AN1X
AN1X
2002-08-27 by Rat Batblue
I'm looking to buy an analog modeling synth, but unfortunately do not live
anywhere near a store that has one so I have no opportunity to hear one. The
AN1X seems to be a great buy. I was just wondering if anyone is using one
for rock or prog rock. I've got a Roland Alpha Juno 2 that I've been using
for 15 years, but I'm looking for something with a little bit more
programming horsepower. Basically I need something with some good leads,
ballsy fat sawtooths and sime nice analog strings and pads. Any help would
be appreciated.
Chat with friends online, try MSN Messenger: http://messenger.msn.com
RE: [AN1x] AN1X
2002-08-28 by Luc Fonteyn
Hello Rat Batblue,
Well, the Yamaha AN1X is certainly a great synth that will satisfy your
programming hunger. BTW, there's a FREE editor for this baby and may I
say, the editor by it self is worth AN OSCAR, not in a million years
will I use SoundDiver (which IS good BTW) to program this blue beauty.
IMHO, it is a great virtual analog synth that can do nice basses, pads,
strings, well all the things a good VA should be able to do.
You've already a lot of experience taming your Alpha Juno 2 but you'll
see that the AN1X is a lot easier to program, even for a novice synth
user.
Of course there are a lot of other VA's out there, that have the same
sonic potential (or better) but not many can offer the same sonic
possibilities a the same price. And today, here in Belgium anyway, they
come very cheap second hand. I've seem them changing owners for less
than 250 EUR but usually they go between 250 and 500 EUR. A small price
for a lot of synthesizer pleasure.
You can always listen to the online audio fragments at
www.yamahasynth.com to give you an idea. But if possible you should try
to find a local shop or a AN1X owner in your neighborhood, how a synth
sounds is always a personal opinion and only YOUR ears can tell you how
it sounds to you.
BTW, did you know that the AN1X actually comes in several flavors? You
can choose between the:
AN1X     => keyboard version,
AN200    => desktop version,
PLG150-AN=> plug-in board for an CS6X
You can read all about them at www.yamahasynth.com to see which flavor
would suite you most.
Of course the AN1X is NOT a 'regular' ROM-pler like for example the
JV/XV-series from Roland, those are more for fast access to sounds like
guitars, flutes, organs, harps,... you know, presets (although they
sound very good) and lesser for programming sounds (but is possible
though).
But if you're looking for a synth that will give you those analog (or
emulation) sounds that you're looking for, you could buy a real analog
synth but could also settle for a nicely priced VA like the AN1X which
also weighs a lot less, even compared to other VA's.
The AN1X is definitely worth checking out.
Any negatives to report? Probably but I did not find any yet :),
needless to say that I'm very happy with my AN1X. Perhaps you could soon
be in that same position ?
Greetings, hope you can find one to test drive,
Luc Fonteyn
Sent: dinsdag 27 augustus 2002 18:25
To: AN1x-list@yahoogroups.com
Subject: [AN1x] AN1X
live
The
one
using
would
be appreciated.
Community email addresses:
  Post message: AN1x-list@yahoogroups.com
  Subscribe:    AN1x-list-subscribe@yahoogroups.com
  Unsubscribe:  AN1x-list-unsubscribe@yahoogroups.com
  List owner:   AN1x-list-owner@yahoogroups.com
Shortcut URL to this page:
   http://groups.yahoo.com/group/AN1x-list
Your use of Yahoo! Groups is subject to
Re: [AN1x] AN1X
2002-08-28 by Bruce Wahler
>be appreciated.
I use the AN1x for rock, and it has all of the above and more.  I don't really do prog-rock any more, but I do use a lot of sounds that are reminiscent of Emerson, Moraz, Wakeman, and others.  It does good Moog and Oberheim imitations, while adding flexibility that even a Moog Modular never had.  It's a little more edgy than a real analog, but I tame that with a tube preamp.
-BW
Bruce Wahler
Design Consultant
Ashby Solutions\ufffd   http://consult.ashbysolutions.com
CloneWheel Support Group and HiNote moderator
978.386.7389  voice/fax
bruce@...
Re: AN1X
2002-09-01 by tuskermusic
Like Bruce, I use it in a rock context. Big leads, all the usual
string and heavy pads, etc. It has a fairly elaborate modulation
routing so you can emulate a number of the tricks on various antique
instruments.  It does moogs pretty well, surprisingly. Particularly
big brassy lead tones like Wakeman and Emerson. For example, the
minimoog's resonance is less at lower cutoff levels (lower notes if
your cutoff tracks the keyboard). On the AN1X you can emulate that
particular filter characteristic to get the closed "bite" on the high
notes and the open buzz on the low notes which is part of that moogy
flavor.
It's not as big sounding and liquid as something like the Andromeda,
but it does have a wide range of tones. And it's definitely more
powerful sounding in the lead department than any rompler I have
played.
Hope this helps,
Jerry
