Re: AN200 OS upgrade issue
2004-12-09 by Jon
--- In AN1x-list@yahoogroups.com, "Mark Daborn" <darkest.yugo@n...> wrote: > Hi, i was rather intrigued by all the news of a new OS upgrade so i downloaded it and followed the instructions given. > > I think i have some kind of problem! > > The data transfer goes okay as i can see the numbers counting up on the display of the AN200 until, that is, it reaches "4" or thereabouts. At this point it goes to "0" and returns to the "TRNL" display. > > I've tried it with several sequencers and each time it does the same. > > I believe there is an issue concerning the transfer rate during a bulk dump to/from the AN200. Could this have anything to do with it? > > I'm rather hoping to solve this problem because now each time i power it up, i get the "TRNL" screen only!!! Hhmm, doesn't sound good :-/ Have you tried to reset your AN200? 1. Turn the power OFF. 2. Press and hold the [SHOW VALUE], [PATTERN], and [EXIT] buttons on the AN200, then turn ON the power to execute the Factory Reset. This will take about 20 seconds. What type of MIDI Interface are using? The AN series has always been known to have unusually large SysEx file sizes hence the reoccuring posts to AN1x-list indicating trouble with bulk dumps. USB MIDI Interfaces and low cost, MIDI I/O as found on Sound Cards are freqently suspect. A quality, multiport MIDI Interface is a good choice and serial port types are often the most reliable. That said, I would advise 1) see if you can reset your AN200 to a working, default state and 2) retry the bulk dump of the .MID file using a drasticly reduced Tempo in your MIDI Sequencer. Jon
