checks out ok. It works fine alone. As soon as I let it run
through the ping and range code the compass code throws errors. Need to
check each part (ping and read the range) separately to see which is
causing the problem. But that will have to be tomorrow. I am getting
bleary eyed.
Behalf Of wbounce
Sent: Friday, June 10, 2005 11:32 PM
Subject: RE: [AVR-Chat] Re: I2C devantech cmp03 problems.
The sonar docs says
ping Sensor-1
read Sensor-3
read Sensor-1
read Sensor-2
-Tony
routines
not
read the
which
ooking
problem
has a
can I
that
> 	else
distance
> in cm */
>   uint16_t d;
>   int8_t rc;
>   if (rc < 0) {
> 	ErrorState = rc;
>   return d;
value)
>   uint8_t v1, v2;
>     return -30;
>     return -31;
>     return -32;
>     return -33;
>     return -34;
>     return -35;
>     return -36;
>   if (i2c_stop())
>     return -37;
>   return 0;
>     return -1;
>     return -2;
>   /* write address */
>     return -3;
>   /* write command */
>     return -4;
>   if (i2c_stop())
>     return -5;
>   return 0;
Yahoo! Groups Links
Yahoo! Groups Links
2005-06-16 by Dave VanHorn
> >REVERSE:
> >     LDI        R31,TABLE_LOC
> >     MOV    R30,TEMP
> >     LPM TEMP
Guess what...
Isn't it obvious that this DOES NOT WORK?
Z needs to be loaded with the address *2, so we actually end up with:
mov     ZL,TEMP
ldi     ZH,high(table)
lsl     ZL
rol     ZH
lpm     TEMP
And this does not take into account that the table might be located
high enough to require the ELPM instruction!
So can the real answer be simplified?
2005-06-16 by Paul Maddox
Dave,
>> >REVERSE:
>> >     LDI        R31,TABLE_LOC
>> >     MOV    R30,TEMP
>> >     LPM TEMP
> Guess what...
It works in my code and as I said in the mail...
the table needs to be on a page boundry and that TABLE_LOC should be double
the value of its location.
Assuming the table doesn't move, we don't need to claculate it each time,
and assumign speed was an issue and memory was no object (as originally
stated) then the table could be placed on a page boundry.
for example if the table is at 0x0200, use .EQU TABLE_LOC = $04
Paul
At 03:20 AM 6/16/2005, Paul Maddox wrote:
>Dave,
> >> >REVERSE:
> >> >     LDI        R31,TABLE_LOC
> >> >     MOV    R30,TEMP
> >> >     LPM TEMP
> > Guess what...
Fine, so ldi R31,high(Table_Loc*2) as above, but what about the low byte?
If the low byte has the MSB set on entry, then that needs to get into
the LSB of the high byte, no?
Worse, if you're in a M128 and putting the table near the end of the
code space, because the MSB of the high byte needs to be put in bit 0
of the RAMPZ register for the ELPM instruction.
Dave,
Not for me, at least not on the MEGA32 I'm running it on.
It seems to run fine
yeah, fair point, but as most of the AVRs don't have 128K of memory it
shouldn't be an issue.
Paul
At 09:37 AM 6/16/2005, Paul Maddox wrote:
>Dave,
Thinking about that again, I understand why it works now, the high
byte needs to position the table on the low page, IOW XXXXXXXX0
Then we get a 256 byte table from XX00 to XXFF, where XX is XXXXXXX0
in binary.
I was thinking that it was a 256 WORD table, which it isn't.
So, the added proviso that it has to reside in the bottom 64k to work
with the simple instruction set.
If not, and you try to make it freely relocatable, you end up with a
lot more cycles.
Dave,
ahh, fair point then.
well, the dvice wasn't stated..
given the fact that the preffered soloution was some hard wired soloution,
also implies that the device wasn't already soldered into a PCB and insdie
an existing product.
> lot more cycles.
as I say, code space wasn't an issue, in which case, all I'd say is that the
table *MUST* reside in the lower 64K :-)
Perhaps a good example of why poorly defined problems lead to confusing
results :-)
Paul
At 09:59 AM 6/16/2005, Paul Maddox wrote:
>Dave,
I wouldn't say that was the preferred solution, but just the fastest one.
>confusing results :-)
Well, we just need to understand the limitations and compromises of
these tricky approaches to problems.
