AT sensor board issue
2013-05-19 by joachim.milson
Hi All,
I acquired my CS80 (unit 1670) less than a month ago. It has a couple of
known issues all bound to the keys.
The one that could be fixed:
- a sequence of 6 consecutive keys had neither AT nor IT. The faulty
chip was a 4016 (Gates) on the TKC.
- two keys had no IT but AT was OK. It took me some time to find out
that this was due to the PCB holding the "IT/note" metal strips at the
back end of the keys. I had to solder two short wires to bypass the two
non conductive printed tracks, although nothing could be seen (no
scratch on the PCB). Has someone already had this problem ?
I'm stuck with the last issue (at least known to me for the moment).
One AT sensor board seems faulty under one key (G#3).
Here is a close-up of the faulty AT sensor board
<http://groups.yahoo.com/group/yamahacs80/photos/album/1863574374/pic/56\
3904716/view>
Compares to the other tracks on the same board, nothing seems to be
different.
The problem is that the voltages at T3 are always two high:
The voltages for a normal key vary (as I measure them) from -0.3V (not
pressed) to 6.2V (pressed to the maximum)
Under the faulty key, the values are 1,7V (not pressed) to 8.4V
(pressed to the maximum).
So the voltages seem to be shifted upward by 2 V under the faulty key.
Certainly some printed resistor is faulty.
The result is that, depending on the AT settings for the current preset,
the corresponding note sounds a bit too loud and can even be heard when
it should not.
I switched the PCB with the last one on the right, so the problem is now
on G#5, where it is slightly less audible, but still there (no miracle
Is there a way to somehow repair this issue ? If not, has someone one
such board (one for the black keys) in his spares stock and would accept
selling it ?
Any help will be appreciated.
Joachim
3904716/view>
different.
it should not.
selling it ?
Joachim
