Newbie question, some help would be welcome...
2001-04-19 by midisys@flevonet.nl
When i play samples on my Akai S2000 and using the AN1x to trigger the samples, the samples play with to much aftertouch. When i trigger the samples with another kb the samples sound o.k. Is it possible to adjust the aftertouch on my AN1x? I looked at the manual but coud'nt find it... thanx in advance Johan van Beek
2001-04-19 by dbase789@aol.com
Hy. Don't know if it is precisely what your looking at, but you should try -if not already- to lower the velocity of the key board. it's in Utility/Setup third switch.. I think there i a way to disable or minor the AT sensitivity, but can't tell you how precisely. Hope it can help. --- In AN1x-list@y..., midisys@f... wrote:
> When i play samples on my Akai S2000 and using the AN1x to trigger > the samples, the samples play with to much aftertouch. > When i trigger the samples with another kb the samples sound o.k. > Is it possible to adjust the aftertouch on my AN1x? > I looked at the manual but coud'nt find it... > > thanx in advance > Johan van Beek
2001-04-19 by RayMaxer
Johan , Unfortunately not ... Try lowering the amount of aftertouch modulation in the Akai's patch. Ray. midisys@... wrote: > When i play samples on my Akai S2000 and using the AN1x to trigger > the samples, the samples play with to much aftertouch. > When i trigger the samples with another kb the samples sound o.k. > Is it possible to adjust the aftertouch on my AN1x? > I looked at the manual but coud'nt find it... > > thanx in advance > Johan van Beek > > Community email addresses: > Post message: AN1x-list@yahoogroups.com > Subscribe: AN1x-list-subscribe@yahoogroups.com > Unsubscribe: AN1x-list-unsubscribe@yahoogroups.com > List owner: AN1x-list-owner@yahoogroups.com > > Shortcut URL to this page: > http://groups.yahoo.com/group/AN1x-list > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ -- http://www.mp3.com/raymaxer - full tracks and CD !
2001-04-19 by jondl_2000@yahoo.com
The velocity control is independent of aftertouch on the AN1x. There is no control on the AN1x to reduce the amount AT transmitted from the keyboard. You'll need to reduce the modulation depth setting at the destination MIDI module as Ray already suggested. If you are using a software sequencer you could apply a filter to exlude AT. Some programs permit this as a global setting but it might be possible at the track level as well - depends on the program. regards, Jon --- In AN1x-list@y..., dbase789@a... wrote: > Hy. Don't know if it is precisely what your looking at, but you > should try -if not already- to lower the velocity of the key board. > it's in Utility/Setup third switch.. > I think there i a way to disable or minor the AT sensitivity, but > can't tell you how precisely. > Hope it can help. > > --- In AN1x-list@y..., midisys@f... wrote: > > When i play samples on my Akai S2000 and using the AN1x to trigger
> > the samples, the samples play with to much aftertouch. > > When i trigger the samples with another kb the samples sound o.k. > > Is it possible to adjust the aftertouch on my AN1x? > > I looked at the manual but coud'nt find it... > > > > thanx in advance > > Johan van Beek
Or may be even scale down the aftertouch values after recording from AN-1x (in the software sequencer) or (as AN-1x sends too 'discrete' values of aftertouch) re-draw the aftertouch graphic looking at the original ... Ray. jondl_2000@... wrote: > The velocity control is independent of aftertouch on the AN1x. There > is no control on the AN1x to reduce the amount AT transmitted from > the keyboard. You'll need to reduce the modulation depth setting at > the destination MIDI module as Ray already suggested. > > If you are using a software sequencer you could apply a filter to > exlude AT. Some programs permit this as a global setting but it might > be possible at the track level as well - depends on the program. > > regards, > > Jon > > --- In AN1x-list@y..., dbase789@a... wrote: > > Hy. Don't know if it is precisely what your looking at, but you > > should try -if not already- to lower the velocity of the key board. > > it's in Utility/Setup third switch.. > > I think there i a way to disable or minor the AT sensitivity, but > > can't tell you how precisely. > > Hope it can help. > > > > --- In AN1x-list@y..., midisys@f... wrote: > > > When i play samples on my Akai S2000 and using the AN1x to > trigger > > > the samples, the samples play with to much aftertouch. > > > When i trigger the samples with another kb the samples sound o.k. > > > Is it possible to adjust the aftertouch on my AN1x? > > > I looked at the manual but coud'nt find it... > > > > > > thanx in advance > > > Johan van Beek > > Community email addresses: > Post message: AN1x-list@yahoogroups.com > Subscribe: AN1x-list-subscribe@yahoogroups.com > Unsubscribe: AN1x-list-unsubscribe@yahoogroups.com > List owner: AN1x-list-owner@yahoogroups.com > > Shortcut URL to this page: > http://groups.yahoo.com/group/AN1x-list > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ -- http://www.mp3.com/raymaxer - full tracks and CD !
