Re: Atmoshpheric choir sound - First Post
2005-03-01 by samriccijr@comcast.net
Hi this is my first post to this list. Please excuse my shorthand, but let us see if this can help. I'm using an AN200 and AN Expert Editor to make a pulse width modulated brassy strings. Open AN Expert editor. The key is TAKE YOUR TIME!. Pick a stringy type patch. You might have to turn all the editor knobs to zero out your settings, so be patient. Zero out the peg and lfos: zero out vco1 peg atk 0 decay 0 depth 0 zero out vco2 peg lfo detail as lfo1 does vco1 and vco2/ lfo2 does filter and amp lfo1 speed 0 vco1 0 vco2 0 lfo2 speed 0 vcf 0 vca 0 wf tri both lfo wf as triangle Turn the noisemakers off: turn sync off make fm depth 0 turn off ring and fb osc1 level 12:00 osc2 0 noise 0 make xmod = 0 Zero out the filters set filter to lpf12 set fc at about 12:00 set resonance at 0 set keytrack at 12:00 (0) set feg intensity at 2:00 (0) Make vanilla envelopes feg a 0 d 1200 s 1200 r 1200 aeg volume at 2:00 aeg a 0 d 1200 s1200 r 1200 Turn distortion and effects off Beginning with VCO1: set wf to pulse set pitch to 0 and fine to 0 depth 9:00 PW 9:00 Edge 3:00 turn the pulse width knob pw - listen to animation now assign lfo1 as source set lfo1 wf to triangle turn up lfo1 speed knob to 8:30 - listen to animation - adjust to taste If you hear pitch wobble - set lfo vco1 to zero and listen Go to VCO2 set wf to triangle set pitch to 0 and fine to 0 or +2 set xmod 0 turn volume up to 12:00 - hear it get richer change VCO2 wf to pulse, use depth 3:00 pw 3:00 and edge 12:00 you now have a thinner pulse under lfo1 control, and you also have a fatter pulse under lfo1 control, which equals lots of animation! Now to filter open filter cutoff to 1:00 - keep resonance off set vcf intensity to 3:00 - adjust to taste - sounds a bit brassy increase attack to about 2:00 - get a string attack keep filter release to 12:00 Go to lfo2 set vcf to about 1:00 (11) not very much set wf to triangle and speed to 10:00 -- more animation adjust filter lfo to taste or turn off if too much (lfo1 does vco1 and vco2, lfo2 does vcf and vca, remember...) Go to vca set attack to 12:00 and release to 1:00 SAVE as BrsPwmStg You now have a brassy string. You can make it thinner by reducing pwm depth, pw and edge change vco2 wf back to triangle (reset xmod to zero) turn lfo2 speed to zero change filter to reduce filter cutoff decreasing feg depth adjusting filter attack Have fun -- I might post the patch, but I think it's more fun for you to figure it out yourself. Enjoy, good luck and please feedback, Sam in NJ USA AN200 user
