Index last updated: 2026-04-03 20:49 UTC
an200<->AN1x
an200<->AN1x
2005-06-26 by Gary
Has anybody tried the editing software supplied with the an200
on an AN1x?
Re: an200<->AN1x
2005-06-27 by Dan
> on an AN1x?
Well, I know that it will definitely work the other way around; the AN
Expert Editor will work on the AN200 (except for the arpeggio
functions).  I can't think of any advantage to using the AN200 editor
over the AN Expert Editor though (unless you're wanting a plug-in for
XGWorks/Lite).
Re: an200<->AN1x
2005-06-29 by Gary
It was the Mac version of the software I was interested to learn if
it worked or not. There seems to be a lack of that sort of thing for
Apple Computers. Surprised no one has put it into the files
section.
--- In AN1x-list@yahoogroups.com, "Dan" <dxalgorithm18@y...>
an200
> > on an AN1x?
AN
editor
plug-in for
> XGWorks/Lite).
Re: an200<->AN1x
2005-06-30 by Jon
Each of the Editor/Librarians provided by Yamaha for the AN1x has always been supported
under the Mac OS dating back to the original AN1x Visual Editing Package which preceded
the release of An1xEdit. Both AN Expert Editor and AN200 Editor are also supported under
the Mac OS (OS 9 to be specific.)
AN1xEdit works with the AN1x/PLG150AN/AN200 and is cross platform compatible
(thansk to the efforts of Gary Gregson). I've successfully used AN1xEdit under Classic
within OS X 10.3.9 (Panther) using OMS 2.3.8 and an Emagic MT4 USB MIDI Interface to
successfully transfers Voices to/from the AN1x. While AN1xEdit will run under Classic
within Jaguar, it will not work for sysEx transfers unless configure with both OMS and
MIDIbridge9x. I never spent the time and effort to successfully configure MIDIbridge9x
correctly - and it was still in beta release when last I tried - so I can't say whether it works
or not.
AN Expert Editor can be used with the AN1x, as can AN200 Editor, but the resulting Voice
transfers will not be 100% consistent primarily due to difference between parameters in
the Voice architecture. You might also experience difficulties using either of these two
editors with the AN1x as the result of differences between the SysEx header ID's. If you are
interested in learning more regarding the differences between the devices I would direct
your attention to the Help file included with AN1xEdit which contains the specifics. You
might find this useful.
For whatever reasons they see fit, Yamaha has never made AN200 Editor available as a free
download as they have with AN Expert Editor - the differences between the two are mostly
insignificant. As list moderators, we made a conscious decision not to redistribute Yamaha
software and manuals under copyright control out of respect for their policies but also to
protect the interest of this list from any false accusations which would violate the terms of
use as established by Yahoo Groups! - that's why you won't find AN200 Editor in the Files
section of this list.
Hope this helps.
Jon
> section.
> an200
> > > on an AN1x?
> AN
> editor
> plug-in for
> > XGWorks/Lite).
