Broken key [won't spring back up]
2004-07-05 by abovedust
One of the keys [C6] on my AN1x won't spring back up anymore. It
sounds fine when pushed, but just stays down. Is the problem a broken
part of the key, or some internal spring mechanism? Is this an easy
problem to fix? I'd really love to remedy the problem without having
the synth serviced, if possible.
--Robin
Re: Broken key [won't spring back up]
2004-07-09 by eduardosocolovsky
Hi ! I have the same problem ... anyone knows something ?
thanks !
Edu
broken
> --Robin
2004-07-11 by Paul Barbieux
Maybe my experience can help you: after 2 years the keys from C2# to
F#2 (if I remember well) did not answer anymore. 3 times the AN1x
left in repair, and each time the breakdown occured again !
One day, I decided to open the AN1x. Don't worry: the mechanism is
very simple. I think there is no lubrification for the keys. But for
my problem, it was a bad welding. And each time the AN1x was open and
closed, the problem disaperead ! Finally, I asked a technician to
remake the welding, and since then I don't have any more the problem.
In conclusion: don't hesitate to open your AN1x: if you are afraid,
take pictures of each step before unmount the components, and
probably you will find somewhere a mechanical disfunction - there is
a "sensitive ribbon" where the "hammer" comes to type...
--- In AN1x-list@yahoogroups.com, "eduardosocolovsky"
> thanks !
> Edu
> broken
easy
having
> > --Robin
2004-07-12 by abovedust
Many thanks, Paul and Gene! I was a bit hesitant to open the AN1x up,
but I'll try tomorrow, taking pictures of each step. Hopefully it'll
be an easy fix. :)
--Robin
> > thanks !
> > Edu
> > broken
> easy
> having
> > > --Robin
2004-07-12 by Jon
> be an easy fix. :)
> --Robin
There are some photos for your reference inthe Photos directory for AN1x-list here at
Yahoo! Groups Check the directory 'AN!x Surgery'
http://photos.groups.yahoo.com/group/AN1x-list/lst
Jon
Re: Broken key/ AN1x plastic casing
2004-07-18 by abovedust
It turns out that after years of carrying it around, the bottom of the
case has become rather dented and warped. I can't even get some of the
screws off. I've basically given up. :(
Actually, do you think it's possible the order a new plastic casing
for the AN1x? That could possibly work for me, but I doubt Yamaha
would sell one.
--Robin
AN1x-list here at
> Jon
