Yamaha CS80 group photo
Yamaha CS80
Archive for yamahacs80.
CS80 stuck/hanging note
2013-05-05 by Nigel99
Hello all,
Longtime lurker and recent CS80 owner here. My CS arrived last week after international shipping in a custom roadcase in seemingly good order.
On first inspection everything worked well but after moving it two rooms away to my studio it has now developed a stuck or hanging note issue. The note is heard from the time that I switch the synth on and I have isolated it to voice 5 on the top bank.
It has been suggested to me that it may just be a trimmer that has slipped and needs minor adjustment. I have fiddled with the lower trimpots on the M board and while I can defeat the voice altogether no setting can remove the sustaining note
I am about to swap out the EG IC and next the VCA on the M board and thought that it may be best to refer to the group to see if anyone else has had a similar issue.
Thank you in advance and best regards,
Nigel
Re: [POSSIBLE SPAM] [yamahacs80] CS80 stuck/hanging note
2013-05-05 by Laurie Curry
I assume you checked the key contacts.... I have one that is very bouncy and on occaision needs rebending.... or it sustains
To: yamahacs80@yahoogroups.com
Date: 05/05/13 17:18
Subject: [POSSIBLE SPAM] [yamahacs80] CS80 stuck/hanging note
Hello all,
Nigel
2013-05-06 by Nigel99
Hi Laurie,
The key contacts are fine. The sustained note changes whenever the 5th voice is assigned.
> -----Original Message-----
> From: Nigel99 <nigelc@...>
> Hello all,
> Nigel
Just an update: I changed the EG chip and that did not solve the problem. Next I swapped the VCA and the voice disappeared altogether so I swapped back the original VCA and the synth now works fine. Very strange.
I am scavenging chips from a CS50 voice board that I bought a couple of years ago through this site. Apparently the board was 100% operational so I guess I could have fried the VCA desoldering it from the board. Still doesn't get me closer to working out what the problem with the CS80 was. A good result however.
--- In yamahacs80@yahoogroups.com, "Nigel99" <nigelc@...> wrote:
> Hi Laurie,
> > From: Nigel99 <nigelc@>
> > Hello all,
> > Nigel
Re: [yamahacs80] CS80 stuck/hanging note
2013-05-06 by David Rogoff
Hi Nigel - welcome to the group. Good news it's working now. I didn't have a chance to look into this before you fixed it.
FYI to any other group members trying to get hold of me: I've been very overwhelmed recently with both work and a very sick family member so lot's of stuff around the house, including CS80 work, is being neglected. I'll be catching up soon (I hope) on this stuff.
David
2013-05-10 by Nigel99
> Hi Laurie,
> > Hello all,
> > Nigel
Re: CS80 stuck/hanging note
2018-10-01 by jw_dewdney@...
did you ever fix this problem? just curious - i'm a bit appalled at the lack of response from forum members
