Thanks alot for the info! I hope this will solve the problem... Maybe I
should try to change the battery aswell while I'm still at it...
>From: Peter Korsten <peterk@...>
>Reply-To: AN1x-list@yahoogroups.com
>Subject: Re: [AN1x] (unknown)
>Date: Sun, 01 May 2005 09:26:28 +0200
>Fredrik H wrote:
> > aeuh.... but how the hell would a factory reset (and how do I do that)
>fix
> > that?! :)
> > You had the same problem?
>I find that, occasionally, especially after periods of non-usage, the
>AN1x starts behaving strangely. And yes, that includes the symptoms that
>you describe. It could be the battery for all I know, since it's never
>been changed.
>You do a factory reset by holding down the '7', '8' and '9' keys whilst
>switching on the unit, and keeping them pressed until you get a screen
>that says something like 'Init blah?'. Choose '9' for a factory reset.
>Then press 'Yes'.
>As mentioned before, make sure you back up all your voices, settings,
>sequences, everything.
>- Peter
Hitta r\ufffdtt p\ufffd n\ufffdtet med MSN S\ufffdk http://search.msn.se/
