Trouble with running AN1X Edit via MOTU Fastlane
2009-02-16 by Justin Wiley
Hello all,
I posted awhile ago about having trouble running An1x Edit on my Mac
g5 OS X. I recently purchased a MOTU Fastlane, which I've heard on
this list has worked for others in the past. Can anyone help me with
the set-up? I downloaded the OMS drivers for the MOTU(FreeMidi) and
have placed them in the OMS folder. I have Mac OS 9 running for the
OMS Set-up and the AN1x Edit. I created a device profile for the AN1x
and I see the little AN1x icon. But there is no responses when I
attempt to load a patch onto the AN1x. Any ideas about what I could do
next? I tried using Midi Bridge awhile back, but to no avail. It still
pops up in the studio set-up screen when I open the AN1x OMS Set-up.
Is this causing the problem? Cheers, Justin
Re: Trouble with running AN1X Edit via MOTU Fastlane
2009-02-19 by Jon
--- In AN1x-list@yahoogroups.com, "Justin Wiley" <g_killian_77@...> wrote:
> Hello all,
From the FAQ, try this:
AN1xEdit will Transfer but not Receive Voices?! (Mac OS 9)
The Macintosh version of AN1xEdit requires the use of OMS (Open Music System)
configured for your MIDI Interface to communicate with the AN1x synthesizer. Under some
circumstances AN1xEdit will not receive SysEx from the AN1x - typically when the MIDI
Interface has been disconnected or reinstalled.
Here's the quick fix to restore communication between OMS and AN1xEdit:
Make certain you are running v1.02 or higher of AN1xEdit.
Double check that OMSLibPPC.slb is in the AN1xEdit folder - do NOT move this item to
your Extensions folder. OMSLibPPC.slb should remain in the AN1xEdit folder.
From within AN1xEdit, under the Setup menu select the MIDI Port Setup... option.
Notice the devices listed in the drop down menu are those defined in your OMS Studio
Setup document. Typically you the MIDI In and MIDI Out options are set to AN1x. In those
instances where OMS and AN1xEdit have stopped communicating - toggle between any
devices other than the AN1x from the MIDI Port Setup... dialog then back again to AN1x
will reestablish the dropped connection.
Also, double check your system installations files... should be like this I beliee:
System Folder (OS 9) -> Extensions -> USB OMSMIDIDriver
System Folder (OS 9) -> Extensions -> FreeMIDI System Extension
System Folder (OS 9) -> OMS Folder -> OMS USB Manager
System Folder (OS 9) -> OMS Folder -> MOTU OMS Driver
System Folder (OS 9) -> FreeMIDI Folder
