--- In AN1x-list@yahoogroups.com, "studiotis" <aabb1@p...> wrote:
> I want to use RM1X as a master sequencer with AN200
> and play certain patterns of AN200
> for example, If I would like to start a pattern from measure 17 of
> RM1X, how can I do it?
> for instance pattern : user # 100, starting from measure 17
> what midi controllers should I use, how to program it in RM1X
> Tomek
You might want to post this question to the RM1x list instead of the
AN1x list:
http://groups.yahoo.com/group/rm1x
I'm not familiar with thr RM1x but one solution might be to insert 16
measures of silence on the Song/Pattern on the AN200 that will be
synchronized to the RM1x. As an alternative, I would simply record
the MIDI out from the desired pattern on the AN200 into an empty
Track/Sequence on the RM1x simply to avoide the headache of
synchronizing the two units.
regards,
Jon
