Seq Edit
Seq Edit
2001-06-24 by DMANX@talk21.com
In anxedit,i know how to edit the preset step sequences,by going into edit sequence tab.But how do i create and save my  own sequences,or do i pick on a exg voice an edit it?
Regards DMANX
talk21 your FREE portable and private address on the net at http://www.talk21.com
RE: [AN1x-list] Seq Edit
2001-06-25 by Gary Gregson
Hi Dmax,
There are two areas where sequences are stored by the AN machines.
1) Voice Sequence: Each patch provides storage for a single sequence.
This sequence is used when the SEQ SELECT mode is set to NORMAL or
NSHIFT+NORM.
2) User Sequences: there are 128 program memories for storing user
sequences. These can be used when the SEQ SELECT mode is set to
PSEL+xxx. This allows you to have multiple sequences applied to a voice
if desired.
You can edit both types of sequences using An1xEdit. Selection of which
type is done via the VOICE and USER buttons of the SEQUENCE editor. When
in voice mode the sequence being edited will always be that of the
current edit voice.
When in USER mode the sequence will be the last user sequence selected
from the library. To select the user sequence program, go to the library
page and click the USER SEQUENCE button. Then choose the program you
want to edit from the main list.
When you have finished editing a user sequence, don't forget to save it
back to the library in the same way as you would a voice patch (i.e. go
to the library, select the USER SEQUENCE button and use the STORE
CURRENT button).
OF course Voice sequences are stored back to library when you store the
corresponding voice to the library.
You can download the user sequences to the AN device in the same way
that you would download voices (except of course you do it from the USER
SEQUENCE view of the library). Alternatively you can download both
voices and sequences if you use the library SELECT ALL button before
hitting SEND.
Regards
Gary Gregson
Email:gary@...
http://www.yme.co.uk/yme
Sent: 24 June 2001 22:48
To: AN1x-list@yahoogroups.com
Subject: [AN1x-list] Seq Edit
Regards DMANX
Community email addresses:
  Post message: AN1x-list@yahoogroups.com
  Subscribe:    AN1x-list-subscribe@yahoogroups.com
  Unsubscribe:  AN1x-list-unsubscribe@yahoogroups.com
  List owner:   AN1x-list-owner@yahoogroups.com
Shortcut URL to this page:
   http://groups.yahoo.com/group/AN1x-list
Your use of Yahoo! Groups is subject to
