Archive for AN1x-list.
any SYSEX masters in this group?
Re: any SYSEX masters in this group?
2016-05-11 by DEREK COOK
Sorry, tried replying to this last week whilst away, but my iPAD won't allow me to send from a btinternet email account..., and for some reason I can no longer log onto Yahoo via internet, and then I forgot....
Anyhow. I program the an.factory Java librarian, so have intimate knowledge of AN1x SYSEX and have programmed SYSEX support for the PLG150-AN and AN200 (although I don't have one of those).
So is that is enough mastery for you? And what do you want to do?
Cheers
Derek
2016-05-22 by mpsfmpsfmpsf@...
Thanks Derek! You might be able to help.
While I was scrawling through the MIDI parameters of the AN200 (making the most of this machine by arming myself with a bunch of external faders controlling a whole heap of hidden functions) I noticed that on page 133 it says the following:
Step Seq Loop Type forward(0),backward(1),alternateA(2), 00(forward) alternateB(3)
NOW surely this means there is a way to get the sequencer to play in directions other than 'Forward' and Backward' - which is only possible via the front panel controls.
Do you know anything about this? I've spent ages trying to work out the sysex for this on my Kenton Control Freak and doesn't work! So frustrating! I've got what seems to be the correct sysex message but only Forwards and Backward work and the other two modes simply don't function. Would love these extra modes - it would be amazing to get the standard 16-step sequencer to be effectively doubled by having it play 'Ping Pong' for example.
BTW. the message I'm sending is
F0 43 10 5C 00 00 09 XX F7 (where XX is one of the 4 playback modes)
Thanks very much, really hope this makes sense to you.
Suren
Re: [AN1x] Re: any SYSEX masters in this group?
2016-05-22 by Amos
Hello everyone,
I'm having difficulty getting my AN1x midi work on Logic pro x. Also, connecting midi to a controller never works: a lot of hitch, instability, fluctuation. Pls, I need help. How can I experience stability with the midi?
Cheers in advance!
Amos
Sent from my BlackBerry 10 smartphone.
Sent: Sunday, May 22, 2016 20:18
To: AN1x-list@yahoogroups.com
Reply To: AN1x-list@yahoogroups.com
Subject: [AN1x] Re: any SYSEX masters in this group?
Suren
2016-05-23 by DEREK COOK
Hi, Suren
Yes it makes sense to me :-)
As I said, I don't have an AN200 myself, but can't check things specially. Your SYSEX message looks correctly formatted to me (P119 of AN200 PDF manual shows the dump).
Is your AN200 set to SYSEX ID of 1 or ALL? Have you tried other parameter ca=hanges and can you see them work?
When experimenting with SYSEX, I use MIDIOX. You can type commands manually and then send them.
Regards
Derek
Do you know anything about this? I've spent ages trying to work out the sysex for this on my Kenton Control Freak and doesn't work! S o frustrating! I've got what seems to be the correct sysex message but only Forwards and Backward work and the other two modes simply don't function. Would love these extra modes - it would be amazing to get the standard 16-step sequencer to be effectively doubled by having it play 'Ping Pong' for example.
Suren
2016-05-23 by mpsfmpsfmpsf@...
Thanks for the reply. Yes I know SYSEX works 100% as I've been sending a whole load of other messages to it, I've mapped at least 45 faders on an external controller to different messages for the AN200!
So that's why it's extra frustrating that this sequencer play mode I'm trying to explore doesn't work - it would be 1 of the best features imho.
1 possibility is that this feature doesn't exist and was just borrowed from AN1X SYSEX data and was never proof-read before being published :-(
2016-05-23 by Jeff
Hello !
i suspect that your problems come from the USB - MIDI interface. For some obscure reason some work perfectly, others not. All will send and receive note data, nearly all deal with mod wheel or ribbon data, but the troubles come with SysEx data which can be "too long". Borrow another one, different from yours of course, and have a try. Or, using  Midi Ox (freeware MIDI "swiss knife") you can check what is coming from your synth and what you can send from your computer. There is somewhere on the An1X forum a short list of the "bad" and "good" ones... if i remember well.  You can experience similar troubles with hardware mergers, most will severely filter anything else than notes and mod wheel - pitch bend data.
Cheers.
J.F.
> Message du 22/05/16 21:46
> De : "Amos amustsuccess@... [AN1x-list]" <AN1x-list@yahoogroups.com>
> A : AN1x-list@yahoogroups.com
> Copie à :
> Objet : Re: [AN1x] Re: any SYSEX masters in this group?
Hello everyone,
Cheers in advance!
Amos
Suren
2016-05-23 by michael@inoutflux.dk
------ Original message------
Date: Mon, 23 May 2016 21:21
To: AN1x-list@yahoogroups.com;
Subject:Re: [AN1x] Re: any SYSEX masters in this group?
Hello !
Cheers.
J.F.
> De : "Amos amustsuccess@... [AN1x-list]" < a="">><>
> Copie à :
Hello everyone,
Cheers in advance!
Amos
Suren
2016-05-25 by DEREK COOK
Well if you are confident that other features are working, then you could be correct and the function does not exist despite what the manual says. I've seen errors in them before.
Cheers
Derek
2016-07-09 by Sobaboy
Try changing the 5C to 6D.
To:
F0 43 10 6D 00 00 09 XX F7 (where XX is one of the 4 playback modes)
Sobaboy
Just to test this, I setup a one bar sequence and fed it the 6D sysex string replacing the XX with the values from 0 to 127. It responded to 0 and 1, and displayed "For" for other values.
Sobaboy
To:
Sobaboy
2016-07-11 by Suren seneviratne
Hey thanks for trying this out! I did try with 6D at some point before, but it didn't work for me. I will try again.
Do the other modes work for you?
On Saturday, July 9, 2016 12:51 PM, "Sobaboy yahoo-lists@... [AN1x-list]" <AN1x-list@yahoogroups.com> wrote:
Sobaboy
To:
Sobaboy
2016-07-11 by mpsfmpsfmpsf@...
Just to confirm, yes I was sending 6D all along but it definitely doesn't work. I've tried Yamaha Support and they initally sent me SYSEX messages to transmit which was exactly what I had been sending (but with the original 5C) code. So even they seem to be confused.
I just really want to hear/see someone pull this off to know if it's possible! Otherwise it seems like the manual may have just taken this SYSEX info from the AN1X and forgot to edit it.
Which is really crap
