AN1X Envelope shapes
2003-01-25 by Jerry Aiyathurai <tuskerfort@hotmail.com>
Are the AN1X enveloples linear or non-linear? Is there any difference
between the pitch envelope and the filter envelope in this regard.
Is it my imagination, or is the pitch envelope logarithmic and the
filter envelope linear?
I was doing sync sweeps with envelopes, and I "thought" that when I
engaged the pitch envelope, the sync moved very fast in the early
stages and then started to slow down. But the filter envelope (for
roughly the same decay time and depth (zero attack) seemed to give a
more leisurely, even sweep.
So I tried the envelopes out with pitch sweeps. I dialed in a slow 2
octave pitch sweep with the pitch envelope. It seemed that the 1st
octave of sweep happened much faster than the second. Then I self
oscillated the filter and tried running through about 2 octaves of
pitch (zero attack, decay time corresponding to decay on the pitch
envelope), and it seemed much more even. But I was relying on my
(awful)ears.
I'd love to know what you guys think. Is there a test we can do, that
would allow us to view the shape of the envelope? Or would one of you
try the audio test I described and tell me what you think?
Sorry for the nerdy question. The difference (if any) could be quite
important for the synthesis of plucked and struck sounds,
particularly those with FM or sync where you have a choice of
envelopes.
Thank you,
Jerry
Re: AN1X Envelope shapes
2003-01-28 by Jon <jondl_2000@yahoo.com>
--- In AN1x-list@yahoogroups.com, "Jerry Aiyathurai
difference
regard.
Liner v non-Linear? Couldn't say but..
..bear in mind the AN1x has only a Depth & Decay setting for the
PEG (as opposed to the PLG150AN which has an added Attack
parm.)
The FEG is a full fledged ADSR (attack, decay, sustain, & release
parms.)
when I
early
(for
to give a
See above. The PEG is behaving how you think it is.
A dedicated ADSR (or better) EG for Pitch is not common too
many synth - late model Ensoniq synths had very sophisticated
Tiem and Rate envelopes for Ptich, Amp & FC and I wouldn't be
surprised if the Kurzweils did too. It's been a few years since I've
had hands on time with a KORG and my memory fails me.
slow 2
1st
I self
pitch
on my
> (awful)ears.
that
one of you
quite
> envelopes.
> Thank you,
> Jerry
regards,
Jon
2003-02-01 by Jerry Aiyathurai <tuskerfort@hotmail.com>
Is the decay on the pitch envelope the same shape as the decay on the
filter envelope?
For what it's worth I did a semi-objective test and here are the
results. The envelopes aren't different as far as I can tell with the
tools I have. However pitch sweeping the  the resonant filter with
the filter envelope (subjectively) provides a very different sound
than pitch sweeping a sine wave (Edge=0) through the same pitch in
the same amount of time. This is due partly due to the signal
strength at various frequencies. The filter resonance is strong at
high filters and fades out at the low frequencies, the oscillator is
pretty consistent throughout. For an imitation of a percussive Bwap,
I found the oscillator version more interesting.
So how did I test the envelopes? Well I set up a pitch sweep (sine
wave traversing from 11,835 hertz to 335 hertz in roughly 14 seconds.
For the filter sweep, I obtained a resonant sine wave and then
traversed it from a pitch of 11,811 hertz to 335 hertz in roughly 14
seconds. (Hertz readings were obtained from a frequency analyzer.)
I put the two sweeps side by side in a visual frequency analyzer, and
try as I might I could not prove that the pitch envelope was any
steeper within the precision of the frequency analyzer's graph. Both
sweeps looked relatively exponential.
So my instincts were wrong as far as the instrument can tell. Still,
I learned two things:
- the filter is way louder at higher frequencies.
- the pitch envelope sweep is much more satisfying for short blips
and bwaps. Why? I don't know. So for plucked string sounds I'll be
using the pitch envelope to control sync or fm modulations.
Hope this is of interest to someone.
Jerry
paper jam's vegas
2003-02-01 by nick ring
in preparing to play out with some friends I was loading some new sounds
into my an1x to play around with.  I stumbled upon Paper Jam's "vegas"
patch just now -- definitely loving it!  I was just tripping out for a
while playing just that...very pleasing.
best,
nick
Re: [AN1x] paper jam's vegas
2003-02-01 by John Temprile
Can you upload the one patch to the group?
Jt
 --- nick ring <nick@...> wrote: > in preparing to
> new sounds
> "vegas"
> out for a
> best,
> nick
> Community email addresses:
>   Post message: AN1x-list@yahoogroups.com
>   Subscribe:    AN1x-list-subscribe@yahoogroups.com
>   Unsubscribe:  AN1x-list-unsubscribe@yahoogroups.com
>   List owner:   AN1x-list-owner@yahoogroups.com
> Shortcut URL to this page:
>    http://groups.yahoo.com/group/AN1x-list
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
Do You Yahoo!?
Everything you'll ever need on one web page
from News and Sport to Email and Music Charts
http://uk.my.yahoo.com
>Jt
jt,
         it's in the files section for this group... as part of the
collections that jon gathered of patches made by listmembers.  I believe
it's in the first of the two collections.
best,
nick
><http://groups.yahoo.com/group/AN1x-list>http://groups.yahoo.com/group/AN1x-list
2003-02-01 by Jon <jondl_2000@yahoo.com>
> >Jt
> jt,
I believe
> best,
> nick
om/group/AN1x-list
There are HTML 'read me' docs in the Files section that list the
individual contributions to each archive. Copies of these doc's
are included with the actual archives too.
regards,
Jon
