--- In AN1x-list@yahoogroups.com, "marcogardengreen
<marcoyyz@t...>" <marcoyyz@t...> wrote:
> Hallo everybody!
> First of all I would like to thank all the people who answered to
my
> qyestions.
> So kind and so fast!! :-)
> Well, some reply from me.
> Ciao!
> Marco
> >From: "Jon <jondl_2000@y...>" <jondl_2000@y...>
> >Date: Tue Feb 18, 2003 11:37 pm
> >Subject: Re: An200 questions
> >You can download the XP patch for XGWorks from here:
> >http://www.yamahasynth.com/down/main.htm#GeneralTools
> I downloaded it and tonight I will try it.
> >The SysEx ID header for the AN1x is completey different from
that
> >of the AN200. The AN200 will NOT accept the .MID transfer
> >regardless of what application you use to dump from PC ->
> >AN200. As a workaround, I would suggest the following:
> Well... Don't ask me why but it worked.
> I had a .all backup of an1x voices. (Cubase song).
> I played it back and all the voices were loaded on the An200!!!
> ANyway thanks for your proposal to upload my sounds on the
> directory and to let someone to convert it for me.
That's great for you! What's a .all file? I'm not familiar with that.
I'm really surprised the Base Address ID for the AN1x worked for
the AN200 - live and learn.
> >From: "RayMaxer" <digil@d...>
> >Date: Tue Feb 18, 2003 6:44 pm
> >Subject: Re: [AN1x] An200 questions
> >Free EG and Feedback of AN-1x are one of 'jewels' virus
lacks..
> feedback is
> >just one parameter but it allows changing the whole sound of
synth
> often on
> >AN..
> To clarify my question that will follow I would like to say that I'm
> a guitarist
> and An200 is the first sinth I own.
> The question is: what is the plus of having Free EG and
Feedback
> features ?
The FreeEG allows you to record, i.e., automate, paremter
adjustments for playback in real time. For example, you could
record adjustments to parameters such as Fliter Cutoff, VCO
Edge, VCF Attack and VCA Release so that they were saved as
part of the Voice and playback automatically upon a note on
event. Very cool.
The Feedback parameter take the signal output from the
Mixer->Filter->VCA and 'feeds' it back into the signal chain from
the Mixer - therefore creating a 'fatter' sound - good for leads and
basses.
> >I'd advise using An1xEdit for all editing..
> Well... I think that with An1xEdit you can't upload voices from
> An200 to the editor itself. Is it right ? In this case I will have to
> use
> the An200 editor that (I guess) should be able to...
Actually, I think you might be able to if AN1xEdit is in PLG150AN
Mode - found under the Setup menu.
> >It should work fine and covers all the params of your AN200..
> For example it doesn't cover effects...
The PLG150AN and AN200 do not have the same effects
selection as the AN1x - specifically, the VariEF/EQ will default to
Amp Sim.
regards,
Jon
