I remember that in the case i mentioned, some of the voltages I measured would change unexpectedly when I played up and down the keyboard, thus giving me the clue that the analog and digital systems had become "floating" relative to each other.
I’m keen to know where the grounds should be linked. I’m seeing the M card
ground is 0.3 ohm with respect to the logic power ground, but around 2k to the
+/-15V ground. I’m guessing that shouldn’t be the case?
I
other.
I'm sorry I can't provide any further details about where the grounds join together or join back to the grounds from the PSU; I just don't remember. One detail I can provide is that it was power rails measured with respect to the metal chassis that would change depending on what keys were played, so for example that +11V you are measuring would move around depending on what key was last pressed. That 2K ohms measured from the Mcard Gnd to the +/- 15 V ground sounds fishy to me, but you'll want to confirm of this is correct/expected before you change/add any connections, lest you cause even more damage.
jkjelec
On March 15, 2017 at 8:38 AM "'LucidSound' lucidsound@... [yamahacs80]" <yamahacs80@yahoogroups.com> wrote:
I’m keen to know where the grounds should be linked. I’m seeing the M card ground is 0.3 ohm with respect to the logic power ground, but around 2k to the +/-15V ground. I’m guessing that shouldn’t be the case?
