Hi John,
So you see that this circuit may be hard to be
realized or you have another one ? - Actually i feel
confused about the serial progrmming process itself
... the data sheet even didn't mention wheather you
have to use a level shifter or not ...
Ahmad El-Saied
--- John Samperi <samperi@ampertronics.com.au> wrote:
At 03:26 AM 5/03/2005, you wrote:
>was a problem that the connections aren't clear on
the schematic ...
>like the pins CTS, Rx, Tx & RTS/DTR ...
It is rather unclear. The Rx and Tx pins from the
level
shifter chip (Max232) go to the Rx and Tx pins of the
8535.
The RTS ans CTS pins (Hardware handshaking) can just
be
shorted together. For J1 chose the RTS setting. This
should
keep the PC happy and it should work. If you are going
to
the trouble of buiding this programmer on Veroboard
then I
would suggest again to use a similar programmer that
uses
the 2313 because I do some (free) firmware upgrade
from time to
time, even though the firmware should be reassemblable
for the 8535. Vasilis Serasidis has lots of info on
his website
at www.serasids.gr
Regards
John Samperi
Ampertronics Pty. Ltd.
11 Brokenwood Place Baulkham Hills, NSW 2153
AUSTRALIA
Tel. (02) 9674-6495 Fax (02) 9674-8745
Email: samperi@ampertronics.com.au
Website
http://www.ampertronics.com.au
* Electronic Design * Custom Products * Contract
Assembly
Yahoo! Groups Sponsor ADVERTISEMENT
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/AVR-Chat/
AVR-Chat-unsubscribe@yahoogroups.com
Your use of Yahoo! Groups is subject to the Yahoo!
Terms of Service.
Send instant messages to your online friends http://uk.messenger.yahoo.com
