Yamaha CS80 group photo
Yamaha CS80
Archive for yamahacs80.
CS 50 due for overhaul: Any pointers?
2015-07-15 by Stephen Parsick
Hi all,
I have finally managed to talk my tech into having a go at my CS 50 -- any things that require particular attention or that should be looked at? My 50 has the habit of occasionally producing portamento on some notes even though no portamento has been dialled in. Sometimes (very rarely) notes with a long release have a tendency to drift upwards in pitch -- I seem to remember that this is due to some caps gone bad on the KAS board, is that true? What CMOS components should be replaced as well?
Any inspiration is welcome. Thanks,
Stephen.
Re: CS 50 due for overhaul: Any pointers?
2015-07-21 by blatnik_michael@...
hi, maybe this page is of interest, some good hints for repair there. http://www.cs80.com/
my cs60 is still working perfect, but i´m also thinking about changing some parts. especially the (standard) ic´s on the KAS and old capacitor (on the PSU) should be changed, this also should solve your problems.
michael
Re: [yamahacs80] Re: CS 50 due for overhaul: Any pointers?
2015-07-23 by Rikard Latvala
I did a big overhaul of a CS-50 including:
Change of all CMOS.
Recap of all Caps (ceramics, mylars, Polystyrene, tantalum and aluminium electrolytics changed to Panasonic FC series)
Changed all open type trimers for closed multi turn one´s.
Total recalibration
installed Kenton MIDI kit.
Now it stays rock solid in tune.
Have a CS-60 and a 50 at home for the same work.
Noticed CS-60 has all IG chips in low cost sockets (They will be desoldered and replaced by
high quality gold plated one´s)
Also have done a complete socket change on a memorymoog with one voice
dropping out of the autotune routine, with new sockets for all the CMOS and Analog IC´s
the voice will not be dropped but still is quite out of tune. It did have a few other issues which
are now gone with the socket upgrade.
Just some ideas for your CS-50.
-----Originalmeddelande-----
Från: "blatnik_michael@... [yamahacs80]" <yamahacs80@yahoogroups.com>
Till: yamahacs80@yahoogroups.com
Datum: 2015-07-21 11:00
Ämne: [yamahacs80] Re: CS 50 due for overhaul: Any pointers?
michael
Aw: Re: [yamahacs80] Re: CS 50 due for overhaul: Any pointers?
2015-07-25 by Stephen Parsick
Thank you for all your responses, much appreciated.
Apparently, my messages make it to the list again. Thanks, David!
Stephen
Gesendet: Donnerstag, 23. Juli 2015 um 16:37 Uhr
Von: "'Rikard Latvala' rikard.latvala@... [yamahacs80]" <yamahacs80@yahoogroups.com>
An: yamahacs80@yahoogroups.com
Betreff: Re: [yamahacs80] Re: CS 50 due for overhaul: Any pointers?
Change of all CMOS.
Total recalibration
michael
