Re: [AVR-Chat] Re: Oh, I am so tired of this..
2005-04-07 by Don Ingram
Got me on that one Kat! Deeply envious of your proximity to the Swan Valley& Margaret River. About all they grow up this way is ants & mosquitos. Cheers Don __________________________________ Yahoo! Messenger Show us what our next emoticon should look like. Join the fun. http://www.advision.webevents.yahoo.com/emoticontest
2005-04-07 by alwelch93021
The problem for me is that I have no clue as to what the solution is. Is there some problem with the way I designed my board for the ISP6pin and the JTAG signals. I doublt it as I changed nothing since the last prototyp in that area AND the last pcb had that day last week where it worked after not working for hours in terms of the tools! The deal yesterday where JTAG indiated it downloaded the program.. showed the progress bar move along and then spin away with the auto program status and never stopped at entry point. That makes me think the problem is in the tools and no where else. I really need to get my program loaded and move on but have no qlue as to what to do other than stare at it some more today. Al --- In AVR-Chat@yahoogroups.com, Don Ingram <don@l...> wrote:
> Got me on that one Kat! Deeply envious of your > proximity to the Swan Valley& Margaret River. About > all they grow up this way is ants & mosquitos. > > Cheers > > Don > > > > __________________________________ > Yahoo! Messenger > Show us what our next emoticon should look like. Join the fun. > http://www.advision.webevents.yahoo.com/emoticontest
2005-04-07 by Larry Barello
Have you checked that your JTAG clock is < 1/4 your system clock? Is your system clock working properly? Are you sure? Can you use the AVRISP/STK500 to check?
-----Original Message----- From: alwelch93021 The problem for me is that I have no clue as to what the solution is. Is there some problem with the way I designed my board for the ISP6pin and the JTAG signals. I doublt it as I changed nothing since the last prototyp in that area AND the last pcb had that day last week where it worked after not working for hours in terms of the tools! The deal yesterday where JTAG indiated it downloaded the program.. showed the progress bar move along and then spin away with the auto program status and never stopped at entry point. That makes me think the problem is in the tools and no where else. I really need to get my program loaded and move on but have no qlue as to what to do other than stare at it some more today. Al
I have found my problem (I think) and learned something about the STK500 as well. First of all, the STK500 can not even read back the firmware version unless you have a working target attached. This is strange to me as It leaves you with no way to even test the rs232 comms to the skt500 until you have a fully working target attached! What i found on my new prototype is the EagleCad software routed two traces (sclk and mosi) right over the top of a GND via that was placed to ground some SMD caps on the top side to the ground plane. Thus the sclk and mosi are grounded. Running the DRC error check on the board does not even detect the problem! I plan on emailing the board files to support to ask why it fails to note the traces are laying on top of the GND via! At least the traces are on the bottom side of the board and can be fixed with the exacto knife, etc. BTW I measured the voltages on the STK500 at those electrolytic caps on the MAX202 as suggested by others here and sure enough some had 7 volts and some were way down to just a few volts. I will replace with some 10UFD 25V X5R 1210 parts i have. Al Welch --- In AVR-Chat@yahoogroups.com, "Larry Barello" <yahoo@b...> wrote: > Have you checked that your JTAG clock is < 1/4 your system clock? Is your > system clock working properly? Are you sure? Can you use the AVRISP/STK500 > to check? > > -----Original Message----- > From: alwelch93021 > > > The problem for me is that I have no clue as to what the solution is. > Is there some problem with the way I designed my board for the ISP6pin > and the JTAG signals. I doublt it as I changed nothing since the last > prototyp in that area AND the last pcb had that day last week where it > worked after not working for hours in terms of the tools! The deal > yesterday where JTAG indiated it downloaded the program.. showed the > progress bar move along and then spin away with the auto program > status and never stopped at entry point. That makes me think the > problem is in the tools and no where else. > > I really need to get my program loaded and move on but have no qlue as
> to what to do other than stare at it some more today. > > Al
2005-04-07 by Jesper Hansen
I have no problem in running the STK-500 without a target. It must be something else that is causing your problem. I look forward to hear more about the Eagle problem. I've been using Eagle for about 3 years and made a lot of boards without noticing such a problem. But I layout manually, so I wouldn't route such an error (pounding chest). However, I have been routing too close to vias sometimes, and the DRC always have found that. Perhaps it is something in your DRC check setup ? /Jesper ----- Original Message -----
From: "alwelch93021" <alwelch@axxiomchromatography.com> To: <AVR-Chat@yahoogroups.com> Sent: Thursday, April 07, 2005 8:21 PM Subject: [AVR-Chat] Re: Oh, I am so tired of this.. > > > I have found my problem (I think) and learned something about the > STK500 as well. > > First of all, the STK500 can not even read back the firmware version > unless you have a working target attached. This is strange to me as > It leaves you with no way to even test the rs232 comms to the skt500 > until you have a fully working target attached! > > What i found on my new prototype is the EagleCad software routed two > traces (sclk and mosi) right over the top of a GND via that was > placed to ground some SMD caps on the top side to the ground plane. > Thus the sclk and mosi are grounded. Running the DRC error check on > the board does not even detect the problem! I plan on emailing the > board files to support to ask why it fails to note the traces are > laying on top of the GND via! At least the traces are on the bottom > side of the board and can be fixed with the exacto knife, etc. > > BTW I measured the voltages on the STK500 at those electrolytic caps > on the MAX202 as suggested by others here and sure enough some had 7 > volts and some were way down to just a few volts. I will replace > with some 10UFD 25V X5R 1210 parts i have. > > Al Welch > > --- In AVR-Chat@yahoogroups.com, "Larry Barello" <yahoo@b...> wrote: >> Have you checked that your JTAG clock is < 1/4 your system clock? > Is your >> system clock working properly? Are you sure? Can you use the > AVRISP/STK500 >> to check? >> >> -----Original Message----- >> From: alwelch93021 >> >> >> The problem for me is that I have no clue as to what the solution > is. >> Is there some problem with the way I designed my board for the > ISP6pin >> and the JTAG signals. I doublt it as I changed nothing since the > last >> prototyp in that area AND the last pcb had that day last week > where it >> worked after not working for hours in terms of the tools! The deal >> yesterday where JTAG indiated it downloaded the program.. showed > the >> progress bar move along and then spin away with the auto program >> status and never stopped at entry point. That makes me think the >> problem is in the tools and no where else. >> >> I really need to get my program loaded and move on but have no > qlue as >> to what to do other than stare at it some more today. >> >> Al > > > > > > > Yahoo! Groups Links > > > > > > > >
2005-04-08 by Brian Dean
On Thu, Apr 07, 2005 at 06:21:31PM -0000, alwelch93021 wrote: > First of all, the STK500 can not even read back the firmware version > unless you have a working target attached. This is strange to me as > It leaves you with no way to even test the rs232 comms to the skt500 > until you have a fully working target attached! Mine works fine without a target attached and reports not only its firmware, but also other parameters like target voltage and oscillator speed, among others. -Brian -- Brian Dean BDMICRO - ATmega128 Based MAVRIC Controllers http://www.bdmicro.com/
2005-04-08 by alwelch93021
The DRC stopped at too few errors and that is why it missed the clearance problems. I increased the errors on the misc tab and then it did find the shorts. In fact it found a second one i had not uncovered yet. Al Welch --- In AVR-Chat@yahoogroups.com, "Jesper Hansen" <jesperh@t...> wrote: > I have no problem in running the STK-500 without a target. > It must be something else that is causing your problem. > > I look forward to hear more about the Eagle problem. I've been using > Eagle for about 3 years and made a lot of boards without noticing > such a problem. But I layout manually, so I wouldn't route such an > error (pounding chest). However, I have been routing too close to > vias sometimes, and the DRC always have found that. Perhaps it > is something in your DRC check setup ? > > /Jesper > > > ----- Original Message ----- > From: "alwelch93021" <alwelch@a...> > To: <AVR-Chat@yahoogroups.com> > Sent: Thursday, April 07, 2005 8:21 PM > Subject: [AVR-Chat] Re: Oh, I am so tired of this.. > > > > > > > > I have found my problem (I think) and learned something about the > > STK500 as well. > > > > First of all, the STK500 can not even read back the firmware version > > unless you have a working target attached. This is strange to me as > > It leaves you with no way to even test the rs232 comms to the skt500 > > until you have a fully working target attached! > > > > What i found on my new prototype is the EagleCad software routed two > > traces (sclk and mosi) right over the top of a GND via that was > > placed to ground some SMD caps on the top side to the ground plane. > > Thus the sclk and mosi are grounded. Running the DRC error check on > > the board does not even detect the problem! I plan on emailing the > > board files to support to ask why it fails to note the traces are > > laying on top of the GND via! At least the traces are on the bottom > > side of the board and can be fixed with the exacto knife, etc. > > > > BTW I measured the voltages on the STK500 at those electrolytic caps > > on the MAX202 as suggested by others here and sure enough some had 7 > > volts and some were way down to just a few volts. I will replace > > with some 10UFD 25V X5R 1210 parts i have. > > > > Al Welch > > > > --- In AVR-Chat@yahoogroups.com, "Larry Barello" <yahoo@b...> wrote: > >> Have you checked that your JTAG clock is < 1/4 your system clock? > > Is your > >> system clock working properly? Are you sure? Can you use the > > AVRISP/STK500 > >> to check? > >> > >> -----Original Message----- > >> From: alwelch93021 > >> > >> > >> The problem for me is that I have no clue as to what the solution > > is. > >> Is there some problem with the way I designed my board for the > > ISP6pin > >> and the JTAG signals. I doublt it as I changed nothing since the > > last > >> prototyp in that area AND the last pcb had that day last week > > where it > >> worked after not working for hours in terms of the tools! The deal > >> yesterday where JTAG indiated it downloaded the program.. showed > > the > >> progress bar move along and then spin away with the auto program
> >> status and never stopped at entry point. That makes me think the > >> problem is in the tools and no where else. > >> > >> I really need to get my program loaded and move on but have no > > qlue as > >> to what to do other than stare at it some more today. > >> > >> Al > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > >
