VCF has no effect on new voice
2004-07-30 by Alien Martian
Hi, I have created a new sequence voice but the VCF when using An1xedit has no effect on the sound.Why is this please? Regards Alien __________________________________ Do you Yahoo!? New and Improved Yahoo! Mail - 100MB free storage! http://promotions.yahoo.com/new_mail
2004-07-31 by Jon
--- In AN1x-list@yahoogroups.com, Alien Martian <alien1x@y...> wrote: > Hi, > > I have created a new sequence voice but the VCF when > using An1xedit has no effect on the sound.Why is this > please? > > Regards > Alien > What is the Filter Cutoff value? Which Filter type are you using? What is the Filter EG Depth value? How exactly are you using AN1xEdit and what effect do expect on the sound? There really not enough info in your question to answer with anything more than speculation... Jon
2004-07-31 by Alien Martian
--- Jon <jondl_2000@...> wrote: > --- In AN1x-list@yahoogroups.com, Alien Martian > <alien1x@y...> wrote: > > Hi, > > > > I have created a new sequence voice but the VCF > when > > using An1xedit has no effect on the sound.Why is > this > > please? > > > > Regards > > Alien > > > > What is the Filter Cutoff value? Which Filter type > are you using? > What is the Filter EG Depth value? How exactly are > you using > AN1xEdit and what effect do expect on the sound? > There really not > enough info in your question to answer with anything > more than > speculation... > > Jon > Hi, The Filter cutoff value is =65 Filter type = LPF12db Filter EG depth Value = 60 What I expect from the sound is to open the filter to let more of the sound through and varie thr frequency. Its strange really, it works on other voices, but not on this one. Regards Alien > > > ------------------------ Yahoo! Groups Sponsor > --------------------~--> > Over 1 billion served! The most music videos on the > web. > Click to Watch now! > http://us.click.yahoo.com/Xkrq7C/IARHAA/n1hLAA/QnLolB/TM > --------------------------------------------------------------------~-> > > > Community email addresses: > Post message: AN1x-list@yahoogroups.com > Subscribe: AN1x-list-subscribe@yahoogroups.com > Unsubscribe: > AN1x-list-unsubscribe@yahoogroups.com > List owner: AN1x-list-owner@yahoogroups.com > > Shortcut URL to this page: > http://groups.yahoo.com/group/AN1x-list > > The AN1x Control Synthesizer FAQ:: > > http://www.geocities.com/jondl_2000/an1x_faq/an1x_faq_toc.htm > > Yahoo! Groups Links > > > AN1x-list-unsubscribe@yahoogroups.com > > > > __________________________________ Do you Yahoo!? Yahoo! Mail - You care about security. So do we. http://promotions.yahoo.com/new_mail
2004-07-31 by Jon
--- In AN1x-list@yahoogroups.com, Alien Martian <alien1x@y...> wrote: > --- Jon <jondl_2000@y...> wrote: > > What is the Filter Cutoff value? Which Filter type > > are you using? > > What is the Filter EG Depth value? How exactly are > > you using > > AN1xEdit and what effect do expect on the sound? > > There really not > > enough info in your question to answer with anything > > more than > > speculation... > > > > Jon > Hi, > The Filter cutoff value is =65 > Filter type = LPF12db > Filter EG depth Value = 60 > > What I expect from the sound is to open the filter to > let more of the sound through and varie thr frequency. > > Its strange really, it works on other voices, but not > on this one. > I suggest you reduce the Filter EG value. Using such a large value for Depth is limiting the range of movement for the Cutoff from a large initial value as 65. Try the following to better understand how the Depth value and Cutoff interact: VCF Cutoff = 0 FEG Depth = 0 -- now sweep the filter cutoff manually from 0-127. You should hear a dramatic change in the FC? VCF Cutoff = 0 FEG Depth = +127 -- now sweep the filter cutoff manually from 0-127, don't here any change do you? Wide open all the time. Now try this: VCF Cutoff = 0 FEG Depth = -127 -- now sweep the filter cutoff manually from 0-127. Just a little bit of change when you hit the peak level for the Cutoff value. Now try the above again but this time adjust the Depth setting between negative and positive values. You'll soon appreciate how the Depth setting affects the shape of the filter ADSR enevelope generator. Jon
Thanks Jon....it works fine,now I understand the concept. Regards Alien --- Jon <jondl_2000@...> wrote: > --- In AN1x-list@yahoogroups.com, Alien Martian > <alien1x@y...> wrote: > > --- Jon <jondl_2000@y...> wrote: > > > What is the Filter Cutoff value? Which Filter > type > > > are you using? > > > What is the Filter EG Depth value? How exactly > are > > > you using > > > AN1xEdit and what effect do expect on the sound? > > > There really not > > > enough info in your question to answer with > anything > > > more than > > > speculation... > > > > > > Jon > > Hi, > > The Filter cutoff value is =65 > > Filter type = LPF12db > > Filter EG depth Value = 60 > > > > What I expect from the sound is to open the filter > to > > let more of the sound through and varie thr > frequency. > > > > Its strange really, it works on other voices, but > not > > on this one. > > > > I suggest you reduce the Filter EG value. Using such > a large value for Depth is limiting > the range of movement for the Cutoff from a large > initial value as 65. Try the > following to better understand how the Depth value > and Cutoff interact: > > VCF Cutoff = 0 > FEG Depth = 0 > -- now sweep the filter cutoff manually from 0-127. > You should hear a dramatic > change in the FC? > > VCF Cutoff = 0 > FEG Depth = +127 > -- now sweep the filter cutoff manually from 0-127, > don't here any change do you? > Wide open all the time. Now try this: > > VCF Cutoff = 0 > FEG Depth = -127 > -- now sweep the filter cutoff manually from 0-127. > Just a little bit of change when > you hit the peak level for the Cutoff value. > > Now try the above again but this time adjust the > Depth setting between negative and > positive values. You'll soon appreciate how the > Depth setting affects the shape of the > filter ADSR enevelope generator. > > Jon > > > > > > ------------------------ Yahoo! Groups Sponsor > --------------------~--> > Check out Music Videos, Internet Radio, Artist > Photos, Music News! > LAUNCH Music on Yahoo! > http://us.click.yahoo.com/Wkrq7C/JARHAA/n1hLAA/QnLolB/TM > --------------------------------------------------------------------~-> > > > Community email addresses: > Post message: AN1x-list@yahoogroups.com > Subscribe: AN1x-list-subscribe@yahoogroups.com > Unsubscribe: > AN1x-list-unsubscribe@yahoogroups.com > List owner: AN1x-list-owner@yahoogroups.com > > Shortcut URL to this page: > http://groups.yahoo.com/group/AN1x-list > > The AN1x Control Synthesizer FAQ:: > > http://www.geocities.com/jondl_2000/an1x_faq/an1x_faq_toc.htm > > Yahoo! Groups Links > > > AN1x-list-unsubscribe@yahoogroups.com > > > > __________________________________ Do you Yahoo!? Yahoo! Mail is new and improved - Check it out! http://promotions.yahoo.com/new_mail
