I'd just like to point out that at no time did I say that you couldn't
convert the second scene, I did mention that no software out there that
will Convert the second Scene info. I feel I should clarify what I
meant by this, there is no software out there that will automatically
convert them, AN-edit of course allows you to edit the second scene, and
it allows copying of the 2nd scene and pasting it to a new patch as 1st
scene, but on 128 possible patches it can be quite a drawn out process.
In article <000401c0ef3d$2abfa4a0$0200a8c0@bigpc>, Gary Gregson
<gary@...> writes
>Hi Fernado,
>Reggie has pretty much covered what you will lose (for a more exact
>description of the differences take a look at the Introduction sections
>of the AN1xEdit Help file).
>The bottom line is that if a voice doesn't rely on both scenes or An1x
>effects, then the result will be almost identical.
>If a voice relies on effects then you may be able to compensate using
>the effects of the PLG host (although I don't know of any PLG hosts that
>provide the most used AN1x effect...Tempo Delay! It may be worth
>checking this out on Motif)
>If a voice relies on dual scenes then there is going to be a noticeable
>difference. However, it is not true that you cannot covert the second
>scene. Simply duplicate the voice in the An1xEdit library (in AN1x
>mode). Then use the program copy features to copy the second scene to
>the first scene of the duplicate voice. You will now have two identical
>patches expect one contains the first scene and the other the second.
>You can then convert the library to PLG mode (by saving and then loading
>into An1xEdit in PLG mode).
>The useful of the second scene really depends on how it was used in the
>original A1nx patch.
>a) If the scenes were always used as independently then you are
>OK...simply select the appropriate saved patch.
>b) If the second scene was purely used for morphing, you are in
>luck....as you can setup the PLG150AN to morph between the current patch
>and an alternate patch in the preset or user banks. Hence you could
>morph between the two patches you saved above.
>b) If it was used as a layer or a split then you really need two PLG
>cards to replicate the same patch (i.e. each card loading one of the
>scene patches).
>On the plus side the PLG does offer some things that AN1x doesn't. For
>instance it provides some additional VCO and LFO waveforms and there is
>a new cross modulation algorithm between the VCOs. Also if you are using
>it within a DAW system such as the XGFactory cards (SW1K, DSPF), then
>you can maintain all signals in the digital domain.
>Of course used with Motif it does add more variety to your performance
>options ;-)
>Regards
>Gary Gregson
>Email:gary@...
>http://www.yme.co.uk/yme
>-----Original Message-----
>From: fernando.guerreiro@...
>[mailto:fernando.guerreiro@...]
>Sent: 06 June 2001 18:43
>To: AN1x-list@yahoogroups.com
>Subject: [AN1x-list] Transferring patches from AN1x to PLG150AN
>Hello all,
>I'm a proud owner of an AN1x for almost 3 years. It is the controller
>keyboard (and only keyboard)in my home studio. The thing is, I'm
>planning to upgrade, and because of space reasons I will have to sell
>it. I'm really interested in the new Motif 6 keyboard, and I'm
>planning on adding a PLG150AN board to it, in order not to loose my
>fantastic AN1x sounds. Will the conversion of my patches to this
>board work 100%? I mean I know I will loose on polyphony, but other
>than that what should I expect, in what regards FX, free EG, step
>sequencer and the sounds themselves?
>Thanks in advance for your help.
>Community email addresses:
> Post message: AN1x-list@yahoogroups.com
> Subscribe: AN1x-list-subscribe@yahoogroups.com
> Unsubscribe: AN1x-list-unsubscribe@yahoogroups.com
> List owner: AN1x-list-owner@yahoogroups.com
>Shortcut URL to this page:
> http://groups.yahoo.com/group/AN1x-list
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
See ya,
Reggie
