Midi playback problem
2001-10-29 by kgilani@earthlink.net
On my AN1x,  I can't playback complex midi Arps or sequences on one track of
my software sequencer properly.
Does this have to do with lack of multitimbrality of AN1x?
I do can record and playback simpler pads etc !
Any idea guys
Thanx
Kamy
Re: [AN1x-list] Midi playback problem
2001-10-29 by Bastiaan van de Werk
I think you mean polyphony here...try turning off unison to up your poly. You should be able to play 5 notes at the same time on one track at any time.
I put Mode to poly and layer to single. T-channel to 3, receive-channel to
1. And in logic put as track channel 1. I also tried all different channel
setting.
But still, the playback comes kinda out of sync.
Any idea?
You mean it's stuttering/not tight? That's your sequencer, your midi-interface or your cabling...most likely...if your arp is on it can be that you should set tempo to midi...
Re: Midi playback problem
2001-10-29 by Jon
> setting.
> Any idea?
From your problem description I believe you are trying to record the
MIDI notes transmitted from the AN1x Arp/Seq into Logic and then have
Logic playback those notes - triggering the AN1x. I'm guessing that the
Arp/Seq for the AN1x Voice is still set to 'ON' when Logic begins
playback of the Arp pattern previously recorded and what you are
experiencing is double note events being triggered from both Logic and
the internal Arp/Seq of the AN1x. I'd suggest you turn Arp/Seq 'OFF'
for the AN1x and resave the selected voice before beginning playback of
the recorded track from Logic.
As an alternative to recording the output of the AN1x Arp/Seq into
Logic, you could simply sync the AN1x Arp/Seq to MIDI Clock transmitted
by Logic and simply record the root notes into Logic (not the output
from tha Arp/Seq) and allow the AN1x Arp/Seq to trigger off playback
from Logic. Make sense? The obvious limitation of this approach being
that you can't easily rechannel the Arp/Seq data to another sound
module as you could by recording the Arp/Seq output into Logic. Give
and take.
regards,
Jon
Re: [AN1x-list] Re: Midi playback problem
2001-10-30 by kgilani@earthlink.net
>> setting.
>> Any idea?
Thanks to Jon and Basstian
It's now working
