Index last updated: 2026-04-05 19:03 UTC
battery info...
battery info...
2005-02-09 by Nick Zuccaro
hey there, the battery in my an1x is: CR2450N
Nick
Re: battery info...
2005-02-09 by Jon
Thank you!
I Googled 'CR5782N' and found this:
http://www.zbattery.com/zbattery/cr2450ncu.html
Renata CR2450N 3V Lithium Battery
Rated Capacity: 540mAh
Wide operating temperature range from -30°C to +70°C
Low self discharge of less than 1 % per year at 23°C
Superior leakage resistance
Excellent storage characteristics, up to 10 years storage with minimum deterioration
Part #:
CR2450NCU
Weight:
0.016 lbs
Voltage:
3V
Chemistry:
Lithium
Dimensions:
24.5mm x 5.0mm
Jon
RE: [AN1x] Re: battery info...
2005-02-10 by Ed Edwards
<snip>
Fortunately, this is a very common battery available at Radio Shack and probably
even Walmart or other department stores.
The nice thing is that Yamahahaha will politely warn you a long time before it
dies with a Battery Low message on your Annie.
Ed Edwards
Leader: Ezekiel's Wheel  \ufffd\ufffd\ufffd\ufffdRetro-Progressive Rock\ufffd\ufffd\ufffd\ufffd
http://www.ezekielswheel.com
http://www.untiedmusic.com/ezekiel
http://www.headholemines.blogspot.com
\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd
